recapped wrong cap.
  • hon
    • Jul 2006
    • 13
    recapped wrong cap.
    i recapped 1 wrong cap on my motherboard.
    the original cap was 470uf 16v.
    i recapped it with a 1000uf 6.3v. i try power up the sys can work , will there be any major problem in long run?
    thank for all help.
  • hon
    • Jul 2006
    • 13
    Re: recapped wrong cap.
    here my problem in detail.
    i got a mix-up and i recapped 1 wrong cap on my motherboard.
    i did a replacement of all the Teapo caps on my old msi board. there total 17 caps. i over-look because all of them look alike and almost all are 1000uf 6.3v. except 1 is a 470uf 16v.
    if the original cap was 470uf 16v and i recapped it with a 1000uf 6.3v(the sys able to power up) will there be any major problem in long run?
    or if the original cap is a 1000uf 6.3v and i recap it with a 470uf 16v, will there be a problem?
    thank for all help.
    • Tom41
      • Oct 2005
      • 338
      • England
      Seeing as the replacement cap is rated at a lower voltage than the original, I'd say it's a candidate for premature failure. The board is probably trying to put around 16v into it, and as the cap can only support 6.3v - it may well blow.
      The other way round, it's not too bad - the cap would be running on a lower voltage than it was designed for, but that shouldn't damage it.
      In any case, your best solution would be to get hold of a cap that's rated the same as the original cap, and put that on the board instead of the 6.3v cap.
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • tiresias
        • Feb 2006
        • 489
        Yes, the manufacturer's original choice of 16v is probably because that cap will be subject to as much as 12v potential, directly from the PSU's 12vdc line. A 6.3v cap in that situation will not operate correctly at all, and will likely be venting its contents before long.
        Not a problem voltagewise, but you will have reduced the capacitance by more than 50%, which is unlikely to do much good... where is this cap located anyway?
        • Rainbow
          • Aug 2005
          • 1375
          Measure the voltage on the cap. If it's 12V, change it to 16V. If it's 5V (or lower), keep it. The 16V rating on the cap might be used also because it was the lowest available for 470uF.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i see lots of 16v caps used where a 6.3 would do.
            easy test is to hook your vom to +12 on the atx connector in continuity beep mode and probe the + side of each cap.with the board disconnected from the psu of course.
            if none beep call it safe to run.
            • hon
              • Jul 2006
              • 13
              recap the board becuase 1 of the 1000uf 6.3v Teapo leaked.
              Thanks Tom41, tiresias, Rainbow and kc8adu for the great help.
              Able to get hold of a same model board and located the wrong recapped cap.
              Its was behide the PS/2 port (the green cap 470uf 16v), next to a bigger brown 1500uf 16v KZG.
              After I recapped the wrong cap, I did power up the system for about 5mins for a test run (sys running without problem) before i realize the mistake and change it back.
              My questions
              1) Will there be any damage to the motherboard during the few mins power up as a wrong cap was use? (should be 470uf 16v but capped a 1000uf 6.3v)
              2) Is the wrong caped cap damage during the few mins power up?
              Should I throw it away or still can keep it as spare? (can get a voltmeter to test it rite? but I got to get someone for help)
              I know What's done cannot be undone(if the board damage) but these are some questions which I like to know and learn for my mistake.
              I be double careful for my next recap job.
              Really thank everyone for all the great help as my knowledge to all these are limited.
              • nsx29
                • Jan 2006
                • 26
                Hon,
                Would be dame cool if u can show ur solder contacts.
                6.3V 1000mf in place of 16V 470mf should be no problem because most asus boards use 1000 mf 6.3V. U should be fine.
                Don't fix something if it ain't broken.
                • hon
                  • Jul 2006
                  • 13
                  hi, nsx29..nice to meet you.
                  solder contacts? do you mean my 'solder job' at back of board?
                  too bad...i had installed everything back into the casing.
                  maybe the next job i will post them (if there any)
                  took me an hour to replace all the 17, tiring + fun job and was happy when i see the sys able to power up and running without error.
                  • nsx29
                    • Jan 2006
                    • 26
                    That's ok. Hope u nvr have to recap one again. Venting caps are very annoying especially when it happens during school year.
                    • yanz
                      • Nov 2004
                      • 910
                      that small caps is for usb or serial/paralel port it's not necessary to use 16v rate replacement.
                      filtering caps for fan header (12v)wont be no more than 47-100uF. filtering caps for 12v vrm input would be 1500uF or higher (~3300uF). 470uF caps usually found between pci slot, ide slot, legacy port <- there are 3.3v or 5v area.
                      but cmiiw.
                      • yanz
                        • Nov 2004
                        • 910
                        Yes, that's why if u uncertain, always measure the locaton with DMM.
                        Yes, if it is actually wrong cap that placed in wrong place. Never use it again.
                        The answer is simple, just measure what is the voltage in the original place that the cap was placed. If like what i said it's not a 12v area, the caps you just thought wrongly placed are probably still good, except the excessive heat from soldering iron kill it. The trick KC8 said is also useful and smart, i never have thought about it
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          What if the average voltage is low enough but there are also much higher voltage spikes? I had a PSU with 1uF 16V caps that were exposed to 50V spikes.
                          • Rainbow
                            • Aug 2005
                            • 1375
                            Yes, that's possible for PSU. But not for motherboard.
                              Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                              This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-06-2024, 08:16 AM
                            • Agent24
                              Dick Smith Q-1760 linear power supply filter capacitor question
                              by Agent24
                              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                              It has at least one problem.
                              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                              I have already ordered a replacement potentiometer, so that's not an issue.
                              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                              All are CapXon...
                              10-21-2025, 05:39 PM
                            • harp
                              can fanless heatsink replace poor original on RX26PG2
                              by harp
                              I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                              06-25-2025, 10:56 AM
                            • kingiii
                              downloaded bios is smaller than the original bios dump
                              by kingiii
                              Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                              Thank you very much
                              06-07-2025, 04:21 PM
                            • chudofermer
                              Asus Ally rc71l bios
                              by chudofermer
                              Hello!
                              Received Asus Ally rc71l with the wrong bios.
                              Have the original package and all serial numbers.
                              Can anyone help me understand what is wrong?
                              Condition:
                              Received with an original box with all serial numbers
                              Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                              Got the flash dump, nothing found on DMI section
                              No Windows key, just key ID on the box
                              What is done:
                              1. Flash the latest bios version with serial numbers...
                              03-05-2025, 05:42 AM
