Help with replacement caps
  • Lobo
    • May 2010
    • 59
    I have a PSU pulled from a Primeview monitor, model S1702D. It showed the usual symptoms of bad caps. It would just shut off randomly and more frequently until it finally wouldn't turn on at all.
    So I wasn't surprised when I opened it up and found 4 Evercon capacitors, two of them bulging. I'm still a noob when it comes to cross referencing these things for replacements. I can't find any info on these Evercons, so I need some help.
    Evercon caps are:
    LE
    10v
    1200 uf
    105° C
    E65A
    height 20 mm, width 10 mm
    and
    RE
    25v
    470 uf
    105° C
    E63A
    height 15 mm, width 10 mm
    please point me in the right direction
  • mariushm
    • May 2011
    • 3799
    Re: Help with replacement caps
    le:
    re:
    evercon = gsc afaik...
    replace with capacitors that are of higher ripple, lower impedance ... making sure they fit in the room of the old caps... height can be higher.
    you're probably in us ... based on your patriot viper rams (afaik only sold in us) so check digikey.com , rs-components.com, mouser.com etc
    • retiredcaps
      • Apr 2010
      • 9271
      Search is your friend "evercon capacitor datasheet" 1st hit.
      https://www.badcaps.net/forum/showthread.php?t=12395
      --- begin sig file ---
      --- end sig file ---
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Yup.
        GSC = Evercon = Sacon
        They were so bad they kept changing their name.
        They seem to be gone now but they might be hiding under a 4th name.
        Mann-Made Global Warming.
        - Dr Seuss
        • Lobo
          • May 2010
          • 59
          Wow you guys are quick. hehe
          So am I safe to assume that the GSC datasheets can be used for these? I'll see what I can find and maybe you can tell me if I'm right, wrong, or even close.
          How about these http://search.digikey.com/us/en/prod...2388-ND/613749
          and these http://search.digikey.com/us/en/prod...2355-ND/613716
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yes
            Make sure the can size is the same.
            Sometimes they made sizes that aren't in the data sheet.
            'Within a Series' the ESR and Ripple change with the can size so if you run into that use the closest cap with the same sized can.
            They are also unusually sloppy with their can sizes.
            I've seen the height vary as much as 4mm for the same size/series cap on the same board.
            - Dr Seuss
            • Lobo
              • May 2010
              • 59
              Originally posted by PCBONEZ
              Yes
              Thanks for the tips, I'll take that into consideration.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                These would work just fine:
                https://www.badcaps.net/store/produc...products_id=42
                and
                https://www.badcaps.net/store/produc...roducts_id=157
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Lobo
                  • May 2010
                  • 59
                  ooh thanks!
                  Glad I waited to order.
