Re: Cap Datasheet Depot
I made a mistake in my previous post. KY is a series of capacitors made by United Chemi Con, not Nichicon.
The vent shape is not used by Nichicon so that's definitely not a Nichicon capacitor. It is used by United Chemi Con but usually their capacitors are brown, not black. Maybe it was a custom series made for Sony.
Other than this, all your pictures are from above, it would have made more sense to post some pictures from an angle, and it would help if you used a flashlight and maybe the macro mode of your camera to take the shots.
You can replace those 1000uF 25v capacitors with the low esr capacitors sold on Badcaps, if not you can buy Panasonic FM/FR or Nippon/United Chemicon KZE/KY/LXZ or Nichicon HW from genuine distributors like Digikey.com or Mouser.com or Newark.com (all three US sellers)
Cap Datasheet Depot
This is a sticky topic.
Originally posted by mariushm View PostKY is a fairly common series of capacitors from Nichicon, mostly used in computer power supplies.
But without some more information, what you say is not enough to say for sure it's Nichicon.
https://www.badcaps.net/forum/showthread.php?t=49363
They're 1000uf 25 volt M(105C) rated. There's a reference to "4(7) 9Y".
All I can say is it looks like "[ ]KY".
Is anyone aware of capacitors which have a "OKY" label on them?
It looks like "[ ] KY".
Shenzhen Zeasset Electronic Technology (ZSTE). From zeasset.com.
Here is RF series datasheet from GJT
Couldn't find it anywhere else.Attached Files
Here are ChengX DS, this ones were not taken from ChengX website but from a distributor in HK (Bentex), cause those were the only ones I could find in HTML version, I checked like 7 random DS against the ones in ChengX website and all matched, DS were slightly reformatted to make them more readable and then converted to PDF.
PS- If somebody is interested in those JPG scans from ChengX let me know and I'll post them.Attached Files
I'm attaching all SAMWEI datasheets in case someone needs them, in the following days I'll be posting ChengX too.Attached Files
ChengX HERE but very low resolution images only
Canicon doesn't have website or at least not a public onesame for YC.
anybody got datasheets for canicon and chengx ?
Thank you very much for it! Added there:
http://www.uloz.to/xcR7d7Kw/Samxon+a...datasheety.zip
Great compilation!
There is sadly missing Samxon GA datasheet... anyone have it?
Has anyone ever found or seen any Datasheets from Yang Chun (YC), Deer/Solytech's favorite capacitor company?
I went looking for this series and it was missing from your extensive list.
Lelon RXA series. (Nippon Chemi-Con KZE equivelant rating)
Could you kindly add them to your collection?
Of note....
I located it at the following webpage, which has many datasheets for this brand.
http://www.capacitorsupplier.com/lelon/lelon.htm
Datasheets for other x-brands here: http://www.capacitorsupplier.com/data_sheets.htm
Thanks for the awesome database.
What a wonderful resource!!
Thank you very much for this list I find myself viewing quite a few of them often. Cheers!
I think they are actually meant to be equivalent series. It doesn't mean that KSC stole the specs for some random cap series.
Awesome library of datasheets, Uranium, but amid them look what I found!!
https://cdn.badcaps-static.com/pdfs/...df27fd2c10.pdf
https://cdn.badcaps-static.com/pdfs/...5472ea4654.pdf
Notice how KSC's "GL" series has the same exact ripple and ESR ratings as Nichicon's PJ series??? Looks like cheap Chinese King Sun stole Nichicon's PJ ripple and ESR ratings because they don't want us to know the real ones!!! Can't say I'm really surprised... because of this though I'm not gonna trust the other KSC datasheets... of course the cheapo Chinese brands lie...
I suspect Samwha LT is discontinued. The only route for replacement I guess is to go for something like Pana FM/FR and assume that it was a low-ESR application they were in.
Yes, some are damaged. The latest catalog I have from Samwha is that large one...
I got it a few months ago by "sniffing" the http requests their Flash based online catalog was making to obtain the full pdf file.
If it's not there, chances are it's either a discontinued series (they remove the discontinued series and suggested replacement series for those after a while from their site) or it's a custom series made on order for some manufacturer.
