MSI N1996 Motherboard with bad timer
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hello, I have a MSI N1996 it also has a sticker on it that says 865PE Neo 2 - V.
    When I power it up it takes a long time then beeps once if I keep waiting it beeps twice then once more. If I leave it after that it just automatically shuts down. If i do not wait after the previous attempt to try it again it doesn't even get to the beeps it just shuts itself down.
    According to this site - https://forum-en.msi.com/index.php?topic=86906.0 Under the AMI BIOS (Which is what I have) 4 beeps means bad timer. Under the PHOENIX BIOS 1-2-1 beeps is also bad timer.
    If I am correct the timer is a chip on the motherboard right?
    If it is would it be possible to replace?
    All of my google searches just come up with changing the motherboard's battery.
    Any help is welcome
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: MSI N1996 Motherboard with bad timer
    I think you're looking at a complex solution when the answer may be simple
    1a. How do you know the memory you're using is good ?
    1b. And compatible with the board ?
    2a. How do you know the graphics card you're using is good ?
    2b. And compatible with the board ?
    3a. How do you know the processor you're using is good ?
    3b. And compatible with the board
    4a. Do you have the optional MSI D-Bracket ?
    • gg1978
      • Dec 2004
      • 431
      the timer chip isn't a discrete part, it's either part of the super i/o chip or the southbridge. Either way you'll be hard pressed to get a replacement and actually swap it out unless you work with high pincount SMT or BGA packages.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Which processor are you using ? - Pentium4 S478 a given - what speed, FSB, cache (all embossed on the chip) - Sspec would be useful
        What memory are you using ? - DDR1 a given - what brand and speed rating, i.e. DDR266/DDR333/DDR400 ?
        Is your board the model with three memory slots, or two ?
        Compatibility of components is an underrated requirement, but key to getting something that works
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          Originally posted by pfrcom
          How do you know the memory you're using is good and compatible with the board?
          I have tested the memory in another pc and verified that it is good and it is the memory that has been in the board since before it broke so I know that it is compatible.
          How do you know the graphics card you're using is good and compatible with the board?
          The graphics card has also been in the board since before it broke and I have also tested it in another pc.
          How do you know the processor you're using is good and compatible with the board?
          Is there any simple way that I can test it?
          Do you have the optional MSI D-Bracket?
          If that is the USB ports with the 4 lights on the back then yes I have it.
          canadaboy25
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            Pentium 4
            2.80GHZ/512/533
            SL6PF China
            5429B816
            That is what is on the processor
            DDR333 one is samsung and the other is infineon
            And my board has 3 memory slots.
            canadaboy25
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              Probably doesn't help you, but that N1990 is just a certification mark or something, NOT a model number.
              -David VanHorn
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                So it used to work, not something you've recently got your hands on ?
                Your board has i865pe chipset (ties in with 865PE Neo2-V model name), as distinct from i848p chipset of two slot board
                Therefore it can run memory in dual-channel, given compatible DDR sticks
                Do you have memory in same coloured slots, or different coloured slots ?
                Have you tried removing second DDR stick, or moving it to alternate slot ?
                MSI manual indicates different coloured slots are dual-channel setup - at odds with convention, where dual-channel is same coloured slots
                I'd try a single memory stick first, to see if that boots - both yours are quality brands, I'd probably favour Samsung, but if one doesn't boot try the other
                If single stick boots, try second stick, moving to alternate slot if no boot at first
                Pentium 4
                2.80GHZ/512/533
                SL6PF China
                5429B816
                An early model Northwood processor with slower 533FSB (compared to later 800FSB)
                Processors rarely fail, but you never know
                Which gets an OK in MSI manual's Memory Speed/CPU FSB Support Matrix
                If it won't boot with single stick of memory, time to connect your MSI D-Bracket and see what code its twinkling lights give you
                The MSI manual I downloaded for your board is sh*t - has instructions for connecting a D-Bracket, but doesn't show what codes mean
                If you go this route, Google D-Bracket and 865PE Neo2-V to see what you can find
                Failing that, download manual for MSI 865PE Neo2-P (aka MS-6728) which is similar MSI board, with useful documentation for D-Bracket - chances are, its codes are same as yours
                • larrymoencurly
                  • Oct 2004
                  • 960
                  What kind of beeps do you get if you turn on the power without any memory modules installed? If the beeps then differ, there's a memory problem.
                  I would take a close look inside the DIMM slots with a flashlight and magnifying glass, in case any of the contacts are bent, broken, or dirty.
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    Well I took the motherboard out of the case and attached the bracket and put in one ram module and the graphics card and the system is now working fine other than the fact that it randomly shuts down all the time. What would cause that?
                    canadaboy25
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      For the listed bleep codes, 1 of them is wrong, IIRC:
                      For Award BIOS:
                      1 long and 3 short bleeps is the familiar video init failure code. It happens often when the video card got bumped on AGP rigs.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Reseat the heatsink and make sure there's the right amount of thermal paste... And I would try another PSU...
                        Arc A770 16 GB
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          And at least for Asus' version of the AMI BIOS:
                          1 long and/or 8, 9 or 7 short bleeps=CPU fan error and you have to press F1. Failed to detect CPU fan RPMs.
                          And this may occur randomly on a P5Q series!
                          Arc A770 16 GB
                          • canadaboy25
                            What is normal?
                            • May 2013
                            • 509
                            Well I had taken off the cpu fan/cooler for testing to see if it would boot because the atx plug is in a hard to get to spot. So I put the cooler on and presto! now its working
                            The only issue I have now is SATA hdd's wont show up in the bios and the BIOS has 4 IDE channels when my board only has two any Idea how to fix that?
                            canadaboy25
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              Sounds like your SATA contoller is running in IDE mode. There should be an option somewhere to change it to SATA or AHCI mode.
                              -David VanHorn
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                i865 SATA channels will show up as IDE
                                Check SATA is Enabled in BIOS - presumably so, if you have extra IDE channels showing
                                If Enabled, try new SATA cables - temperamental things
                                Otherwise, disks not compatible with i865's SATA - or need jumpering into compatible mode
                                Not with i865
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4981
                                  • New Zealand
                                  Not with i865
                                  Oops. Didn't know that, I'm an AMD guy
                                  -David VanHorn
                                  • vallllliiii
                                    Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                                    by vallllliiii
                                    Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                                    08-18-2024, 09:21 AM
                                  • tech_guru
                                    Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                    by tech_guru
                                    Hello.
                                    I am having a disappointing motherboard repair with this laptop and I need your help.
                                    This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                    -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                    -PQ102 MDV1525URH
                                    -U17 AOZ1331
                                    -UE1 C8051F383-GQ
                                    -PU800 SY8032ABC
                                    -UI2 SY6288D20AAC
                                    -PU508 RT6220AHGQUF 7P=
                                    -PU100 TPS51225CRUKR
                                    -PU300 TPS51212DSCR
                                    Now, I get all the standby voltages, it turns...
                                    02-16-2024, 09:40 AM
                                  • glovecaps
                                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                    by glovecaps
                                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                    11-25-2024, 04:23 PM
                                  • Docus
                                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                    by Docus
                                    Hi everyone 😀,
                                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                                    06-10-2025, 04:24 PM
                                  • Archimedes
                                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                    by Archimedes
                                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                    Fans are spinning. Blindly could install windows11 and got the device manager...
                                    07-30-2024, 05:14 PM
