#1 |
City & State: Harrisburg, PA
Line Voltage: 120VAC 60Hz
Anyone who has purchased a lower-end Coolermaster Case with a PSU included probably found one of these inside of it, so let's see how good or bad it is.
First off it is not a 350w, if you add up the individual rails it comes to 250w, we'll find out why in a moment. First the input side, there is decent input filtering (only half is on this board the other coil and Xcap are attached the the power connector for a total of 2 Xcaps, 2 Ycaps, and 2 Coils, not the best I've ever seen but considering many PSUs in this class have no input filter at all this isn't too bad. GBU4G Bridge Rectifier rated at 4A 400V, considering this is a 250W PSU this is defiantly sufficient A Pair of Canicon 470UF 200V filter caps, I'd prefer 680UF caps although 470s should be ok for a 250W unit. Decent Sized Coils, Two D304X primary switchers, more than sufficient for a 250W Now we move on to why this is really a 250W PSU. One F12C20C Schottky on the 12V rail rated at 12A 200V, Given that this rail is rated at 10A this is just barely sufficient with only 2A of overhead. Two S20C45C Schottkys each rated at 20A 45V one for the 5V and another for the 3.3V. These rails are rated at 14A each so again a 20A part is sufficient although I would like to see more than 6A of overhead. Decent sized coils and caps for a 250W PSU although all the caps are either Canicon or Sapcon, not exactly the best brands. Bottom line this isn't all that bad for a "Free with a Cheap case" PSU. If you stick to the ratings of the individual rails and only use it in a low end system it will probably do ok for an extreme budget build, just don't try to load it up too heavily, and forget about quad core processors or high end video cards. I would however recommend a better unit if budget allows. Stay tuned for a rebuild, this thing appears to have some potential. I'm planning on swiping the much more substantial secondary rectifiers from a dead Dell Celetronix CX305P (proprietary Dell BTX casing that is slightly larger than standard ATX meaning it won't fit in a normal ATX tower and thus not worth repairing), and upgrading the Caps as well when I get some free time. Last edited by dmill89; 02-07-2012 at 09:01 PM.. |
#2 |
Unknown
My Country: Australia
Line Voltage: 240V 50Hz
It's a Sun Pro. If you load it to it's labelled rating, it will explode. I reviewed two similar ones in the HWI el-cheapo PSU roundup.
EDIT: I also load tested a Thermal master 420W PSU. It was also made by Sun Pro. It exploded at 420W load.
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod Last edited by c_hegge; 02-07-2012 at 09:07 PM.. |
#3 |
I could see this thing potentially doing the 250W you get from adding up the rails, at least for a little while. I agree if you load it to the 350W combined wattage on the label the 12V rectifier will blow up since it is only rated at 12A. I doubt anyone would have to worry about overloading the 5V or 3.3V rails on any modern system although I would like to see more than 20A of capacity on these rails.I could definitely see this thing running a sub 200W Celeron, Pentium dual core, or i3 system with integrated video at least for a few years until the caps fail. These faults are things I will correct when I get around to doing the rebuild. Again this isn't a great PSU but it is better than most of the Free with sub $50 case PSUs I've seen. Last edited by dmill89; 02-07-2012 at 09:41 PM.. |
#4 |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Not too bad indeed. I'm actually pretty surprised Sun Pro made this. Their quality is usually very low.
Post a picture of the underside, if possible. I would like to see how Sun Pro did with the soldering. Judging by this PSU, perhaps they have improved a little. |
#5 | |
Not the worst I've ever seen, definitely not the best either, looks like they sanded/ground some of the blobs down so they wouldn't short against the case. It also looks like it was hand soldered on an assembly line since the soldering on some parts of the board is better than others. Last edited by dmill89; 02-07-2012 at 11:11 PM.. |
#6 |
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
The only complaint I have about yours above is that the separation between some traces on the primary is a bit too small in certain places. That's typical of Sun Pro, though. But other than that, not too bad. Again, I expected much worse from Sun Pro. The 380W Raidmax I have by them is a complete disaster. And they still make those too!
#7 |
On my level
It isn't too bad - look, the transformer is an EI-40. That's a step up from the 33 you usually see in those units. Oughta do 400W if you do the right upgrades.
#8 |
I Promised a rebuild and here it is:
Input Side: Now has 2 X 680uf caps, and a GBU6J Bridge Rectifier Overhead Rectifiers on secondary: 2x STPR1620CT 16A 200V on 12V rail, 2x STPR3045cw 30A 45V one each on the 5V and 3.3V rail New Caps on the secondary are UCC KZE except the 2.2uf 50v caps which weren't replaced New Fan: Sunon KD1208PTS1 Full Listing of Changes / Upgrades: Input Side: Bridge Rectifier: GBU4G > GBU6J Main Caps: 2x 470uf > 2x 680uf Secondary Rectifiers: 12V: 1x F12C20C > 2x STPR1620CT 5V: S20C45C > STPR3045cw 3.3V: S20C45C > STPR3045cw Secondary Capacitors: 2x Sapcon 16v 470uf > 2x UCC KZE 16v 680uf 4x Canicon 10v 2200uf > 4x UCC KZE 10v 2200uf Sapcon 16v 2200uf > UCC KZE 16v 3300uf Sapcon 16v 1000uf > UCC KZE 16v 2200uf Canicon 10v 470uf > UCC KZE 10v 1000uf Fan: Generic sleeve bearing fan > Sunon KD1208PTS1 With the exception of the caps on the secondary all the parts were salvaged from a dead Dell (Celetronix) CX305P-00, the secondary caps were ones I had on hand, nothing was purchased specifically for this rebuild. Last edited by dmill89; 02-11-2012 at 12:56 AM.. |
#9 |
404 Not Found
City & State: Fairfax, California
I'm a: Forum Junkie
Well cool! Looks good
What's with that tape or something on the primary capacitors?
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!! http://www.youtube.com/watch?v=y6GaPkkGZGw |
#10 |
They came out of the dell like that. The tape is really sticky and difficult to remove, and it helped hold them when I was soldering so I left it on. There was more tape on the top (you can see the residue), but I removed that piece to be able to see the tops to make sure they weren't bulging or leaking.
#11 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Wish there was a way to beef up those heatsinks (when it comes to high power heatsinks, heavy metal is definitely your friend!) and replace that O/P inductor -26 material core with a core made with -52 material (powdered iron core materials made by Micrometals), but neither would practical. OTOH, replacing those 4700pF, 2KV Y caps with real 4700pF Y caps would be a good idea, and you might find some in that Dell P/S (made by Delta Products?).
PeteS in CA Republican Operative discussion forums Where might is right There is no right. - Sophocles in "Antigone" **************************** All that is gold does not glitter, Not all those who wander are lost; - J.R.R. Tolkien, The Fellowship of the Ring **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. |
#12 | |
The Dell says it is made by a company called Celetronix on the case and when I search the UL number it comes back to a company called EOS Power India PVT LTD. It looks reasonably well built but not as good as a Delta or Lite-On, Probably close in build quality to most HIPROs I've seen. The only thing wrong with it was blown CapXons on the secondary, but since it is a non-standard size which only fits certain Dell BTX towers and I have several Deltas and Lite-Ons in that same size which are better built if I need one for a BTX Dell, so I generally just strip these Celetronix PSUs down for parts. Last edited by dmill89; 02-12-2012 at 01:08 PM.. |
#13 |
I had planned on that however, those plans changed. I pulled the Y caps from the Dell and they only tested at 1800pf(It was a heavily used 7 year old PSU), I tested the Y caps that were in the Thermal Master and they tested at 5400pf so they will be staying at least until I get another junk PSU with good Y caps I can steal. However I did add an extra X cap salvaged from the Dell that tested good. The Thermal Master already had 2 X caps but there was a spot silkscreened on the PCB for an extra one so I added it in.
| Thread Tools | |
| Display Modes | |
