Nichicon HD(M)
  • Tom41
    • Oct 2005
    • 338
    • England
    Nichicon HD(M)
    I've been reading a lot about the recent spate of failures of Nichicon caps. From what I understand, only certain types of Nichicons from a certain era are affected.
    I looked at the WinME machine again, wiped the dust off the caps, and found the names. Next to the CPU, they're all Rubycons - but elsewhere on the board, all Nichicon HD(M). Is this a known 'bad' kind of Nichicon?
    I'm about to reformat the ME machine and install XP; we'll see if that makes the system any more stable
    Then again, when I opened up the PSU it was full of Teapos. No bulging or leaking yet, but Teapo is notorious for failing without any physical signs...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Rainbow
    • Aug 2005
    • 1375
    Re: Nichicon HD(M)
    HD should be OK. Only HN and HM were affected.
    • linuxguru
      • Apr 2005
      • 1564
      Re: Nichicon HD(M)
      HD doesn't have any reported premature failures - it's older and larger than comparable HM/HN, so it's probable that it is over-engineered with thicker dielectric and foils. It has excellent endurance (4000+ hours at 105c) as well as high ripple current and very low-ESR. Taicon (Nichicon Taiwan) also manufactured a HD-series with apparently the same specs., with a green sleeve instead of black or lacquer (silver). No premature failures of the Taicon HD have been reported, either.
      • Shroomie
        • Apr 2006
        • 356
        Re: Nichicon HD(M)
        The Teapos in the PSU ought to be OK. They almost inevitably fail as VRM caps on a mainboard, but newer Teapos do fine in a PSU. My Channel Well's stable as a brick and running pretty close to capacity on the +12v, all Teapo, and over a year old. The older ones might be OK in a PSU as well, I'm not sure - I have a SPI supply (AOpen barebones) with Teapos from 1998 and going strong.
        You know there's something wrong when you open up a PSU and are glad to find Teapos.
        Why I don't buy cheap cases!
        • trodas
          • Jan 2006
          • 770
          • Czech republic
          Re: Nichicon HD(M)
          While is true, that caps in PSU are nowhere near as stressed, as caps into mainboard, I still would like to say that bad caps into PSU can not only make your system unstable (as the user already experiencing), but mainly overstress and blow even good caps on the mainboard - like it was happen to my DFI LP B and Chemi-con KZG caps there...
          So, in short, Teapos in PSU aren't okay and they are endangering the whole machine. I would replace them ASAP.
          "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
          "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
          • Tom41
            • Oct 2005
            • 338
            • England
            Re: Nichicon HD(M)
            Update: PC is now running XP Pro instead of ME, and seems a lot more stable (albeit a lot slower) than under ME. Then again, I haven't yet re-installed all the software that we were using before.
            On my XP machines (including this reformatted one), I've never once had a freeze so bad that I've been unable to shut down and power off. ME, on the other hand, required hard-rebooting (pulling mains lead out) on an almost daily basis!
            I'm going to try and get hold of an oscilloscope and measure the ripple current coming from the PSU under load - updates will be posted here later.
            Edit: For anyone who's interested, I already posted pics of the PSU in the build quality pictorial topic: https://www.badcaps.net/forum/showthread.php?p=18605
            On the last page, it's the 'High Power' 300W PSU.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: Nichicon HD(M)
              just to put the nichicon problem into perspective, we have had reports of older HM series (2002) still working fine. The widespread fails were from 2003 and failed after about a year of service. The fails were i believe in most cases that i saw were practically total, all caps or most were failing. Which leads me to conclude that there was something seriously wrong with the manufacturing of those caps.
              We have not seen evidence of a new problem with nichicon yet and if you have a board working fine for 2-3 years with HM, HN on it then it does not have the issue.
              Problem is that suppliers can be distributing batches of caps manufacturerd a while back so i would certainly avoid HM or HN with 2003 date codes.
              Date codes are written on the caps as 0311 for instance (2003 week 11)
              • arneson
                • Sep 2005
                • 1267
                Re: Nichicon HD(M)
                Using a date code would be interesting to find a source of company records indicating what was going on at the fabrication facility at that time.
                Spring break, Hooters convention, strike, espionage or did someone spill a bottle of rum in the electrolyte slosh.
                Jim
                • Spacedye69
                  • Nov 2005
                  • 698
                  • US
                  Re: Nichicon HD(M)
                  I have old HM(2002) good, new HM(2005) good.
                  • DrewPhillips
                    Capacitor Diarrhea - Nichicon PL Series
                    by DrewPhillips
                    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                    03-02-2025, 10:18 PM
                  • nick3092
                    Mid/late 80's Nichicon Yellow Caps
                    by nick3092
                    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                    08-28-2022, 03:56 PM
                  • chth96
                    Is there datasheet for nichicon LXJ series?
                    by chth96
                    I want to calculate capacitor ESR referring to below guide.
                    https://forum.digikey.com/t/calculat...-from-tan/2633
                    I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                    I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                    Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                    11-20-2022, 08:11 AM
                  • chth96
                    Is there any datasheet for nichicon RT(M) series?
                    by chth96
                    A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                    https://www.badcaps.net/forum/troubl...e-been-blew-up
                    and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                    But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                    I have spare console...
                    11-28-2023, 03:36 AM
                  • spiros.p
                    EV dsp,replace the nippons lxz with nichicon fw ?
                    by spiros.p
                    Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                    12-19-2023, 12:26 AM
