Re: Cap Datasheet Depot
Here are some newer datasheets from the brand sunion/threecon.
I made sure that only ones you don't have yet made it in.
Cap Datasheet Depot
This is a sticky topic.
Despite the mass KZG / KZJ failures, I also still consider Chemi-con to be a good brand. KZJ was discontinued a decade ago now. No idea if the issues with KZG were ever fixed before discontinuation, but "for what it's worth", I haven't seen a prematurely failed KZG with 2009 datecodes and newer, which says something considering the "bad" KZGs (made from 2001 to 2008) started failing around 2005 to 2011 after a few years of discontinuous use in moderate to high heat environments.
I think Suncon (formerly Sanyo's electrolytic division) is good too, despite a couple bad series / runs from them. I've seen a couple datasheets for Sacon FZ (easily found on Google
). One claims them to be of ultra low-impedance grade like Nichicon HM. The other, closer to Nichicon HD. I wouldn't stake my life on either claim, however.
What about NICHIcon? I wouldn't consider them bad. They just had a bad run of HM/HN/HZ for a few years, but they've fixed the issue since and until they finally stopped making them.
Interesting read. I'll look for the screenshots I made that link Samcon with Elcon.Leave a comment:
Yup, this old thread needs updating it seems
https://www.badcaps.net/forum/showthread.php?t=3369Leave a comment:
From my findings a few years back, Elcon and Samcon are either the same company or one owns the other and they have closely-related products. Elcon EEZ was used quite often on low-end XFX GeForce 9 series video cards and it burst the same way as Sacon FZ.
Now, it gets even more interesting, because XFX used to often use Sacon FZ on their mid- and low-range GeForce 8 series of video cards. And before that, XFX used Evercon and GSC.
So where I am going with this?
GSC changed names to Evercon, which then became Sacon, because they were all utter garbage. Then Elcon came along and died the same way as Sacon... so I'm pretty certain Elcon is just another name for Sacon... and I also have a few screenshots of their website showing Elcon and Samcon factories on the same page.
In short, most likely:
GSC = Evercon = Sacon = Elcon = Samcon = ...GARBAGE
So don't use them!
I do appreciate you posting the datasheets, though.
Might come in handy when needing to replace one of these. Although, the truth is I've seen Elcon EEZ series appear good and measure worse than general purpose 85C caps (that was on a GeForce 9400 GT video card). What I find even more amusing is that Panasonic FM and FR easily beat the crap out of both Sacon FZ and Elcon EEZ in terms of specs... and FZ/EEZ is supposed to be a "high ripple, low ESR" series.
Hasn't that always been publicly available due to the fact they'd rather have it easy to find than not cause they're a good company?Leave a comment:
I've attached the capacitor datasheets for the brand Elcon, after finding that others have had them fail and I couldn't find the DS for them. All datasheets for all currently made series as of 6/20/17.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Homophobia: Gay vs Lesbian?
Sorry to OT here. Uranium-235, do you have a Nippon Chemi Con series SL datasheet in that archive by chance?Leave a comment:
About a month ago, i sent a PM about some ymin capacitor datasheets i found.
Just a reminder because i have not seen them on the site yet.
http://www.sh-ymin.com/products/pmcId=43.htmlLeave a comment:
It's good to hear you are still supporting/working on this. I have almost forgotten about this and just do caps by memory, lol.
Thanks for all the hard work man!
ChengX uploaded. Thanks SIDMX. Only took me two years!Leave a comment:
changes have been nonexistant but I finally have my SSH password reset and winscp installed. Just put jazzie366's jwco addition up there. more to comeLeave a comment:
Here's a Rubycon I'm pretty sure you don't have yet...
https://www.google.com/url?sa=t&rct=...hRhx_-msV7fVEw
Rubycon LEX 125c for LED lamps.Attached Filesif you find these attachements useful please consider making a small donation to the site
fujicon LK?
http://www.paullinebarger.net/DS/Fuj...K%20Series.pdf
for "Hi-Fi sound audio systems"Leave a comment:
Thanks.I made a mistake in my previous post. KY is a series of capacitors made by United Chemi Con, not Nichicon.
The vent shape is not used by Nichicon so that's definitely not a Nichicon capacitor. It is used by United Chemi Con but usually their capacitors are brown, not black. Maybe it was a custom series made for Sony.
Other than this, all your pictures are from above, it would have made more sense to post some pictures from an angle, and it would help if you used a flashlight and maybe the macro mode of your camera to take the shots.
You can replace those 1000uF 25v capacitors with the low esr capacitors sold on Badcaps, if not you can buy Panasonic FM/FR or Nippon/United Chemicon KZE/KY/LXZ or Nichicon HW from genuine distributors like Digikey.com or Mouser.com or Newark.com (all three US sellers)Leave a comment:
First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheetHi all,
I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if... -
by SoulFreezeHi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq.... -
I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
So if anyone has a datasheet or at least... -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by evgentalHey everyone,
I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
Thanks a lot!-
- Loading...
