Transistor Testing
  • bobbyskillz
    • 76
    Transistor Testing
    I have an NPN Transistor (c1815gr) that I'm testing on a power board from a Gateway monitor that has 2-seconds to black.
    I get continuity both ways between the emitter and the collector when I use my multimeter on the diode test. After a few seconds the continuity stops and the meter goes to "0L". Does this mean the transistor is bad?
    I don't see any visible defects anywhere on the board. The MOSFETs I checked appear to be good.
    Edit: I tested the transistor with a Fluke 87 multimeter with the transistor still soldered into the board. The board was disconnected and powered down.
  • Joun
    • Jul 2011
    • 191
    • Greece
    Re: Transistor Testing
    There is probably a capacitor in parallel with the pins you are testing.When it reaches fully charge it shows 0L.The only way to be sure about your testing is desolder the transistor and then measure it..
    • retiredcaps
      • Apr 2010
      • 9271
      2 seconds to black can be
      a) bad caps
      b) bad ccfls
      c) bad ccfl wiring (especially the return wiring)
      d) bad secondary windings on the inverter transformer
      More details starting with post #19 at
      https://www.badcaps.net/forum/showthread.php?t=10419
      Also, see budm's Inverter tester using old CFL
      https://www.badcaps.net/forum/showthread.php?t=19987
      Nice multimeter. When testing in circuit, other components could be affecting the measurement.
      I would check out the other things as written above.
      --- begin sig file ---
      --- end sig file ---
      • bobbyskillz
        • 76
        Thanks for the quick replies!
        I printed the 2-Seconds to Black instructions and have them as a guide. I'll desolder the transistor and see how it reads. I also plan on assembling a test CFL. I'll be sure to post back what I find!
        • bobbyskillz
          • 76
          The transistor seemed to test okay. I just have to pull apart a CFL and test it. If that doesn't work, I'll go back to component testing.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Byte_76
            Requesting assistance with 486 motherboard repair
            by Byte_76
            I have a seemingly rare 486 motherboard which shows no signs of life.
            The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
            With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
            I found a thread on Vogons of someone else who had the same board in working condition.
            What I've tried so far: (In each case, the symptoms remain unchanged as...
            04-12-2025, 06:43 AM
          • repair-it
            Need advice testing a samsung power supply board with scope
            by repair-it
            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
            07-12-2025, 11:00 AM
