Wondering how common this is???
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I have an A-Open motherboard (Socket 478) that is in my Linux box. I checked the caps on it, and it has a combination of KZG, Panasonic, G-Luxon, Sanyo, and OST. They don't normally have that much variety do they? Luckily the CPU's main caps are Panasonic
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Wondering how common this is???
    It is not unusual to see 6 or more different brands of caps.
    --- begin sig file ---
    --- end sig file ---
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Wow really? That is cool. I'm used to seeing 1 or 2 in my motherboards
      • retiredcaps
        • Apr 2010
        • 9271
        Wow really?
        A recent example.
        https://www.badcaps.net/forum/showthread.php?p=193827
        More if you count the polys.
        • mariushm
          • May 2011
          • 3799
          I have a video card in front of me that has four brands of capacitors... so no, not surprised seeing so many on motherboards.
          ps... and it's a Gigabyte video card... GSC, Teapo, Nichicon HM and some polymers.. at least they're grouped by capacity... probably bought in large volumes.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Okay, I still have a lot to learn about caps, I'm just trying to get as much knowledge as I can Your poor card has GSC....ouch
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
            • J_T
              Operating frequency for motherboard common mode inductor/filter
              by J_T
              I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
              The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
              Sorry, I am not experienced hence a basic question.
              01-04-2025, 05:54 AM
