I have an Antec SP-350 in my computer and heard it was responsible for many mobo deaths. Is there a good cheap PS I can buy?
New PS
Re: New PS
And yes, one of my friend's motherboard was fried due to the Antec SP-350 5V STB rail failing high (around 11V DC).--- begin sig file ---
--- end sig file ---Comment
Re: New PS
Depending on how cheap you consider to be affordable, one of my favourittes is the corsair VX450. It has entirely Japanese caps, and is one of the best out there. Personally, I consider Antec StupidPowers (Smartpower) and early TruePowers to be worse (ie. less reliable) than even the really cheap and nasty brands, like low end deer, powmax/leadman, sun pro and linkworld. They are the only PSUs I've seen with a 100% premature failure rate.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Re: New PS
Smartpowers aren't even ATX2 speced I don't think.Comment
Re: New PS
The VX450 is indeed a solid supply, but if you need cheaper, I'd recommend an Antec NEO ECO which is a Seasonic S12II based power supply, exclusively available on Newegg.com. No, it's not sketchy at all. It's a sold supply.
The VX450 is a bit old at this point. There are some better designs out there, but reliability wise, it's top notch. But you won't have problems with the Antec either.Comment
Re: New PS
What a good selection! Thanks to all of your excellent advice, I have decided to go with the VX450W from Amazon.
This review helped more than a little.Comment
Re: New PS
I've only heard of one case where a smart power caused a house to burn down.
They must be safe.Mann-Made Global Warming.
- Dr Seuss
- Dr Seuss
Re: New PS
It nearly happened to one of our customers. Several years ago (before I worked where I do), my boss used to use antec PSUs in new systems. One customer's SP-350 once gave off a heap of smoke, caucht on fire inside and and exploded big time when they attempted to power their PC on. Remarkably, the only thing to get antec'd was the motherboard.I love putting bad caps and flat batteries in fire and watching them explode!!
Re: New PS
When I say premature failure, I mean one that occurs before the PC is obsolete and due for retirement. I consider that to be around 7 years, but 5 years is a record for an antec stupidpower. I've known them to fail as early as 6 months given heavy usage.I love putting bad caps and flat batteries in fire and watching them explode!!
Re: New PS
According to Intel the useful life of a PC is 7 years.
[That's from their marketing side.]Mann-Made Global Warming.
- Dr Seuss
Re: New PS
Don't want to rain on your parade, but...
CompUSA has it for $39.99 after a $15 rebate.
Toastveritas odium paritComment
Re: New PS
OH!
That's a rain hat!
I thought it was a helmet!
- Dr Seuss
Re: New PS
If you decide to recap the Antec SP-350, here is the thread giving some helpful information, especially how to do the DM311 mod to prevent overvoltage problems with the 5vsb circuit.
https://www.badcaps.net/forum/showth...hlight=everellOld proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by CerberuskaHello guys,
I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
BIOS I updated to last one.
any suggestions?
And same thing for two different 5600G, and yes, MoBo supposed to support it.
Thank you...1 Photo -
by IbodHI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
Not sure where to go from here ?
Is the PSU at fault or is the mobo causing the problem
Look forward to any help :-)
If I plug the 24... -
Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
So I got this Dell Inspiron to play with.
No charger, so I connected to my bench PSU.
The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
------What it did (and didn't do)------
1) I turned it on and it powered on. Powered down in 2 seconds by itself.
2) Removed RAM, changed slot. Same... -
by tartufGreetings
My old 350W FSP-350GLN(80) PSU was working fine with my current computer for few years(and previously with few other computers as well). Nothing has changed in setup but since last few months I am getting problems while trying to boot PC.
What happens, is that PSU starts and I can hear fans, both PSU, CPU, MOBO and GPU. I can also hear HDD scratching and normal starting sounds. But DVI monitor claims that there is "no signal". Moreover, neither USB mouse nor PS2 keyboard does flash leds like it should do upon boot.
I have to turn PSU switch... - Loading...
