Looking for a good substitute
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Looking for a good substitute
    I still would leave the VRM alone. fujitsu polys and panny lytics are fine. i left mine alone (the lytics were rubies on my board), and it has been 100% stable running 24/7 for about 6 months.
    not saying you couldn't poly mod, but that there is less to gain since you can't OC these.
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      The board in the picture is not v b chil-n's board. It has rubycons on the vrm and they are vented.
      Originally posted by v b chil-n
      My HP board has two failed caps near the cpu socket. They are rubycon 6.3v 1800uf MCZ...
      • v b chil-n
        • Dec 2005
        • 32
        Sorry I've been MIA, thanks again for all the great info and suggestions guys, once I free up some time I'll be recapping this thing, for now my cell phone will have to serve as my home computer.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Originally posted by c_hegge
          The yellow ones are actually polys. The reason for replacing them is because if they are different, you will be putting more load on some caps than others, so replacing them all is a good way of evenly distributing the load.
          I'm with Ratdude on this one. Leave the yellow Fujitsu caps, and if the VRM has Panasonic caps, you can leave those alone as well. The Rubycon MCZ, however, should be changed.
          Now that you mentioned this, I remember that the only pattern I saw in those DC5000 and D530 computers is that the ones that had Panasonic caps in the VRM did not have a single Panasonic cap fail. On the other had, the Rubycon MCZs had quite a few failures in the VRM. Sometimes I'd see failed Rubycon MCZ in VRM and near the memory slots, but the Teapo and Ost next to them were fine. I'm not dissing on Rubycon quality or anything like that, but rather I want to point out again that the only caps that had a 100% survival rate among the electrolytics were the Panasonic caps. Everything else was hit-and-miss. Too bad VRM was the only place with Panasonic caps.
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
            by momaka
            03-15-2023, 10:17 PM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • irepair559
            Ps4 1215a hdmi diode readings good everything good but no pic??
            by irepair559
            PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
            01-05-2023, 12:32 AM
          • DXseekerMO
            Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
            by DXseekerMO
            Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
            If anyone has a link to where I can buy what I need that would be even better.
            These are the caps that have burst:
            Board location: C8BV, C26BV, C43BV
            Brand: United Chemi Con
            Series: KZG
            Size: 10mm dia X 25mm height
            Impedance: (ohms max/20c, 100kHz) .012
            Ripple: 2800...
            02-04-2022, 04:48 PM
