OSCON go BOOM!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    OSCON go BOOM!
    Who says Solid Polymers don't fail?
    So, the story..
    I set up a dual Xeon skt 771 board on the workbench with one CPU to test some FB-DIMMs.
    All the parts involved have been tested before but as the RAM is going into a final build I wanted to test it again.
    First booted into the BIOS to check settings.
    Clicked save but on restart Memtest [on a USB stick] didn't 'catch' and run.
    Not usual for boot from USB to 'miss' on this particular board when doing a hot-restart.
    For some reason this board only checks for USB-bootable on cold restarts.
    - So I fully power down and reboot.
    Comes up and memtest is loading then...
    POW!! HISSSSsssssssss SMOKE!! - TURN IT OFF! - TURN IT OFF!
    LOUD pop followed by the sound of escaping gas and a large puff of NASTY smelling black smoke.
    I didn't see -exactly- where it came from.
    At first I thought the south-bridge but here is no sign of a problem there.
    Upon closer inspection one of the OSCON's [Vcore for the socket with NO CPU installed] is much 'taller' than it used to and the 'legs' are longer than they used to be.
    Looks like the can tried to play missile leaving the 'guts' of the cap on the legs,, but the bung did not 'let go',, so my guess it vented along the path were one of the legs passes through the bung.
    I haven't pulled the cap yet but I did get a couple snap-shots for your entertainment.
    Mann-Made Global Warming.
    - Dr Seuss
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: OSCON go BOOM!
    Hmm, very interesting
    One possible reason could be that with no CPU installed there was a fault in the CPU VCore regulator, since it got no feedback it could in theory increase the VCore indefinitely, all the way up to 12v, which would of course cook the 4v OSCONs.
    I don't have any valid reason to think _why_ it would do that, especially on a multi CPU board (I presume) where it really must be taken into the design that a CPU slot might be unpopulated...
    Only reason I'm entertaining the thought is I know what happens to a CPU when you volt-mod a mainboard to gain more voltage and mistakenly put the variable resistor at min value when you infact where meaning to put it at max, oh those poor Athlon XP CPU's
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: OSCON go BOOM!
      I think it's just a random cap failure.
      Yes. Board is designed for single or dual operation.
      Previously ran with Dual CPUs in actual service.
      Vcore voltage was fine.
      Gives audible alarm if not and that didn't happen.
      The board has a lot of built-in over-kill.
      Has third [different] VRM just for the RAM.
      Not like any one Vcore cap is heavily loaded.
      There are 38 of them [all OSCONs] in Vcore [19 per CPU].
      That's at least double what is seen on consumer boards with comparable CPUs.
      Point of posting is that -ANY- kind/brand of cap can fail on occasion.
      Even Solid Polymer -and- even OSCON.
      - Dr Seuss
      • Toasty
        • Jul 2007
        • 4171
        Re: OSCON go BOOM!
        Fallout from Japan....
        Gonna pull the ones to either side to see? Closest to CPU/heat related?
        veritas odium parit
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: OSCON go BOOM!
          Oh it's a good 2+ inches from the CPU.
          It's by the empty socket.
          Pulled bum cap and the board runs fine now.
          I'll just leave it out and use single CPU until I can get a matching cap.
          [Gotta keep the VRM color coordinated. They run better like that.]
          Not sure if this one has that audible alarm as I thought.
          As I recall the BIOS had a setting but I looked and it's not there.
          That might have been in an older rev of the BIOS and now it's not there.
          Pics of the pulled cap & empty spot attached.
          Can see where the smoke left a 'jet blast' mark and a smoke trail on the board.
          [Trail is between the two caps in back. Couldn't get enough light in there.]
          Looks like the leak started at the leg like I thought.
          Not sure if the split happened from the failure or from removal [RoHS solder and that one came out like pulling a tooth] so I may have caused the split after the fact.
          I don't -think- I pulled that hard, but?
          - Dr Seuss
          • Toasty
            • Jul 2007
            • 4171
            Re: OSCON go BOOM!
            [Gotta keep the VRM color coordinated. They run better like that.]<<
            lol
            I'll put 2 out in the mail tomorrow.
            veritas odium parit
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: OSCON go BOOM!
              Thank you!
              - Dr Seuss
              • TheLaw
                • Jan 2011
                • 477
                Re: OSCON go BOOM!
                oscon? OSCON? OSCON?
                Of any of the polymer manufacturers to experience a failure with, Sanyo Oscon is the one I'd be sure that wouldn't blow.
                That's really quite strange. I regard them as some of the best. I guess nothing is perfect though.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: OSCON go BOOM!
                  If you build a few million of something a year there's bound to be a few that don't come out just right.
                  - Dr Seuss
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: OSCON go BOOM!
                    i once got a panasonic fm with the jacket on wrong.long lead was on the neg stripe side.
                    wonder if that is what happened here?mismark?
                    • TheLaw
                      • Jan 2011
                      • 477
                      Re: OSCON go BOOM!
                      Don't think it would have been working for such a long time like that.
                      • TBoneit
                        • Jun 2010
                        • 70
                        Re: OSCON go BOOM!
                        Showing his ignorance he asks, Polys have polarity?
                        They're new to me since I was in electronics school. Then we had Electrolytics, Mica, & paper. Not to mention the variable capacitor for tuning the radio.
                        Of course back then a common voltage rating might be 400volt for filtering the B+ supply.
                        I even remember seeing some really old radios where the electrolytics were the wet type
                        "Mershon's solution was to simply fit the capacitor into an oversize aluminum or copper can, half-filled with extra electrolyte. These units are referred to as "wet electrolytics,"
                        • Wizard
                          • Mar 2008
                          • 2296
                          Re: OSCON go BOOM!
                          That kind of surprises bound to happen even with best one.
                          Electrolytic is really a 'wet' not in sense if it even is water based, the electrolyte can be any kind of formulations not just mixed with water.
                          Cheers, Wizard
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: OSCON go BOOM!
                            Yes
                            The half moon spot of color on the top [or sometimes it's a rectangle/stripe in the same place] marks the negative lead.
                            - Dr Seuss
                            • Toasty
                              • Jul 2007
                              • 4171
                              Re: OSCON go BOOM!
                              Get the caps yet PC ?
                              veritas odium parit
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: OSCON go BOOM!
                                No Sir, not yet.
                                Not a big deal though.
                                It will be like next week before I have time to do anything with that board again anyway.
                                - Dr Seuss
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  Re: OSCON go BOOM!
                                  Wow! These have been 'in the wind' for a week, and I stuck more than enough stamps on it too.
                                  veritas odium parit
                                  • TBoneit
                                    • Jun 2010
                                    • 70
                                    Re: OSCON go BOOM!
                                    Originally posted by PCBONEZ
                                    Yes
                                    What happens if they are reversed? Do they catastrophically fail like a Electroylitic does?
                                    RT
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: OSCON go BOOM!
                                      I would imagine so.
                                      They are still electrolytic and still work by [and are polarized because] they have an oxide layer on the anode foil.
                                      The oxide layer is the actual dielectric.
                                      Sending electrons through the wrong way erodes [thins] the oxide layer and will ultimately cause the cap to short internally.
                                      - Dr Seuss
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        Re: OSCON go BOOM!
                                        polys will explode violently when polarized wrong. been there done that
                                        no vent on top for the gases to get out.. so it'll blow the whole can across the room like a projectile (and you're usually left with the rubber bung and a tower of rolled cap innards on the board.. nasty stuff)
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
                                        • Francisco.s
                                          CPU vcore missing in HP workstation Z2 Mini 4G
                                          by Francisco.s
                                          Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                                          The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                                          It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                                          Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                                          The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                                          I wonder which circuit generates this enable...
                                          04-22-2024, 12:35 PM
                                        • mikzs
                                          Rx580 8gb sapphire nitro+ turn off vcore randomly
                                          by mikzs
                                          Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
                                          11-06-2023, 12:28 PM
                                        • jm942
                                          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                          by jm942
                                          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                          I did voltage injection on the cpu with 0.7V and i have a current...
                                          07-11-2024, 05:11 AM
                                        • conghuyms
                                          MSI RX580 Vcore voltage is too high, please help me !!!
                                          by conghuyms
                                          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
                                          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
                                          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
                                          What should I do...
                                          08-02-2025, 11:38 PM
