Transistor Identification - older Weller soldering station
  • alecjahn
    Dumb enthusiast
    • Feb 2012
    • 77
    A while back I tried repairing one of the soldering pencils for my old Weller soldering station that I use quite frequently (sure, there are fancier models out there nowadays, but it has given me years of great service!).
    I tested the repaired pencil only momentarily until recently when I decided to try it out for a project instead of using the old standby pencil that has always worked.
    Well, something fried in the base/station and now it won't heat up either pencil. I'm blaming the "repaired" one on this.
    It -appears- that a transistor, located on the little daughterboard that the pencil actually plugs into, has bit the dust. Whoops.
    My problem now, is identifying the part - a google search for any or all of the numbers on the transistor can ("TO-18" packaging, as I have learned) brings up nothing to help.
    Am I out of luck unless I can find a schematic (no luck there - yet!)? Or is there some magical way to divine the part's rating/numbers with a little more education?
    Thanks, y'all.
  • sofTest
    • Aug 2008
    • 361
    Re: Transistor Identification - older Weller soldering station
    Any chance you could give us the model of the station, and a picture of the underside of that connector board?
    Be a mensch
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8707
      I don't have a Weller so I can't comment on the specific unit you have, but my Ungar also uses low voltage heaters (it has a transformer) and IIRC uses a TRIAC to do heat control of the heating elements.
      If my eyes aren't fooling me I thought that was a TO-5 case...
      hmm...
      http://www.hutsonind.com/TO5SCR.shtml
      • redwire
        • Dec 2010
        • 3912
        The part is a Hutson SCR HS04 4 amp, 50V sensitive gate. It controls power to the heating element from the thermostat switch.
        I would put in a TO-220 part like S4006L, BT150, C106M (w/heatsink), since TO-5 can parts are obsolete.
        Low voltage through-hole SCR's are a bit hard to find, so a 400V part might be easier.
        Teccor SCR's pdf
        Weller MP soldering station schematic
        It's a good station worth repairing.
        • alecjahn
          Dumb enthusiast
          • Feb 2012
          • 77
          The station is a MP101.
          And ah, so it's not a transistor, then! I see now. (my ignorance is showing, whoops!)
          thanks for everyone's help! Hopefully I can find a suitable replacement part. Is a modern plastic part going to have the same pinout?
          Here's a picture of the back anyway:
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8707
            Likely you'll have to replace with a TO-202 or TO-220 and they may not have the same pinout... but if you get the right ones in the right holes it should work. The three terminals for SCRs are the cathode, anode, and gate.
            But likely since the TO5 did not have a heatsink, you won't need one on the TO-220 either. The TO-202 is a maybe... but likely not either.
            BTW, wouldn't these SCR-controlled solder irons have horrible power factors? I suspect the TRIAC controlled ones aren't much better...
            • redwire
              • Dec 2010
              • 3912
              I'm not sure why they didn't use a triac. Otherwise, the heater gets 1/2 wave DC, so it is not optimal. It makes the transformer run hotter and things get magnetised. Newer Weller stations (i.e. WTCP), the thermostat can handle the heater's full power. Perhaps the contacts arc and get stuck.
              The date code on the SCR is 1977...?
              I have Hakko, Ungar and the Weller WTCP is still a great soldering iron.
              • alecjahn
                Dumb enthusiast
                • Feb 2012
                • 77
                Ordered a S4006L and a BT150 from digikey. Hopefully one will do the trick (if not I'm only out a $1 part). Thanks again everyone, I'll update again when I get one installed.
                • alecjahn
                  Dumb enthusiast
                  • Feb 2012
                  • 77
                  Well, no luck. I'm suspecting the transformer.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Have you even tested the resistors?
                    Did you put the new part in the right way around?
                    Muh-soggy-knee
                      Yes, should verify the pin out of that SCR.
                      If you jump Anode to Cathode, the iron will have full power if the transformer is working.
                      • alecjahn
                        Dumb enthusiast
                        • Feb 2012
                        • 77
                        Yeah, I checked the pinout many times before turning it on the first time.
                        Resistors seem fine to be fine.
                        Tried this jump trick and no results.
                        I'm getting no voltage out of the red lines (from the transformer).
                        • redwire
                          • Dec 2010
                          • 3912
                          There are usual checks - heating element resistance, thermostat (with tip in and out), transformer secondary voltage - which you have zero... Neon lamp comes on?
                          Check ohmeter continuity for the transformer primary. I usually go right across the AC line cord prongs (unplugged end!) open-circuit tells me to check the on/off switch etc.
                          If your transformer shows open-circuit on its primary, then the thermal fuse is probably blown. Rarely, you can replace one using micro-surgery.
                          • alecjahn
                            Dumb enthusiast
                            • Feb 2012
                            • 77
                            As it happens, my father had this lying around:
                            The iron operates with the original transformer disconnected and this in place.
                            I assume the thermal fuse is blown in the transformer. Is this a horrible task to replace? where might it be located - around the windings under the paper?
                            • redwire
                              • Dec 2010
                              • 3912
                              If you get no ohmmeter continuity on the primary, it's shot and you don't have anything to loose if surgery goes bad.
                              The thermal fuse is on the lead-in to the primary winding. Look for a bump or something resistor-sized, just after where the wires start to go into the bobbin. I use an exacto-knife and carefully cut back some of the paper until I can see it. The magnet-wire is pretty fragile. You just want to desolder the fuse and replace it.
                              You can get a new transformer for $20 on eBay, which might be less hassle: ebay.com Weller-soldering-station-TRANSFORMER-MP-201-NEW-OLD-STOCK-/181024341913
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Sometimes the fuse will be in under a layer of the windings, but yes, it usually is on the outside. Be VERY careful when taking at apart, the windings are probably VERY fine wire... which is easy to break!
                                Muh-soggy-knee
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  You know, If you can find out what the secondary voltage of the original transformer is, (using documents, design circuits, etc...) you could just buy a new transformer with the same secondary voltage (and current capability!).
                                  Muh-soggy-knee
                                    by sam_sam_sam
                                    07-01-2024, 06:34 AM
                                  • chth96
                                    What soldering station should I purchase for 900M-TJ-I tip?
                                    by chth96
                                    hello.
                                    A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                                    https://ko.aliexpress.com/item/4001275635593.html
                                    Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                                    Any reply would be appreciated.
                                    11-24-2023, 05:08 PM
                                  • caprider
                                    Recommendations of quality soldering station and (separate) hot air station
                                    by caprider
                                    Hey,
                                    I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                    I now have a TS100 and some soldering irons and looking for some better tools.
                                    1. Soldering station, budget around 200-240€
                                    JBC BT-2BWA seems to be a good product in the budget.
                                    2. Hot air station, budget around 200€
                                    Up to now I've found ATTEN ST-862D to be a good option....
                                    01-15-2022, 02:05 AM
                                  • mkbehbeh
                                    KSGER C245 Soldering station PSU 220V only?
                                    by mkbehbeh
                                    I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                    I am...
                                    04-17-2023, 03:11 PM
                                  • Peter_1402
                                    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                    by Peter_1402
                                    Hi Everyone,
                                    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                    1. Soldering iron works great
                                    2. There is a burnt mark on the hot air gun handle.
                                    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                    Reed switch tested ok with a magnet.
                                    From the above test, I can conclude...
                                    07-12-2025, 11:50 AM
