Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Old 10-22-2009, 10:04 PM   #1
Zero Hour
Getting there
City & State: Brandon, MS
Send a message via AIM to Zero Hour
Default ECS mcp61pm-hm 6-bad 1800uf 63 Tk caps
It originally came from an HP Media Center. I'm hoping someone can help me to locate these caps or equivalent replacements? There are 10 on the board altogether. last powered on it even still posts and such but Vista gave a bsod. I replaced the guy's board and kept this one so It would be awesome to replace the caps and use it! Any help I do much appreciate! Thx!
Zero Hour is offline   Reply With Quote
Old 10-22-2009, 10:42 PM   #2
etnietering
City & State: Michigan
Default Re: ECS mcp61pm-hm 6-bad 1800uf 63 Tk caps
They look to me like 8mm diameter. Rubycon MBZ and MCZ would be suitable replacements. Make sure to know how many of each capacitance/voltage you need. You should be able to get caps from TC, owner of badcaps.net.
You'll want to measure the diameter to make sure though, as well as the height, and any height restrictions that there might be, and also the lead spacing. TC should be able to hook you up with whatever you need.
Good luck!
etnietering is offline   Reply With Quote
Old 10-22-2009, 10:46 PM   #3
Zero Hour
Getting there
Do I need to know/compare any specs? like Resistance or ripple or anything?
Old 10-22-2009, 11:26 PM   #4
etnietering
Well if you can dig up specs for the TK caps then sure, but they look to be junk, and Rubycon MCZ is pretty much the best of the best in terms of ESR and ripple handling, so I don't think there's much to worry about.
Old 10-22-2009, 11:49 PM   #5
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Send a message via Yahoo to Toasty
Toshin Kogyo from the OST line of crap:
http://www.ost.com.tw/PDF/TK/EC_TK_ATWB.pdf
Toasty is offline   Reply With Quote
Old 10-23-2009, 07:02 AM   #6
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Send a message via AIM to 370forlife
Wow, why does capacitor web have TK listed as a good brand?
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 10-23-2009, 02:27 PM   #7
370forlife
Large Marge
370forlife's Avatar
TK is simply distributed by OST. TK is a japanese company, and is typically reliable.
This may be heat related, not correct series for this situation, or a manufacturing defect.
Old 10-23-2009, 02:55 PM   #8
Toasty
Toasty's Avatar
Hmmmm. Except that this value isn't listed. Likely a "special". Maybe made by OST for TK or vice versa?
I'll go with the heat related. The ratings per the datasheet are very good.
Old 06-15-2010, 04:39 PM   #9
ztech2010
This is a year later but just wanted to let everyone know I am experiencing the same problem with these capacitors. I would experience freezups and restarts and bsods in vista and w7. Sometimes scans would go for hours of memory or backups but other times i would freeze every 2 minutes. Tried everything I could think of software wise and even swappin out parts PS graphics HD.. and did notice these caps bulkin at top, no leaks but very frustrating problem. We mustve got a bad batch.
ztech2010 is offline   Reply With Quote
Old 06-15-2010, 05:43 PM   #10
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
I've seen bad TK caps as well on an ECS board. I consider them as a bad brand, Just like Chemi-con KZG and Nichicon HM and HM. Just because a cap came from japan doesn't mean it will be reliable.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 06-15-2010, 07:33 PM   #11
kaniki
City & State: City of Idiots, Pennsylvania
if the caps are bulging up in the center, then most likely they are bad. one other thing to check, make sure that all your fans are working and nothing is clogged up of blocking air from getting through. If any parts are overheating, it can cause the same problem.
kaniki is offline   Reply With Quote
Old 06-30-2010, 03:42 AM   #12
c_hegge
Unknown
c_hegge's Avatar
Same board, same caps, same problem. 3 TKs are bulged. Two near the PCI-E slot and one between the RAM slots and CPU socket.
This board has already been given a partial recap. I replaced the 3 1800uF 16V TK caps with 1500uF Ruby MBZ and the 1000uF OST RLS caps with Sanyo WG.
I've ordered more caps to replace the rest. The 470uF 16v caps (currently G-Luxon) will be replaced with MBZ. The 4 1800uF caps on the VRM out will be replaced with 820uF Nichicon LF Polys (like the other polys on it) and the other 1800uF caps will be replaced with MCZ.
Old 06-30-2010, 09:27 AM   #13
Zero Hour
Getting there
I got fedup with mine sitting in the corner and randomly decided to order some polymers. I replaced every one of the 1800uf Tk's with (they are LG and either 820 or 1000uf) but I've not tested stability yet, I probably will sometime this week though and I'll let ya'll know.
Old 07-21-2010, 05:19 PM   #14
c_hegge
Unknown
c_hegge's Avatar
I've recapped mine. I ended up going with Panny FJ for the non-VRM 1800uF caps (a bit cheaper). It's been running in memtest all night now (15 Hours, 54 minutes and 38 seconds to be precise). 34 passes and still no problems yet.
Old 08-02-2010, 05:13 AM   #15
c_hegge
Unknown
c_hegge's Avatar
Looks like it will be fine now. It ran without incident for:
24 hrs Memtest
24 hrs Prime95 Blend Test
24 hrs Prime95 In-Place FFT Test
24 hrs Prime95 Small FFT Test
Here's a picture of it with all those polys.
Old 08-02-2010, 08:00 AM   #16
kc8adu
kc8adu's Avatar
City & State: dayton ohio
i have done a bunch of these.used 330@16 sanyo sep in vrm input.
820@2.5 fujitsu re on output.
same on vdimm and vtt.
kc8adu is offline   Reply With Quote
Old 02-16-2011, 08:40 PM   #17
Pro289
Where can I get the replacement caps? I just ran into a friends' computer with 5 bad ones, an HP Pavilion a6357c with a MCP61PM-HM (Nettle2) motherboard. I haven't yet taken it apart to see which values they are, but they all seem to be the same type, like the row near the CPU.
I was trying to find a replacement board, but they're hard to find. A different board that may fit could be around 60-130$. I've recapped an ECS board many year ago, so it shouldn't be too difficult.
Does anyone know if the badcaps store MCP61SM-GM kit would work the same?
Pro289 is offline   Reply With Quote
Old 02-16-2011, 08:54 PM   #18
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
http://www.badcaps.net/store/index.php ?
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 02-17-2011, 09:44 AM   #19
Pro289
After removing my MCP61SM-GM motherboard I found the 5 bad caps are the same 6.3v 1800uf caps as in the first post. So I figure I'll just get 9 and replace all of them to be sure. I'll have to post some pics later of my progress.
Old 03-27-2011, 12:46 PM   #20
Pro289
Well, success! I've purchased replacement caps from this website.
All went okay. A little difficulty in clearing the holes of solder after removing the bad caps.
I ended up using a 0.65mm drill bit to do the job.
My HP Pavilion a6357c is back to life! Prime95 now runs stable.
Thanks BadCaps.net!
