Do you got Evercon datasheets ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I got a new project - a Dlink DGL 4300 with low quality caps and I want to replace all of them.
    I got datasheets for the Taepos and CapXon but not for the Evercons.
    Evercon 470µ 25V 1Stk 105 E60A 10x12
    Evercon 100µ 16V 5stk 105 E69B 6x8
    Evercon 100µ 16V 1stk 105 E69F 6x11
    Starting with the 470uF Evercon
    100uF 6x8
    100uF 6x11
    Do you get datasheets for these ? can you send them to me ?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    Re: Do you got Evercon datasheets ?
    Unfortunately the Evercon website has been inactive for some time, so downloading the datasheets there is not possible.
    I have checked on WebArchive and can't find anything there either.
    Someone should be able to suggest a good series to replace those capacitors with, though.
    -David VanHorn
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Yes I noticed that - tried to google for their datasheets but had no go.
      I also had a look at The Wayback Machine - could not find anything.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        Apparently GSC, Evercon, Sacon, Capsun, Samwha, SamYoung.. are all the same thing
        However, the series names are different for each brand, so while one of the datasheets from the other brand should be a match, you don't know which one.
        -David VanHorn
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          samyoung is gsc?
          i have a board with samyoung... better recap it!
          sigpic
          (Insert witty quote here)
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            samyoung is gsc?
            According to what PCBONEZ found, yes
            (https://www.badcaps.net/forum/showthread.php?t=4341)
            -David VanHorn
            • bigbeark
              • Jan 2010
              • 661
              Even if you could find datasheets, would you believe them? These guys produce
              crappy caps in non-standard can sizes. I would think Panasonic FM, or Panasonic FC, or Ruby MBZ or MCZ, or almost any general purpose 105C cap from any of the major manufacturers would be a huge improvement over any Evercon/GSC or whatever they call themselves now.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5085
                • New Zealand
                You don't have to believe them.
                If the manufacturer (In this case, D-Link) believed them, then they would be chosen to fit the circuit design.
                Therefore, any decent capacitor matching the specifications (or better) should work just fine, as those are the specifications the D-Link engineers would have been expecting of the capacitors.
                -David VanHorn
                • mockingbird
                  • Dec 2008
                  • 5488
                  Now that we're on the topic of this defunct manufacturer, I have a "GSC" cap, which uses a similar namesake to this Evercon cap, and I would love to know it's official specification:
                  "E5NK", 16V 470uF.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5085
                    • New Zealand
                    I would love to know too.. But I've looked and looked and I just can't find a damn thing
                    -David VanHorn
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5085
                      • New Zealand
                      Well, I have managed to find these datasheets for the GSC LE and RE series. Not sure it helps anyone though...
                      -David VanHorn
                      • Gabriel
                        • Jan 2010
                        • 620
                        • Norway
                        Anyone know what series the Evercons are ?
                        E69B, E60A are date codes right ?
                        @Agent24
                        Those Gsc datasheets I will keep for future problems - Thanks
                        • mockingbird
                          • Dec 2008
                          • 5488
                          How can I check if my GSC cap is non-polar? I'm asking because I find two interesting references to an "NK" series capacitor one from Capxon and one from Jamicon, both of which are non polarized.
                          Is it possible to have a non-polar capacitor on a motherboard? Maybe for the sound subsystem? Though it is right next to the PCIe x16 port.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Not likely. All i've seen have a large NP printed on them, and are significantly larger than a polarized cap of the same value (that's normal since they are two caps in one).
                            A working TV? How boring!
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              samyoung is gsc?
                              No
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • mockingbird
                                • Dec 2008
                                • 5488
                                You're right. The dimensions are wrong. The Capxon NK is 10x16 and the Jamicon is 12.5x25. Mine is 8x11.5.
                                But still I can't help but wonder, the 330uF 6.3 Capxon NK is 8x11.5. If I had the datasheet for this motherboard, would it indicate whether a bipolar cap should be placed there?
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  No
                                  GSC=Evercon=Sacon
                                  Not a manufacturer, just a distributor.
                                  They had their caps made elsewhere and had their name put on them.
                                  Capsun was their OEM supplier. [The actual manufacturer.]
                                  Capsun supplies some other CH & TW brands as the OEM. [I think including some OST.]
                                  SamYoung is Korean and not related to them other than distribution.
                                  Samwha is also not related to them other than distribution.
                                  Joint ventures are usually just distribution networks.
                                  They don't make each others caps but they sell each others caps.
                                  - Dr Seuss
                                  • mockingbird
                                    • Dec 2008
                                    • 5488
                                    You think Capsun might have the spec sheets?
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      The purpose of non-polar caps is to be able to take full rated voltage in either direction.
                                      I haven't seen a situation on a mobo that needed that but that doesn't mean none exist.
                                      If you can draw out the schematic for that section you should be able to figure out if the polarity can change direction.
                                      If it can't then you don't need a non-polar cap.
                                      - Dr Seuss
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Maybe.
                                        I'll find the link. It isn't straight forward.
                                        - Dr Seuss
                                        • Ady2017
                                          Are there any datasheets available for Elna RJG capacitors?
                                          by Ady2017
                                          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                          05-25-2025, 02:19 PM
                                        • CdDvdFlash
                                          Please teach me how to find datasheets to obsolete caps
                                          by CdDvdFlash
                                          I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
                                          (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
                                          08-12-2023, 12:29 PM
                                        • Tomek188
                                          Looking for datasheets for EN7521 and MT7520
                                          by Tomek188
                                          I need datasheets for EN7521 and MT7520 (similiar chips). This is GPON ONT.​
                                          01-17-2025, 01:47 PM
                                        • petehall347
                                          100nf and 100uf precision capacitors
                                          by petehall347
                                          i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
                                          08-13-2024, 06:56 AM
                                        • ten-d
                                          Nippon Chemi-con 100uf 100v BP electrolytic cap
                                          by ten-d
                                          Hi all!
                                          I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                                          01-30-2024, 05:18 PM
