many mobo's will benefit from polymer cap upgrades
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    i wound up with a bunch of polymer caps from a surplus outlet.
    my experiments conclude that most if not all motherboards benefit from using polymers.
    noise/ripple on vcore of this imperial gl is half what it showed with ncc kzg.
    next up is a vp6.
    note these are 2.5v caps so only useful on vcore and vdimm.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: many mobo's will benefit from polymer cap upgrades
    hehe you probably doubled the value of that imperial
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i bet the original cost of the caps exceed the oem cost of the board.
      like a car who's value doubles when you fill it up.
      • Super Nade
        • Jun 2006
        • 294
        Actually man, I bought a whole bunch of OSCON SEPC 4V 560uF recently. Planning on recapping all MB VRM's I have with it.
        I'm trying a little experiment-->
        http://www.ocforums.com/showthread.php?t=536054
        Suggestions are most welcome!
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
        Abit IP35Pro
        ATi HD4870
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          cool!
          i got a big mess of those too.
          nice thing is they are the short version needed for 775 boards.
          on the next boards i do i will record before and after readings.
          looks like a friends bp6 is the next test subject.
          i got a ton of the 820@2.5 in fujitsu and ncc.
          • Super Nade
            • Jun 2006
            • 294
            I want to replace the 6.3V Fujitsu's on my ASUS P5K, but I wonder if that would make any difference? So you reckon these big MB makers are avoiding Sanyo because of the price?
            Q6700 @ 3.6 GHz
            Zippy GSM-6600P
            Abit IP35Pro
            ATi HD4870
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              what value are the fujitsu's?
              i would say if the ones you intend to install have the same value but lower esr there may be improvement esp if you overclock.
              i have been using the 820@2.5v on vrm output(vcore)
              i tried 560@4v on vdimm to give a safety margin.
              so far this board has been folding 2 weeks with no problem.
              the box it came from would bsod several times a day.thats why my neighbor tossed this board.
              he found out too late i repair them after he bought a asus board and bent over for his billy gates reaming for an xp license.
              • gonzo0815
                • Feb 2006
                • 1600
                I have done a recap too with Oscon SEPC series. But the problem with those polymers is probably to maintain capacitance.
                My first and only polymer recap job was an Asrock K7S8XE+, but the poor Tbred died shortly after the mod.
                But ok, it was oced right from the start up to the limit and may be further (but always prime, memtest86+ etc. stable) and was running several years w/o a problem.
                I had to reduce the capacitance of the four KZG 3300uF caps by using four 2700uF polymers.
                I know, that may be it isn`t to smart to tweak a value board, but it was just a project
                Now, for the Intel P4 boards, there are already smaller value caps used, may be due to a higher switching speed and the very fast response time Intel specified for it.
                • Super Nade
                  • Jun 2006
                  • 294
                  Fujitsu's have the same value i.e 560uF and all spots are not populated. I'm replacing them with SEPC 560uF, 4V. ESR is about the same i.e around 7mOhm.
                  Q6700 @ 3.6 GHz
                  Zippy GSM-6600P
                  Abit IP35Pro
                  ATi HD4870
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    i would replace them and stuff all the unpopulated spots too.
                    • Super Nade
                      • Jun 2006
                      • 294
                      Yep, that is what I'm gonna do. I'll be replacing all Fujitsu 560uF's across the board with SAnyo. So, do you think I'll see more stable voltages?
                      Q6700 @ 3.6 GHz
                      Zippy GSM-6600P
                      Abit IP35Pro
                      ATi HD4870
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        maybe.
                        but make sure you only change vrm output side caps.
                        you will be safe to replace those on vdimm too but do a bit of testing to ensure you dont install these on vrm input which are +5 or +12 as lifespan vill be very short(pardon the pun)
                        these dont like overvoltage and often turn to very low value resistors when they go.
                        • gdement
                          • Jan 2007
                          • 690
                          If the ESR is reduced, then you don't need as much bulk capacitance.
                          I somewhat recently recapped a Socket-370 board. It originally came with 4x 1000uF electrolytics on Vcore. I replaced them with 4x 560uF Oscons, and it passed every stress test perfectly with the most stressful CPU I could find to plug into it (Celeron 1100MHz). It's probably more stable now than it ever was when new. Intel and AMD both have some docs which show the relationship between ESR and required capacitance, which is what convinced me to try doing this.
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            Yes, that is right, but the control loop has to be fast enough to respond faster, if the bulk capacitance is lowered (or i am wrong in this case??)
                            If the VRM was designed with an few 1000uF capacitors, i think it would be no problem to use an 560uf to 820uf polymer capacitor.
                            But how about a VRM with a few 2200Uf to 3300uF at the output?
                            I am not sure, if the control loop would handle a drop to 1500uF or even lower w/o changing the feedback filter.
                            • Super Nade
                              • Jun 2006
                              • 294
                              AFAIK, the output side caps have nothing to do with the feedback loop. They only serve to create a low impedance path for AC. More important here is the whopping 6200mA ripple current rating of the OSCONs. If you have a small number of phases, inductor ripple current is the biggest problem.
                              In fact OSCONs are specifically recommended against being used in any kind of feedback/integrator loop. The tech docs say so.
                              It is tackled in two ways, on the CPU package or the socket, you see a whole bunch of MLCC's which have very good frequency response across the board, have zero temperature de-rating and have a very low ESR. You may also see a bunch of Tantalums thrown in there to accommodate low frequency cutoffs. All this is ofcourse after the output side is filtered.
                              Q6700 @ 3.6 GHz
                              Zippy GSM-6600P
                              Abit IP35Pro
                              ATi HD4870
                              • MixMasta
                                • Feb 2006
                                • 142
                                Originally posted by gdement
                                If the ESR is reduced, then you don't need as much bulk capacitance.... Intel and AMD both have some docs which show the relationship between ESR and required capacitance, which is what convinced me to try doing this.
                                Hey could you post a link to these docs. I am interested in reading them. Thanks!
                                • Super Nade
                                  • Jun 2006
                                  • 294
                                  I've got some stuff in there for AMD.
                                  http://www.ocforums.com/showthread.php?t=536760
                                  Look at VRM 11.0/11.1/8.XX/9.XX Tech docs from Intel's website.
                                  Q6700 @ 3.6 GHz
                                  Zippy GSM-6600P
                                  Abit IP35Pro
                                  ATi HD4870
                                  • gdement
                                    • Jan 2007
                                    • 690
                                    Here's the AMD document which I was looking at more recently:
                                    I think this is the Intel doc I read before, or at least it has similar info. It was a few months ago and I can't find it on my computer anymore:
                                    • gonzo0815
                                      • Feb 2006
                                      • 1600
                                      From my understanding, the bulk capacitance is required for transient response. Sure the transient voltage drop depends on the ESR, but if the control loop is not fast enough, the caps are drained before the switcher controller can adapt to it.
                                      Furthermore, the inductor sets the minimum time, how fast the current could be delivered.
                                      I refer to the L6917D app note:
                                      I have read a lot of other more general notes about VRM design over th time from ST, but i forgot the document numbers.
                                      Basically at the bottom of page 25 there is the control lope mentioned, and at page 15 the inductor slope time and capacitor choice and minimal bulk capacitance formula.
                                      Transient response is from my understanding critical, as it is occurring frequently when powering a fast CPU.
                                      Many board manufacturer (including Asrock) had been disabled bus disconnect feature of Athlon Xp in the BIOS, to reduce transient stress from the VRM.
                                      I have enabled it on my Asrock K7s8XE+, and i experienced Vcore fluctuations as high as 0,2v.
                                      • gdement
                                        • Jan 2007
                                        • 690
                                        Thanks for that link, I've saved it and will be interested to look at those formulas more carefully sometime.
                                        It seems to me that the response time is already factored into the capacitance formula:
                                        Code:
                                                deltaI * deltaT
                                        Cb>=    --------------------------
                                              (deltaV - (deltaI * ESR))
                                        deltaT is defined as the "voltage regulator response time" in the AMD document (pdf pg 17).
                                        deltaI is the max current transient
                                        deltaV is working voltage * tolerance
                                        If deltaT remains constant, and the only change is in the ESR, then required bulk capacitance should be reduced, if I'm understanding this formula correctly.
                                        It's a simplification though, the Intel doc points out that the formula is assuming that the voltage regulator has no response during deltaT, then suddenly responds 100%. But that should only make it more conservative than it has to be.
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
                                        • Perry Babin
                                          Derating of polymer electrolytics
                                          by Perry Babin
                                          There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
                                          If they require derating, why would the manufacturer give them their rated voltage?
                                          This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
                                          https://www.mouser.com/datashe...
                                          10-24-2025, 11:57 AM
                                        • Perry Babin
                                          How do organic polymer caps compare to liquid electrolytic for reliability
                                          by Perry Babin
                                          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                                          If not organic polymer, what would be the caps that could take the most abuse?
                                          08-18-2025, 04:04 PM
                                        • cj_reha
                                          Mystery 80s Sanyo cap - perhaps polymer?
                                          by cj_reha
                                          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                          01-06-2023, 09:24 AM
                                        • OriginalDaggers
                                          XBox 360 All Polymer Capacitors
                                          by OriginalDaggers
                                          As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                          I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                          If I have things right, I can replace them TO
                                          x9 : 1500uF 16V 10x20mm
                                          TO: 470uF Nichicon FPCAP R7
                                          x2 : 820uF 6.3V 8x12mm
                                          TO: 2.5V 820uF Nichicon FPCAP R5
                                          On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                          What's a good replacement for the smaller...
                                          This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                          02-20-2024, 12:49 PM
