204B freezes after caps replace
  • ztrekr
    • Jun 2012
    • 10
    • r
    I've replaced all 820, 330 and 47 uF caps in my Samsung SyncMaster 204B and now the back-light turns on.
    But as soon as it turns on, the monitor "freezes", i.e. doesn't respond to the power button on the front panel and no image is displayed - just blackness.
    Before the light goes on the power button is operational, but I can't see the menu or anything. But as soon as the back-light activates, the button stops working (the blue light on the button still on).
    Also the humming noise inside the monitor stops as soon as the light goes on.
    What could be the problem?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: 204B freezes after caps replace
    i would remove clean and reseat all the cables could just be a bad connection. re check your soldering on the capacitors just incase you have bridged 2 tracks together by accident
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Hi - please can you update your country and mains voltage in your profile.What problems did your monitor have before your replaced the caps.
      What make/series of caps did you use for replacements.
      Please check your soldering for cold joints and make sure caps are the correct
      way round.(Polarity)
      Try disconnecting the lvds cable - video board to panel and see if the back lights stay on.
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      It will be useful if you can say a bit about yourself - skills tools etc.
      • ztrekr
        • Jun 2012
        • 10
        • r
        Of course I've checked all the trivial things before posting
        Polarity, soldering, wires...
        I even went so far as to replace the capacitors yet again with a new bunch of fresh ones, in case there was a factory defect in one of them or bad soldering.
        Anyway, the back-light now works perfectly, so I guess the power supply unit is now Ok and the problem is probably in that other board that is responsible for actual displaying. I think some internal microcode or settings got corrupted.
        I've seen posts here where people reported bad colors or corrupted image after capacitors replace and it was solved by reseting to factory defaults. Unfortunately, I can't reset to factory default because I can't see the menu.
        And holding the front panel's "Enter" button doesn't work either because the back-light goes on in about 2 seconds (then monitor freezes) and you need to hold the button for 5.
        So is there a hardware way to reset to factory defaults, like shortening some pin on the board or something?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Please can you update your country and mains voltage in your profile.
          What problems did your monitor have before you replaced the caps.
          https://www.badcaps.net/forum/attachm...1&d=1290283049
          https://www.badcaps.net/forum/attachm...7&d=1280167246
          • ztrekr
            • Jun 2012
            • 10
            • r
            Today I've found out that my replacement caps are probably not low ESR
            They are Jamicon TK series:
            http://www.icd-sales.com/Manufacture...ies-table.aspx
            How critical is low ESR? Is it possible that this can cause freezing of the microcontroller board in my case? As I said, the back-light seems to be working fine...
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Well, one out of three requests answered - this is going to be a long thread.
              Short term,low esr caps will work but will be short lived and may take out other components as they fail - they are also only 85deg caps so will react badly with heat.
              • ztrekr
                • Jun 2012
                • 10
                • r
                What my country and mains voltage have to do with anything?
                The problem was standard "2 seconds to blackness" problem.
                • mariushm
                  • May 2011
                  • 3799
                  If we have to recommend some components for you to buy to fix your monitor, it helps to know where you're from, so we can give you links for the more convenient store.
                  Ex. If you're in Malaysia, I could give you links to Digikey and be charged 40$ for shipping from US to you, or I could give you links to element14/newark which has warehouse in Singapore and have free shipping or you pay only a few dollars to ship.
                  Post pictures of the boards if you can, sometimes experienced people can spot areas with problems that you may not think about or spot by yourself or can suggest to do some measurements on some components in case something else is the problem in your case.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Well country was one of the compulsary fields when you applied to be a forum member.
                    The Mains voltage in my opinion is actually more important as it tells us what to expect
                    as a result of certain tests. It is also important from a safety point of view 240 volts is more likely to kill you than 120 volts.
                    Less important. If you dont supply the information I will not try to assist you, which I guess will not bother you in the least.
                    • ztrekr
                      • Jun 2012
                      • 10
                      • r
                      Yeah, like you're gonna be liable if I die poking inside my monitor... Let me worry about my own safety.
                      What are you, some kind of racist? What's with this laughable blackmail?
                      • mariushm
                        • May 2011
                        • 3799
                        He's not employed here to help everyone, and you're not paying him anything.
                        It's not blackmail, it's just his personal decision to not help anyone that doesn't follow instructions designed to keep things running smoothly.
                        • ztrekr
                          • Jun 2012
                          • 10
                          • r
                          "If you don't provide info I won't help" IS blackmail.
                          Childish, unreasonable blackmail, because my country and mains voltage have nothing to do with the problem at hand.
                          • t.j.
                            • Apr 2010
                            • 383
                            • canada
                            no blackmail! your just ignorant! what was asked was to make helping you easier ! you seem to know everything, good luck!
                              Trust me 115V hurts just as much as 230V and both will quite easily kill you in the wrong circumstances. But it's quite difficult to do if you're careful.
                              Let's guess that you are using 115V AC because as far as I know the Syncmaster "B" series was a US only model.
                              Your Jamicon TK caps probably won't do the job and are likely to at least be part of the problem.
                              • ztrekr
                                • Jun 2012
                                • 10
                                • r
                                Well, you guested wrong It seems that the B model is also available outside US - I have a 220 V grid.
                                Ok, got it, thanks. I will try to find proper replacement caps here.
                                Until then - is there a way to reset EEPROM on the board somehow? I think its settings just got corrupted and that's why it freezes. I have 0.1 rev board.
                                  Another reason to specify line voltage... Since you refer to it as "220" are you in Europe (excluding UK?)
                                  On Samsung TVs the procedure is to short pins #5 and #6 of the 8 pin EEPROM together while the monitor is starting up. I don't think your EEPROM is corrupt though, I think it's more likely it's not booting because the power supply is not stable.
                                  • ztrekr
                                    • Jun 2012
                                    • 10
                                    • r
                                    Yes, I'm in Europe, but not in the UK.
                                    Ok, then I will try to find proper capacitors, replace them and see what's going to happen.
                                    • ztrekr
                                      • Jun 2012
                                      • 10
                                      • r
                                      UPDATE: I haven't replaced the caps with low ESR ones, but managed to measure the voltage from the power supply to the microcontroller board - it stays the same all the time (from turning on to "freezing") - 13.06-13.07 V (specs require 13 V).
                                      • ztrekr
                                        • Jun 2012
                                        • 10
                                        • r
                                        Hooray, I've fixed it! I was right all along - EEPROM A81SC (24C08) got corrupted (probably due to the wild voltage swings because of bad caps).
                                        So shorting pins 5 and 6 while turning the monitor on, cleared it and the monitor stopped freezing!
                                        tom66, thanks for the info!
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • edith
                                          Caps and how to find one to replace
                                          by edith
                                          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                                          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                                          Thank you!
                                          06-11-2023, 05:00 PM
                                        • Mattz_GT
                                          Which caps to replace: ECS P4M800Pro-M V1.0A
                                          by Mattz_GT
                                          It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
                                          I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
                                          Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
                                          Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
                                          PS. Additional diagnostic,...
                                          01-22-2025, 12:12 PM
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          Hi everyone,
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
