identify and buy a voltage regulator, Audj833
  • electroelef
    • Jun 2014
    • 57
    I am trying to identify and buy a voltage regulator.
    The casing is somewhere between SOT563 and SOT963.
    So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
    Codes on the capsules are:
    AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
    pin2 is ground
    pin3 is Vin +5v
    pin6 is Vout +3v3
    pin4 is connected through an L to pin6
    I spent quite a while looking for a replacement to buy.
    Any help would be highly appreciated.
  • R_J
    • Jun 2012
    • 9606
    Re: identify and buy a voltage regulator, Audj833
    This should be it? MP2141NGTF
    • electroelef
      • Jun 2014
      • 57
      That's the one!!!
      You saved my life!
      It's a bit cheeky but how did you find it?
      • deep000
        Burned Voltage Regulator in Monitor – How to Identify and Repair?
        by deep000
        My computer monitor ASUS VP249H stopped working, and smoke came out of it.
        I opened it and found that a voltage regulator had burned out.
        The problem is that I can't identify its reference.
        I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
        How can I find its reference, and do you think it's repairable?
        Monitor: Asus VP249H
        Board reference: 0171 - 2271 - 6083
        09-08-2024, 01:13 PM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • playit
        diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
        by playit
        hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
        and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
        for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
        02-26-2025, 05:39 AM
      • artvandalai
        Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
        by artvandalai
        This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
        The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
        11-05-2024, 07:38 AM
      • Long AMD
        Acer AL1916W - Two seconds to black - Voltage regulator problem?
        by Long AMD
        Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
        I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
        The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
        09-13-2020, 05:59 PM
