There's nothing worse than seeing a thread full of red 'X's or broken image links!! PLEASE use the attachment feature for image hosting. When posting a thread or reply with images, click the manage attachments button below the text box and upload them to our server. This eliminates a lot of headaches for members viewing your thread long after your cheesy photobucket or imageshack account has removed your images!
Please Use Forum Attachments For Images!!
This is a sticky topic.
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsTags: None- Stuck
Re: Please Use Forum Attachments For Images!!
even if they are still available the worst is when you are trying to reply and the offsite images are still slowly loading. -
How about imagevenue? They seem a bit more reliable.
Any concerns with site bandwidth with large images?Comment
we have no bandwith concerns but it nice to be respectful to other members so the threads are loading fast (use 700px wide max)
https://www.badcaps.net/forum/showthread.php?t=1868Comment
i don't know. i don't trust any other free image hosting than geocities. i host a website there from 2001 and still running to this day. with some trick you can use it to hotlink the images from the forum too.How about imagevenue? They seem a bit more reliable.
(will, is what i said allowed?)
also i just want to add some tips for you who want to upload screenshot. you may alreaddy know that png is better than jpeg for screenshot. it is better because it is lossles, can be 16kb color, smaller in filesize, and you can add transparency too.
you know, when you visit a webpage with dozens of those jpeg screenshoot, and it slooow because the images take hundreds of kilobytes where png would save it for half the sizes, you feel tired. you on a laptop and using cellphone as a dialup modem. isn't it perfect?
jpeg is only better for natural photography.
/just my 2 cent.
days are so short when you actually do something..Comment
hmm i will try that. saving photos as png is a mistake though, for instance i just saved a tiff in png and it was 6mb, the jpg was 482kb.png is better than jpeg for screenshot.Comment
Try reading this couple times and change the words photobucket or imageshack for any other provider you wish:
This eliminates a lot of headaches for members viewing your thread long after your cheesy photobucket or imageshack account has removed your images!Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Photobucket=OFC (Of fucking course!) That's a notorious one for removing images in a short time.
imgur is a good one, IIRC, far less likely to delete or disable images for no-good reason.Last edited by RJARRRPCGP; 12-29-2015, 09:16 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
That post almost seems like your account have been hacked and you are just canning food…Less jewellery, more gold into electrotech industry!
by reessiHello!
This machine had the classic fault that all these motherboards have which is the loose pins on the RAM slot.
I soldered them as I have done on a few other of these and then it posted.
Everything works, fully installed with Windows 11 etc.
Only fault is when it has gone to sleep and you turn on again the screen is blank with no backlight and the caps lock does not work so I assume it has frozen completely.
Only way to get it to post again is to remove the battery! No amount of forcing off and on will get it to post!
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by notallbadHaving replaced a brand new full led backlight set and fixing a mainboard fault (power-on transistor) theres now a louder than normal hum / buzz coming from the power board in the AC filter, namely in the LF101 / 2 area, or at least thats where the sound is more resonant whilst the backlight is set at 100%. Turn down the backlight to 50% its less noticeable and 0% its non-audible.
When the rear case is fitted back on its more audible and its certainly more than an acceptable level so would rather solve than leave like it.
Have powered on the tv with panel disconnected... -
The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping...
Channel: Common Parts Library - Datasheets
10-23-2024, 03:37 AM -
The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...-
10-07-2024, 04:12 AM -
- Loading...
