New PS
    New PS
    I have an Antec SP-350 in my computer and heard it was responsible for many mobo deaths. Is there a good cheap PS I can buy?
    Re: New PS
    How cheap is cheap?
      Re: New PS
      Search this board for posts by everell and his DM311 mod.
      And yes, one of my friend's motherboard was fried due to the Antec SP-350 5V STB rail failing high (around 11V DC).
      --- begin sig file ---
      --- end sig file ---
        Re: New PS
        Depending on how cheap you consider to be affordable, one of my favourittes is the corsair VX450. It has entirely Japanese caps, and is one of the best out there. Personally, I consider Antec StupidPowers (Smartpower) and early TruePowers to be worse (ie. less reliable) than even the really cheap and nasty brands, like low end deer, powmax/leadman, sun pro and linkworld. They are the only PSUs I've seen with a 100% premature failure rate.
          Re: New PS
          Define "Premature Failure Rate" Mine still works after 2-3 years of light usage. Cheap means > $50 but better to spend money on a PS than money on rebuilding my entire system. I will check out the corsair VX450 Thank you .
            Re: New PS
            Nono...Antec TruePowers are definitley not worse than Leadman/Deers. True they are filled with Chemi-Con KZGs, but I doubt the Fuijiyus in the Leadmans are any better. Soldering quality and overall construction quality is much better, even if the caps might not be as good as the rest.
            Smartpowers aren't even ATX2 speced I don't think.
              Re: New PS
              The VX450 is indeed a solid supply, but if you need cheaper, I'd recommend an Antec NEO ECO which is a Seasonic S12II based power supply, exclusively available on Newegg.com. No, it's not sketchy at all. It's a sold supply.
              The VX450 is a bit old at this point. There are some better designs out there, but reliability wise, it's top notch. But you won't have problems with the Antec either.
                Re: New PS
                They are now, but the earlier ones had Fuhjyyu and 100% premature failure rates.
                  Re: New PS
                  Ohhh...yes, sorry. Those wretched first gen Truepowers. Yes, those were dismal units. Can't believe Antec let those off the assembly line.
                    Re: New PS
                    What a good selection! Thanks to all of your excellent advice, I have decided to go with the VX450W from Amazon.
                    This review helped more than a little.
                      Re: New PS
                      I've only heard of one case where a smart power caused a house to burn down.
                      They must be safe.
                      Mann-Made Global Warming.
                      - Dr Seuss
                        Re: New PS
                        Not exactly limited to 'first gen'.
                        TP, TP2, TP3, True Blue, and a few other 'True' -whatever- all had the same problems.
                        - Dr Seuss
                          Re: New PS
                          It nearly happened to one of our customers. Several years ago (before I worked where I do), my boss used to use antec PSUs in new systems. One customer's SP-350 once gave off a heap of smoke, caucht on fire inside and and exploded big time when they attempted to power their PC on. Remarkably, the only thing to get antec'd was the motherboard.
                            Re: New PS
                            When I say premature failure, I mean one that occurs before the PC is obsolete and due for retirement. I consider that to be around 7 years, but 5 years is a record for an antec stupidpower. I've known them to fail as early as 6 months given heavy usage.
                              Re: New PS
                              According to Intel the useful life of a PC is 7 years.
                              [That's from their marketing side.]
                              - Dr Seuss
                                Re: New PS
                                Don't want to rain on your parade, but...
                                CompUSA has it for $39.99 after a $15 rebate.
                                Toast
                                veritas odium parit
                                  Re: New PS
                                  OH!
                                  That's a rain hat!
                                  I thought it was a helmet!
                                  - Dr Seuss
                                    Re: New PS
                                    Oh, been into the strong coffee this morning, eh?
                                    It's tin foil lined to prevent "them" from reading my thoughts.
                                    veritas odium parit
                                      Re: New PS
                                      If you decide to recap the Antec SP-350, here is the thread giving some helpful information, especially how to do the DM311 mod to prevent overvoltage problems with the 5vsb circuit.
                                      https://www.badcaps.net/forum/showth...hlight=everell
                                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                        Re: New PS
                                        Toast
                                        As a member of Amazon Prime, the shipping is worth it, especially since I would like to use my computer and not think of the PSU as a $400 rupoor.
