Wondering how common this is???
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I have an A-Open motherboard (Socket 478) that is in my Linux box. I checked the caps on it, and it has a combination of KZG, Panasonic, G-Luxon, Sanyo, and OST. They don't normally have that much variety do they? Luckily the CPU's main caps are Panasonic
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Wondering how common this is???
    It is not unusual to see 6 or more different brands of caps.
    --- begin sig file ---
    --- end sig file ---
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Wow really? That is cool. I'm used to seeing 1 or 2 in my motherboards
      • retiredcaps
        • Apr 2010
        • 9271
        Wow really?
        A recent example.
        https://www.badcaps.net/forum/showthread.php?p=193827
        More if you count the polys.
        • mariushm
          • May 2011
          • 3799
          I have a video card in front of me that has four brands of capacitors... so no, not surprised seeing so many on motherboards.
          ps... and it's a Gigabyte video card... GSC, Teapo, Nichicon HM and some polymers.. at least they're grouped by capacity... probably bought in large volumes.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Okay, I still have a lot to learn about caps, I'm just trying to get as much knowledge as I can Your poor card has GSC....ouch
            • BigPete
              Panasonic Heatpump Dryer Repair
              by BigPete
              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
              Unfortunately the whole machine has to come apart to fix it.
              I have...
              11-01-2025, 06:40 PM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
