KZG cap bulged sitting in the attic
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    The motherboard is an Intel D845PESV and it was not in use since August 2011, (all the caps were ok at that time).
    Today I opened the PC case to take the speaker and noticed that 1 of the 3 KZGs was in very bad condition.
    I know that during hot summer days the temperature in the attic can reach 43Celsius, but I never could imagine that the electrolyte of KZG would break down by itself.
    Anyway, I recapped with used Rubycon MBZ that I took out from another -dead- Intel D845PESV mobo.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: KZG cap bulged sitting in the attic
    yup, sometimes the forumlas can be so messed up (especially with KGZ series) they can bloat under 85c
    heat by itself CAN bloat a cap with no electricity required too. Get a heatgun, put it on high and aim it at any boards caps, and they will vent thier forumla right there
    • japlytic
      • Oct 2005
      • 2086
      I found that used low-ESR OST capacitors placed in storage (not bulging) did bulge after some time, even though no energy was applied to them.
      Also, I have seen unused Chemi-Con KZJ units bulge after some time.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        I was out of circulation for several years ... did NCC/UCC poo the screwch with the KZG and KZJ series?
        PeteS in CA
        • Rulycat
          • Apr 2010
          • 724
          I believe they used some new iron-based formula which didn't work out. OR something like that.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            PeteS in CA; Yup
            Rulycat; Very interesting, before reading your comment I thought to myself that the crap out of that KZG looks like rust!
            • PeteS in CA
              • Aug 2005
              • 3581
              I would love to learn how something that bad survived UCC's engineering test processes. Test processes should take parts being test through spec'ed conditions and beyond, so the parts' behavior is understood well before the first production parts reach customers.
              PeteS in CA
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Yea it's strange, the ones I've seen like these have been used for years before the failure though.
                So maybe that is the reason, they only realized untill it was already too late?
                • triplefour
                  JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                  by triplefour
                  got this tv from a friend who got a new one and didnt want to bother repairing this one.
                  he said it sometimes would just flash color patterns.
                  and sometimes it would just work
                  i figured it had some intermittent mainboard issue.
                  i stored it at home for a while before looking at it
                  when i plugged it in for the first time, i heard some popping noises
                  and then a big cloud of white smoke came out of the back of the tv!
                  i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                  i unplugged it and took the back off and discovered...
                  12-18-2022, 12:38 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • eccerr0r
                  failing hard drives after sitting for years...
                  by eccerr0r
                  With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                  Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                  Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                  03-02-2023, 10:33 AM
                • roadrash
                  Yamaha HTR-5630RDS AMP sitting down
                  by roadrash
                  I wonder if anyone has any idea what could be causing this to shut down. When you turn it on you hear the relay click and it all lights up. Then about 4-5 seconds later the relay clicks again and it turns off. I have looked carefully at it and checked all connections and it all seems ok.
                  Anyone have a suggestion?...
                  02-06-2023, 08:38 AM
                • SolomonMan
                  Antenna...
                  by SolomonMan
                  All,
                  I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
                  There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
                  Since we moved in, 8 years ago,...
                  10-05-2023, 02:37 PM
