Monitor: Sony SDM-HS74P LCD
  • forswitch38
    • Sep 2015
    • 10
    Before I explain the monitor, I want to say I'm new here. I also am a hardware noob. I've spent most of my life with computers. I've built one and I've programmed software. But I've never soldered on the circuit board or even hacked a graphics card to put a custom heatsink on it. See, at the hardware level, the most I've done is simply oiled some fans.
    Now onto the problem...
    This one came with a prebuilt computer in 2005. I think in 2010 or 2011 it started shutting off. I was able to keep it working by pressing menu buttons and changing the brightness--if I recall rightly. There was only a couple seconds when this would work, after which it would stay off. However, at some juncture, that stopped working. So probably in 2010 or 2011 I put this thing in storage and forgot about it. Now I picked it up again because I want to try and get it working again.
    Just to clarify, what happens is this:
    1) I turn it on
    2) Takes a few moments and then the screen lights up and shows whatever is on it. If the cord isn't connected, it'll say there's no signal. Otherwise, it'll act normally and show whatever is supposd to be onscreen.
    3) About 2 seconds later and it shuts off
    I've done hte flash light test and I know things are still showing on the screen. For example, I can see the bootup screen prompting me for my password. If it's in Widnows, I see whatever should be there. So I'm led to believe the inverter or CCFL's or wiring inbetween them is failing, meaning things ARE on screen, but not lit up.
    This--I believe--is the service manual:
    http://www.go-gddq.com/upload/2009_0...0810482821.pdf
    From what I can tell, it's a heavy construction, not lightweight. I removed the cover via screws, so I didn't have to monkey with any tabs, as I feared.
    Here's a picture of its layout:
    I lack the knowledge to make much sense of it. However, I'm guessing the power board is in the middle, the inverter board on the left and the processing board on the right.
    After I opened it up, I looked at the capacitors to see if any were bulging. Unfortunately, there was not any obvious bulging, as I had hoped there would be. There is a capacitor on the right which is crooked, but it doesn't look like there's any bulging underneath or above. (Ignore the fact it's discolored on the image above--that's my shadow) All of the capacitors looked, but except there were 2 which caught my interest. These:
    (Note the crack on the right one and the copper colored discoloration on the left)
    Disregard the green goo inbetween them. That was in other places. I'm led to believe it's to decrease vibration or maybe dissipate thermal heating. Is the copper colored spot on that one to be worried about? It looks almost like rust. The crack on the other one was immediately visible. It's not deep by any means. I also don't notice any seepage. While there's no bulging on either of them, these features felt worth asking about on these forums. Both of those appear to have a manufacturer which goes by "[ ] KY" It looks somewhat like OKY. They're 1000uf 25 volt 105C rated. There's a reference to "4(7) 9Y".
    Sadly (inconvenentily) I do not as yet have an ESR meter or capacitance meter. I do have a old meter of sorts, but I don't think it'd be of any use. It's named GB Instruments GMT-12A. Here's the manual:
    http://www.ps2netdrivers.net/manual/...mt-12a/#manual
    Neither do I have the other things I need: soldering iron, soldering wick or solder sucker, solder wire. So right now I'm just digging for information. I may also open it up again and take a look at the underside of the boards, as I've told they can show damage too. I also want to figure out how to get cleaner shots with the camara.
    Some questions I have:
    1) Are the capacitors available in the shop on this site rated as being low ESR?
    2) Do I HAVE to get low ESR capacitors? My local radio shack has some 1000uf 35 volt electrolytic capacitors, but it doesn't look like they're low ESR.
    3) If I buy these on badcaps.net, what should I get? And can I use paypal without debit/credit card?
    4) What tools do you recommend I buy to do this job, keeping in mind I'm VERY budget conscious. I might have a $50 budget for this, at most.
    EDIT: Mods feel free to remove one of my (duplicate) threads. ThIS one is a duplicate of my other thread, located at:
    https://www.badcaps.net/forum/showthread.php?t=49361
    I put it in that section first but then put it here because this seemed more apt.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4973
    • New Zealand
    Re: Monitor: Sony SDM-HS74P LCD
    If the capacitor is actually cracked then it would have dried out and could well be the cause of your problems.
    Being a switching PSU, yes, you need Low ESR. And no, Radio Shack don't have those.
    Re: the other thread for identification - can you post a photo showing the capacitor label rather than the top?
    -David VanHorn
      You should also check those two blue caps next to the Inverter transforemrs and same for the two transistors (c5706/5706) next to the blue caps.
      This series are also known for having bad lamp assemblies.
      http://s807.photobucket.com/user/bud...?sort=3&page=1
      • forswitch38
        • Sep 2015
        • 10
        It's at a stupid angle and hard to get a good picture. I may try this weekend.
        I've been reading about switched mode power supplies:
        https://www.mikesarcade.com/cgi-bin/...e=psrepair.txt
        It mentions in there that switching transisters can "short-circuit, causing
        massive amounts of current to be drawn across the transformer and blowing
        the fuse." It says this often happens if the capacitors are bad.
        Can the switching transisters be damaged if the capacitors fail?
        Is there a way to guess what might cause the monitor to "display" this behaviour? The fact it's able to display correctly for a second or two after I turn it on leads me to believe something is working. And the fact ti passes the flash light test means the processing unit is working and activating the correct pixels, even after the fail condition occurs.
        I'm led to believe at this point the invertor and/or the CCFL's and/or wiring inbetween is the culprit. Can anyone elaborate on that?
        • forswitch38
          • Sep 2015
          • 10
          Thanks for the reply. I don't think I looked at them, but they may have been covered. You have to realize by now I'm completely noob with no tools atm. Information gathering right now because it's all I can do and need to do it anyway.
          These're "switching transisters"? Could I visible see any damage?
          By "lamp assembles" do you mean the ccfl's? How many are there? Four?
            There are transistors that drive the high Voltage transformers to light up the lamps. You have to use meter to test them.
            • forswitch38
              • Sep 2015
              • 10
              Anybody know by looking at the image of the board layout if there're "bleeder resistors" for the capacitors?
              If you're wondering what I mean, look here:
              https://www.youtube.com/watch?v=C7qnNMM7Dic
              See, I do not have a hand made bleeder resistor for discharging. I do have a screwdriver, naturally. I haven't plugged my monitor in for a couple days. That should be enough time, given what I've read.
              Anybody have a suggestion for a capacitor testing tool? I've read that ESR meters are the best for these switching power supplies. I've read about capacitance meters as well. Anyone offhand know hte difference?
              Would this do the job for measuring ESR:
              http://www.newegg.com/Product/Produc...4349-_-Product
              I hate the price, though, but... Anything else out there?
              Is there anyway I can use this analog multimeter for testing capacitors:
                You can just measure the DCV between the two legs of that main filter cap to see what DCV you have left on the cap. If you do not have soldering iron to remove the suspected bad parts to test them off the board then you will need to have soldering iron and the solder removing tools. Cheaper to just replace the caps than trying to find out which one had bad ESR. You can buy cheap meter that will do resistance, ESR, DIODE TEST, ETC, READ THIS THREAD FOR EXAMPLE:
                https://www.badcaps.net/forum/showthread.php?t=49296
                • Joe Black
                  eager to learn
                  • Sep 2015
                  • 173
                  • southeastern europe
                  Correct.
                  Basically, what Budm said. You'll HAVE to get a DMM and a soldering equipment if you want to work.
                  Don't discharge caps with screwdriver, just use common sense and don't touch anything dangerous. Hey, you'll most likely have to do some work with board plugged in, bleeder or not, so...
                  Ignore switching transistors. Check those budm pointed you to, and report back.
                  Correct checking procedure is easy to find on forums.
                  stay classy
                    by momaka
                    03-15-2023, 10:17 PM
                  • FZG
                    Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
                    by FZG
                    Hello there, helpful forum people!
                    I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
                    On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
                    The original part...
                    05-10-2023, 11:54 AM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                  • Rick_1234
                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                    by Rick_1234
                    Good evening, gentlemen.
                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                    Things I tried
                    - Bought a new AC adapter thinking that was the problem but the problem...
                    06-22-2024, 04:44 PM
