How do you guys hold your boards?
  • Uno
    • Jan 2011
    New here, and interested in re-capping iMac MLB.
    I'm gonna try to recap an iMac G5 20inch, leaking/bulging caps.
    I'm just curious on how you guys handle your motherboards while de-soldering.. one hand for the iron, another with the sucker, but what do you guys use to hold up the board?
    Thanks.
  • c_hegge
    • Sep 2009
    • 5219
    Re: How do you guys hold your boards?
    I usually use one hand for the iron, the other for the cap, forget the solder sucker and hold the board in my legs. Probably not the best idea, but it works.
    • bigbeark
      • Jan 2010
      • 661
      I made a frame from spruce strapping, using screws and glue for a solid job. I attach the board to the frame using wood screws through the board mount holes. I then use a large spring clamp to clamp the frame to the work table so that the board is held perpendicular to the work table.That way I have both hands free and the board is held solidly in position.
      I may have to reposition the board on the frame to get access to caps that are close to the edges of the board.
      Since I use the pin method, I can "tack" the caps to the board while it's in the vertical position. After I have attached all the caps, I remove the board from the frame, flip it over and properly finish all the solder joints. The caps stay in position and I get a tidy-looking job.
      To finish, I trim the "legs" to a shorter height.
      • Uno
        • Jan 2011
        I guess I'll use my legs, I was hoping there were large clamps for mobo.. I see allot of little helping hands for small boards..
        If I have extra time and supplies I'll try to build my own.
        BTW Happy New Year!
        • Trinite
          • Dec 2010
          • 143
          I solved the dilema by getting a desoldering iron. Frees up my other had to hold the board.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            i use wood clamps
            can see about half way down the page
            http://www.capacitorlab.com/replacin...owto/index.htm
            works nice for me.
            • yyonline
              • Jul 2009
              • 692
              My dad used to do circuit board assembly as a side job. So I inherited a 30-year old this:
              http://www.panavise.com/index.html?p...eqskudatarq=26
              It works well for 95% of boards. For those that are oddly shaped, i usually just put them between two cardboard boxes.
              • severach
                • Aug 2007
                • 1055
                Harbor Freight Item 46808 18" Padded Ratchet Bar Clamp or any equivalent from any other company. Contrary to what you might think, the *longer* bars are better. I have two and have yet to find anything that just one can't hold. After using one of these I can't think of any way a board vice at any price could even match it.
                I also solder with a desoldering tip to eliminate the solder hand. Once you get used to solder tips with holes in the center, everything else is second best.
                sig files are for morons
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Larger motherboards I lay on the bench, they are easy to hold in place and work on. When using my SS pick, I keep the board immobile with the heel of my left hand, and use my left hand fingers to work the pick. Iron in my right hand of course. Smaller boards, I have a device like yyonline posted. The smaller ones can be tricky to hold in place and solder/desolder on.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Originally posted by willawake
                    i use wood clamps
                    works nice for me.
                    I'm having a hard time finding the glass with the giant sheep on it at any of our local electronics stores. Where'd ya find yours? I tried using a regular glass, but it didn't work quite as well.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      lol. i dont have that glass no more.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        me too but imacs are the worst to recap... not sure if a 45W desoldering iron would do it. maybe if you took the iron part off and put a beefier iron on... the imac bards have heavy heat-sucking ground planes...
                        sigpic
                        (Insert witty quote here)
                        • severach
                          • Aug 2007
                          • 1055
                          Ground planes stop sucking when they are preheated with SMD hot air.
                          • Trinite
                            • Dec 2010
                            • 143
                            Had a few boards like that. Took a while to melt the solder but I was able to get the caps off. I have a 120W soldering "gun" just in case, but I haven't had to resort to using it on a PCB yet.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4970
                              • New Zealand
                              What's the best method to do that?
                              -David VanHorn
                              • severach
                                • Aug 2007
                                • 1055
                                Unlike with a contact soldering gun, a regulated hot air gun can pour copious amounts of heat into a board with minimal risk. In one hand the heater points under the poised desoldering gun in the other hand with the excess heat going towards wherever I'm going to desolder next. When the temp is right the desoldering gun only requires a couple of seconds to melt through to the other side and the hole is clear with very little scarring. A few holes stick so I heat them with the air gun while rocking the connector until the solder breaks.
                                This technique allows me to pull and reuse many types of through hole connectors including power, audio, ATX, IDE, USB, and Ethernet. If the through hole pins don't protrude it's possible to skate the desoldering gun along without turning the pump off.
                                With the heat gun providing most of the heat the contact point of the desoldering gun is able to skyrocket the temperature of the solder without overheating surrounding areas.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4970
                                  • New Zealand
                                  Ahh.... But I don't have a desoldering gun, unfortunately.
                                  I've seen some videos on Youtube, they look quite useful when used properly.
                                  -David VanHorn
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • Hakuu
                                    by Hakuu
                                    Hi There,
                                    More Details
                                    TV Model - LG OLED77G1PUA
                                    07-12-2023, 02:37 PM
                                  • ugamazing
                                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                    by ugamazing
                                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                    12-17-2024, 07:05 PM
