Recap for fun
  • exxocet
    • Nov 2010
    • 6
    • Romania
    Recap for fun
    Hi guys,
    I'm new on this great forum, but pretty familiar with electronic service. It's just a hobby, not my everyday job, but I like it and it's a good way of spending my spare times.
    I have an ASROCK 4CoreDual-SATA2 R2 motherboard, 1.5 years old and I've decided to recap it completely. It works flawless, recap just for fun and checking its overclocking margins.
    The motherboard came with:
    30 x 1000μF/6.3V Nippon Chemi-Con TMZ = 0.02 - 0.03 Ω ESR
    3 x 1000μF/16V Nippon Chemi-Con KZG = 0.01 Ω ESR (CPU)
    1 x 1000μF/16V Nippon Chemi-Con KMZ = 0.01 Ω ESR
    7 x 1500μF/6.3V Panasonic FJ = 0.01 Ω ESR (CPU)
    2 x 1500μF/6.3V Panasonic FL = 0.01 Ω ESR (DDR)
    5 x 100μF/16V Teapo (sorry, forgot to get the series) = 0.05 Ω ESR
    I ordered all capacitors as follows:
    Rubycon MCZ 1000μF 16v
    Rubycon MCZ 1500μF 6.3v
    Panasonic FM 100μF 50V
    I'm thinking about replacing only the Nippon Chemi-Con and Teapo caps and leaving Panasonics as they are now.
    What do you think - should I replace all caps (including Panasonics) or even leaving the board as it, as it works flawless?
    Thanks guys.
  • bigbeark
    • Jan 2010
    • 661
    Re: Recap for fun
    I would have started with an obsolete board as my first recap, just in case it doesn't work out, no harm done.
    As for the Panasonic FJ/FL, you won't find a better cap, so leave them as is.
    Your recapping technique will determine the success of the project. That board will have ROHS lead-free solder, so you are for sure going to have to apply new solder to melt the old stuff to remove the caps.
    Main thing is extreme patience and zero force. Work SLOWLY. If the cap does not want to come out easily, apply more solder. The cap legs should slide out like without yanking.
    The hard part is removing the caps and cleaning out the holes. You need a good fixture to hold the board so you can remove and replace the caps and a soldering station or iron with 60 watts of power.
    The rest you learn by asking questions and doing it.
    • exxocet
      • Nov 2010
      • 6
      • Romania
      Re: Recap for fun
      Thank you bigbeark, that really came in handy! I'm not the biggest fan of lead-free solder, thanks for the tip. I'll be carefull and I won't hurry up a bit.
      Actually I'm not so afraid of a failure as I have 20 years of electronics hobby behind, worked with SMD and multilayer boards, my big concern is your opinion regarding what should I do next. I mean, what would you do if...
      Should I replace NCC and Teapo caps or just leave it as it is as won't see any improvement?
      I did not made massive recap before and I don't know if there is a point in replacing good capacitors just to get 0.01Ω less on ESR. (NCC to Rubycon)
      Thanks guys.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Recap for fun
        i would replace the kzg and call it a day.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: Recap for fun
          kzg----> replace
          teapo----> replace
          the rest is good... unless you dare to polymod, which since it has worked flawlessly, would be of little or npimprovement (it might already have poly caps by the cpu)
          sigpic
          (Insert witty quote here)
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            Re: Recap for fun
            Replace only the KZG caps.
            The Teapos are too small to go bad, unless they are placed in a very hot area.
            • exxocet
              • Nov 2010
              • 6
              • Romania
              Re: Recap for fun
              Thanks guys, that will be a fun job.
              • exxocet
                • Nov 2010
                • 6
                • Romania
                Re: Recap for fun
                Job done. Great success.
                I've recapped all capacitors, except Panasonics. Nippon/United Chemi-Con were replaced with Rubycon MCZ, Teapo replaced with Panasonic FM. I'm talking about ~50 capacitors.
                Everything went smoothly, except for a catch - my new flush cutter proved to be a piece of shit - it died after just one cap. I had to use the scissor and I was nearly to detach one connection hole, right at the DDR voltage. Crap chinese cutter.
                So everything went well, yea, with some thrills, but it's more fun that way. As a matter of fact, it was "recap for fan". And more - after recap, I'm able to reach 3.5Ghz with my E7500 (it might go further, but I didn't tried), before it didn't passed 3.4Ghz. A small gain, but still, good results for money and work.
                Thanks for help guys.
                  no-name Radeon 9600 XT recap and cooler
                  by momaka
                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                  This one was actually suggested to me by ChaosLegionnaire....
                  11-06-2020, 07:54 PM
                • varunviolin007
                  Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                  by varunviolin007
                  Hi guys,
                  I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                  I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                  Looking for someone experienced with older PC boards who uses...
                  07-29-2025, 11:53 PM
                • Foetuss
                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                  by Foetuss
                  Hi all
                  Hope this is in the correct place.
                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                  Could use some double checking to see if I'm not doing something stupid .
                  Pictures of the boards are attached.
                  What I will be replacing with what : (planned)
                  Soltek Golden ::
                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                  01-18-2025, 11:44 AM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
                • goodpsusearch
                  Got 4 LG L222WS 22" for free - psu recap
                  by goodpsusearch
                  Got 4 CCFL 16/10 monitors for free.
                  The resolution is almost Full HD (1680x1050)
                  VGA Input only is a bummer though.
                  Uses cheap TN panel with terrible viewing angles.
                  Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                  All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                  01-15-2022, 05:36 PM
