identifying SMD ceramic capacitor damage
  • Proxyep
    • Nov 2010
    • 14
    I have a few graphics cards (not working) on which the SMD ceramic capacitors appear to be different colors.
    The are mainly brown (like normal SMD ceramic capacitor brown) but others are a dark grey! Thing is on the exact same motherboard revision but another different board the exact same capacitor can be a different color
    Long story short but does the dark grey mean that it has overheated/burnt?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: identifying SMD ceramic capacitor damage
    I've seen brown/tan SMT ceramic capacitors, I've seen grey SMT ceramic capacitors, I've seen white SMT ceramic capacitors ... unused and in bags or on auto-insert tape. When SMT ceramic capacitors short or get leaky, they aren't subtle. They make loud noises, glow brightly and often damage the PCB. Large form-factor SMT monolythic ceramic capacitors are evil, but frustratingly necessary (try finding a 2uF, 600V electrolytic or film capacitor that is just 1 cubic inch in size!).
    So, no, the grey color is not, of itself, a sign that the cap has overheated.
    PeteS in CA
    • b700029
      Banned
      • Sep 2010
      • 640
      As their name suggests, they're made of ceramic. They're fired in a kiln, and the color variation may be dependent on insignificant factors such as how long they were in there for, and small differences in the composition of the ceramic. It's nothing to worry about.
      • aurgathor
        • May 2012
        • 16
        SMD ceramics themselves are fairly reliable, but if they do fail because of spikes or overvoltage, chances are good that something else got fried, too. When they do fail w/o overvoltage, that's often physical because of stress levels, or the failure is caused by other external factors, often related to soldering, etc.
        You could probably test them with a good capacitor tester, but I think the fault lies elsewhere.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          some of those are inductors too.
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • rictechie
            smd ceramic capacitor use in iphones
            by rictechie
            is there a brand of smd ceramic capacitor use in iphones? or they are generics
            07-26-2024, 08:28 PM
          • Doyle1
            BMW OEM Amplifier 9 264 953 – Help Identifying Missing SMD Component
            by Doyle1
            I'm currently working on a BMW OEM amplifier, part number 9 264 953, taken from a 2011 BMW F10 535i.
            There's visible PCB damage near the NXP 74HCT193 chip, where a small SMD component is missing or burned. Based on shape and size, it's most likely a ceramic capacitor or resistor in 0603 package.
            I recovered the loose component (appears unmarked, like a ceramic cap) and have detailed photos:
            – PCB with missing part
            – Close-up of recovered component
            – Full view of the board
            I'm looking for:
            - The correct part...
            05-31-2025, 12:09 PM
