Heres the deal.
  • TheLaw
    • Jan 2011
    • 477
    #61
    Re: Heres the deal.
    Originally posted by Pyr0Beast
    Eh. Poor stuff makes you want to give up on what you do.
    It is sad to see people use cheap-shit irons, had to sand down the tip to make solder adhere to it. And afterwards it was moderately good to use.
    But compared to 45W weller ... It is junk.
    Also. Spending 20$ on an iron and then 40$ on a new one is throwing those 20$ away or buying 40$ iron for 60$ ...
    Waaaste of money ...
    This
    • marinesman215
      • Feb 2011
      • 33
      #62
      Re: Heres the deal.
      Hey guys.. real quick.. I placed the order a couple days ago.. then today i noticed on one of the caps i bought its a radiall cap.. the other two were FC SMD's this one is FC Radial... Did I order the wrong one....?
      • steve2
        • 121
        #63
        Re: Heres the deal.
        Those should have all been radial, thru hole (as they go through the board). The SMD's mount on the surface.
        • TheLaw
          • Jan 2011
          • 477
          #64
          Re: Heres the deal.
          Yes all through hole...and radial.
          • marinesman215
            • Feb 2011
            • 33
            #65
            Re: Heres the deal.
            God damn it.. Thanks guys..
            • marinesman215
              • Feb 2011
              • 33
              #66
              Re: Heres the deal.
              I'm looking up the ones I'll need to replace... When I find them.. If you guys could just double check.. That would be great...
              • marinesman215
                • Feb 2011
                • 33
                #67
                Re: Heres the deal.
                I talked to a classmate in my Computer Science Class about soldering, he said something about demagnetizing the caps.. and I think I'm way over my head here.. In the videos I watch about soldering and desoldering I never heard or seen anything about what he was talking about..
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  Re: Heres the deal.
                  He probably meant discharging caps. The big main filter capacitor could hold a charge and you want to discharge it first.
                  Most modern lcd/tvs have a bleeder resistor and that discharges the big main capacitor after the power has been removed and unplugged in about 1 or 2 minutes.
                  You can verify if the big cap has been discharged by measuring its DC voltage with a multimeter.
                  --- begin sig file ---
                  --- end sig file ---
                  • marinesman215
                    • Feb 2011
                    • 33
                    #69
                    Re: Heres the deal.
                    Hey guys, like I mentioned before... I ordered the wrong one.. then just yesterday ordered the correct ones.. Anyways.. I desolder and soldered 4 of them I needed to replace... I must say its not all that hard (had I better experience and tools I wouldnt have been as sloppy im sure) Other then getting random drops of solder on the board..... it went pretty seemlessly. Now, it is a bit sloppy and if request is needed i can upload pics of it, but will some solder on the board in spots that serve no purpose mess things up.. its not globs of solder but kinda a smeared type of deal.... Thanks again guys for making this possible.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #70
                      Re: Heres the deal.
                      So what's the outcome? Or are you still waiting on the caps and just practiced on the old ones.
                      A working TV? How boring!
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        Re: Heres the deal.
                        this kinda sounds like your solder is without a flux core..
                        • marinesman215
                          • Feb 2011
                          • 33
                          #72
                          Re: Heres the deal.
                          Hey guys! Sorry the rest of the parts just came two days ago.. been busy and just finished putting everythign on today.. put it all back together, and what do you know... IT WORKS! You guys are the best... 40 bucks and two solder burns later i got a TV, and learned a hell of a lot along the way which was worth much more than 40$, you guys have been a great help! Thanks a lot!!!
                          • steve2
                            • 121
                            #73
                            Re: Heres the deal.
                            Congrats on your first fix. Your already ahead of most of the Jarheads. Just kidding. Have fun with it and good luck with ROTC.
                            • marinesman215
                              • Feb 2011
                              • 33
                              #74
                              Re: Heres the deal.
                              This week has been amazing, on Monday I got accepted to The Citadel, and on Tuesday I got the TV to work! And thanks I appreciate it!
                              • xfreaksus@gmail.com
                                Need schematic for Ayaneo Geek (black edition)
                                by xfreaksus@gmail.com
                                Hi, anyone here have information of ayaneo geek (black edition) schematic? thanks
                                08-11-2025, 03:50 AM
                              • capwizard
                                How to deal with huge LCD screen when we are replacing the TV LED backlight?
                                by capwizard
                                Does anyone have a better way to deal with 70-inch TV or above LCD screens which are very easy to break when we change the LED backlight?
                                I'd broken 10 TV screens already.
                                One of my friend has 75 inch edge TV with one LED not working. I said : just leave it alone.
                                Is there a better way to ensure that the LED TV screen will not break? I need 100%. I can't afford the Robot either.
                                01-29-2019, 10:11 AM
                              • reformatt
                                Macbook display shortage in China?
                                by reformatt
                                Aftermarket screen prices have jumped for all Apple laptop display assemblies recently. I got something in Chinglish from a supplier on Whatsapp:
                                Latest news on supply of Macbook screen with top covers
                                1. Industry inside news: macbook screen with top covers with logo won't be restocked in the short term. The product selling now are all from the factories existing inventory. No factory will dare to produce new products in the short term. First come, first served.
                                2. The supply of Macbook LCD only is normal and will not be affected by this goverment interview...
                                11-04-2025, 06:11 PM
                              • gleniu
                                Lenovo IdeaPad Gaming 3 15ACH6 - no power
                                by gleniu
                                Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                                10-27-2025, 01:13 PM
                              • AustinCER
                                Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                by AustinCER
                                Hello, I currently have a Dell XPS 8940 in our office for repair.
                                Service Tag: HG1Y673
                                The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                07-15-2025, 05:28 PM
