new caps reading low on the capacitance meter.
  • hydrive
    • Nov 2012
    Hi, I had two capacitors that were exploded on my motherboard, allthough it seemed to still work ok but I wanted to replace them so I removed the exploded capacitors and ordered replacement ones on ebay. Before I installed them I wanted to ensure they were functioning properly, so I tested them with a capacitance meter.
    One of the ones that exploded was rated at 1000 uF, 16 V. I ordered 5 of them on ebay and when I measured them with the capacitance meter, they were as follows:
    867 uF
    818 uF
    930 uF
    870 uF
    816 uF
    Since the reading seemed rather low I checked the listing out again, and I notice that it says Tolerance is + or – 20%. Does that mean they are good if they read anywhere from 800 uF, to 1200 uF? Or does that mean I purchased low quality caps since the tolerance is so high? They do not have any brand printed on them but the spec sheet says the series is NHG, so I googled it and I believe they are made by Panasonic. Would these be worth installing or is the capacitance too low?
    The other one that blew was 820 uF, 6.3 V. I ordered four of them (from a different ebay seller) and I measured the capacitance and got the following readings:
    890 uF
    890 uF
    897 uF
    894 uF
    These all seem rather high. These are Nichicon HN capacitors. Is it safe to use them even though they are measuring a bit higher than the rating?
    Please clarify for me!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: new caps reading low on the capacitance meter.
    Probably 98% of the capacitors on ebay are fake.
    Since you live in the USA, you have cheap and reliable distributors that sell genuine capacitors with low cost shipping and quick delivery times (usually within 2 days).
    Digikey, Mouser, and badcaps.net all meet the above criteria.
    --- begin sig file ---
    --- end sig file ---
    • Kiriakos GR
      Banned
      • May 2012
      • 940
      • Greece
      Does this capacitance meter have a name ?
      • hydrive
        • Nov 2012
        The meter I am using is an old meter, but it seems to work just fine. I have tested lots of other caps and the rating is always very close to what it says on the label. But the meter is branded as follows: BK Precision, dynascan corp, 820 capacitance meter.
        Retiredcaps- Thanks for the info on the suppliers. I will keep that in mind for future projects.
        Given that info, I now assume that the the no name caps I ordered are junk especially since the rating is so low. Still not sure about the Nichicon ones I ordered from ebay. Lets say hypothetically I purchased 4 of them from a recommendable source, (820 uF, 16 volts). If I measured them with the meter would it be uncommon for them to be slightley higher, such as in the 890 range?
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          Your meter is made at 1978 and looks to have 4% accuracy.
          At 1000uF you will have +/- 40uF error, plus it needs 10-30 seconds so to setle down.
          Not the best choice for true capacity comparisons.
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            Re the supposed Nichicon HNs, that they are all reading high suggests the possibility that they are fakes whose electrolyte lacks stabilizers to prevent the electrolyte from attacking and thinning the aluminum oxide layer (the dielectric in an electrolytic capacitor). IF that is the case, thinning the oxide layer would have two effects: 1.) decreasing its true maximum voltage (and ongoing deterioration would eventually thin the layer to the point of causing the cap to vent); 2.) causing the capacitance to increase (dielectric thickness and capacitance value are inversely related).
            If you could post pix of the supposed HN caps, showing all markings, the top vent and the rubber bung, folks here could give you a better idea about the likelihood of the parts being fake or real.
            PeteS in CA
            • bigbeark
              • Jan 2010
              • 661
              Not to deny your point entirely, but sometimes you need an odd-sized cap that is not available through the normal distribution channels. Typically it is a higher UF and voltage in an 8 or 10mm can. Surprisingly, these are seldom faked. They will be old stock however.
              I have had good luck sourcing FJ series Panasonic caps via Ebay. They have the precut short leads and were obviously intended for some OEM production run but were surplus.
              I always test new caps with my ESR and capacitance meters. I have only had one fake experience: some Panny WG 2200uf 16v 10mm. They all measured 1500uf and the ESRs were all over the place. Never dealt with that seller again.
              Otherwise, I source caps via Mouser, Topcat & Digi-Key as recommended. A lot quicker and no surprises!
              • chth96
                by chth96
                03-09-2024, 10:03 PM
                12-31-2023, 06:04 AM
              • Ryan Wurtz
                Lenovo Yoga C740-15IML 5V on usb meter.
                by Ryan Wurtz
                Hello. So I searched and didn't find any posts on this specific problem.
                When plugged in USB power meter reads 5v
                Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                Original mobo had a shorted cpu it seems.
                So I decided I need a new motherboard.
                Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                5v on the meter. Still won't charge. Can still charge the battery...
                11-24-2025, 01:08 AM
              • jorpec
                by jorpec
                Hi
                Thnaks
                01-23-2023, 10:37 AM
              • SuperAman
                PS5 HDMI port diode reading?
                by SuperAman
                I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                02-03-2024, 10:16 PM
