Asus Ally rc71l bios
  • chudofermer
    • Jan 2022
    • Украина
    Hello!
    Received Asus Ally rc71l with the wrong bios.
    Have the original package and all serial numbers.
    Can anyone help me understand what is wrong?
    Condition:
    Received with an original box with all serial numbers
    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
    Got the flash dump, nothing found on DMI section
    No Windows key, just key ID on the box
    What is done:
    1. Flash the latest bios version with serial numbers added (except mac address, dunno where to put it)
    2. Flash the latest bios version without changes
    Changes:
    When 1 and 2 are done I can see the bios window once, and after restart, it has no life, only logo on the screen
    Questions:
    - How to flash the bios without an original dump?
    - Which bios version should I flesh?
    - How to move serial numbers in the correct way, and where is MAC key located?
    - Can someone explain in general what's going on with flashing Asus Ally?
  • Lisa Su
    Badcaps
    • Apr 2021
    • 213
    • Taiwan
    See if this makes difference
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • ujhazi
      ASUS ROG Ally RC71L-NH001W Bios password
      by ujhazi
      Hi
      Is someone, can remove the bios password from the attached bios please?
      sn: R9NVKD00184239B
      Many thanks!...
      12-13-2024, 07:24 AM
