Component identification GCR 958
  • bindiou
    • May 2015
    • 11
    • France
    i have a shorted component on my ASUS board FX507GU (TUF F15)
    i think it is a step down regulator for the +3.3V on eDP connector for the screen
    can someone identify it ?
    ty
  • R_J
    • 9551
    seems to be made by Monolithic Power Systems Inc. QFN-11 2x2 Top marking might be custom?
    • bindiou
      • May 2015
      • 11
      • France
      hi,
      ty for your reply
      indeed i found same manufacturer, but even with this, i do not find any 11 pin component
      google image, did not help more
      • R_J
        • 9551
        There are many of these QFN-11 2x2, such as MP2384, MP2329, MP2389, MP2349,MP8639 (pdf as example)
        Search results for: 'qfn-11' (monolithicpower.com)
        • bindiou
          • May 2015
          • 11
          • France
          hi
          ty for your research
          i think it is the MP2349,
          the Vin is in the 19V range, and output is 3.3V, what i was searching for ...
          the other one is only max 16V entry voltage
          • deep000
            Burned Voltage Regulator in Monitor โ€“ How to Identify and Repair?
            by deep000
            My computer monitor ASUS VP249H stopped working, and smoke came out of it.
            I opened it and found that a voltage regulator had burned out.
            The problem is that I can't identify its reference.
            I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality ๐Ÿ˜…).
            How can I find its reference, and do you think it's repairable?
            Monitor: Asus VP249H
            Board reference: 0171 - 2271 - 6083
            09-08-2024, 01:13 PM
          • electroelef
            identify and buy a voltage regulator, Audj833
            by electroelef
            I am trying to identify and buy a voltage regulator.
            The casing is somewhere between SOT563 and SOT963.
            So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
            Codes on the capsules are:
            AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
            pin2 is ground
            pin3 is Vin +5v
            pin6 is Vout +3v3
            pin4 is connected through an L to pin6
            I spent quite a while looking for a replacement to buy.
            Any help...
            07-20-2022, 06:47 AM
          • DriversScrew
            Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
            by DriversScrew
            Hello everybody,
            I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
            Vin: 5,0V
            Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
            Pin1: ? (perhaps enable)
            Pin2: GND
            Pin3: Vout - connected to 3ยต3 coil
            Pin4: Vin
            Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
            I searched many datasheets, but no one seemed to match according the surrounding components.
            Best similar parts I found were...
            12-21-2023, 07:06 AM
          • valentino_val
            Transistor or V regulator identification - help
            by valentino_val
            Hi, need help with identification one transistor (or maybe voltage regulator). I need to replace it.
            MMBT2907A ???
            The transistor is burned and is from car's gas analyzer machine that have problem with the display....
            06-14-2021, 05:44 PM
          • Tomylee
            Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
            by Tomylee
            I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
            It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
            I'm looking for help with the following:
            The exact identification or part number of the T5 component
            05-28-2025, 12:42 PM
