Viewsonic VE500 monitor
  • aradja2
    • Jul 2012
    • 7
    My monitor would display briefly then go blank. I opened it up and the monitor had an obvious bad cap (C9) and I replaced it. Again, the monitor is a Viewsonic VE500 19", Model # VLCDS23722-1W. It still didn't work; no lights turned on. I decided to replace the other two caps (C12 & C13) just in case they went bad even though they displayed no visible signs of damage. The monitor still remains blank without any lights turning on. I don't know my next plan of action. Any thoughts? Thank you.
    Note- I do have access to an o-scope and DMM.
  • selldoor
    Slow Learner
    • 7870
    Re: Viewsonic VE500 monitor
    We need picture of the power supply board - or does it have external ps.
    Have you checked fuses? / power lead.
    Does it no longer flash briefly when turned on.
    What does the power indicator light do?
    • selldoor
      Slow Learner
      • 7870
      Answering my own questions now! - It is external PS.
      Have you checked the PS - simple voltage check and voltage under load.
      There is a small white smd fuse on the bottom right corner in your pic - check that.
      I attach a service manual which has schematics and troubleshooting guide
      It only has a 15inch panel?
      • aradja2
        • Jul 2012
        • 7
        I'm not sure. There's one board on the right hand side under everything and another on the lower portion under the fancy high voltage metal cage.
        Upon plugging it in, no lights turn on and the display shows nothing. Pressing the power button does nothing.
        • selldoor
          Slow Learner
          • 7870
          Have you checked the external PS - simple voltage check and voltage under load.
          • aradja2
            • Jul 2012
            • 7
            I just checked it and it reports infinite resistance. I'll check the manual for that type of fuse to replace it.
            Thank you for that manual, but the manual schematic does not match the board... Which is extremely odd. Would you happen to have the other version? W2 or W3?
            • selldoor
              Slow Learner
              • 7870
              Fuse is 4A 125V - question is why did it blow?
              Did you put the new caps in the correct way around (Polarity matters) and did you use like for like replacements voltage and capacitance.
              As far as manuals go that is probably as good as it gets - you can trawl the net to try and find a better one. It is not odd that it does not match - in fact it is rare that they do. Its getting late over here so Im off to bed.
              • aradja2
                • Jul 2012
                • 7
                Thank you for all your help!
                Yes, I made sure the replaced caps were in the correct polarity. Same size, capacitance, and voltage. I also replaced the fuse and nothing happened, again.
                • selldoor
                  Slow Learner
                  • 7870
                  Has the fuse blown again or is it still good?
                  I keep asking this and you dont answer?
                  Cant really go on to the next step without an answer.
                  • aradja2
                    • Jul 2012
                    • 7
                    The fuse works fine.
                    Sorry! Yes, the external power supply passes both tests.
                    • selldoor
                      Slow Learner
                      • 7870
                      Ok With it all connected up and "on" put your meter on 200vDC and measure the voltage at the fuse. Put your black lead on the ground screw and use the red to probe each end of the fuse.
                      Next with the Black probe on the ground screw test the voltage at each pin
                      on the two connectors.
                      If the pins are labelled please post results like
                      Pin Label Actual
                      1 12v 12.11v
                      2 5v 4.87v and so on.
                      If they are all under 20v use the 20v scale on the meter to give a more accurate result.
                      There is a voltage regulator at U4 can you post the part number. If you cant read it try and clean it with little isopropyl alcohol on a q-tip
                        by momaka
                        03-15-2023, 10:17 PM
                      • RetroComputingGrotto
                        Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                        by RetroComputingGrotto
                        I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                        I've uploaded a video of it happening on YouTube:
                        I've taken the monitor...
                        01-11-2024, 05:37 AM
                      • ant3202
                        HP 27es - LED monitor - Monitor Flashing On - Off
                        by ant3202
                        Hi Everyone
                        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                        https://www.badcaps.net/forum/troubl...lashing-on-off
                        The monitor is HP 27es LED Monitor
                        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                        The monitor will randomly blackout and display no signal and will recover again.
                        Sometimes need to power and off again to restore the display but...
                        03-20-2025, 07:30 PM
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
                        Wise Wing F199 19'' LCD monitor - recapped
                        by momaka
                        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                        When I saw the Craigslist post, I wasn't...
                        08-24-2020, 10:58 AM
