Richtek RT8205A RT8205B RT8205C Power Supply Controller for Laptop Computer Datasheet
    The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping to the PWM outputs. The RT8205A/B/C includes on-board power-up sequencing, the power-good output, internal softstart, and internal soft-discharge output that prevents negative voltages on shutdown.
    A constant on-time PWM control scheme operates without sense resistor and provides 100ns response to load transients while maintaining a relatively constant switching frequency. The unique ultrasonic mode maintains the switching frequency above 25kHz, which eliminates noise in audio applications. Other features include diode emulation mode (DEM), which maximizes efficiency in light-load applications, and fixed-frequency PWM mode, which reduces RF interference in sensitive application
    Applications
    - Notebook and Sub-Notebook Computers
    - 3-Cell and 4-Cell Li+ Battery-Powered Devices
    Features
    - Wide Input Voltage Range 6V to 25V
    - Dual Fixed 5V/3.3V Outputs or Adjustable from 2V to 5.5V, 1.5% Accuracy.
    - Alternative LGATE1 Output (LG1_CP) acts as Clock for Charge Pump (RT8205B)
    - Secondary Feedback Input Maintains Charge Pump Voltage (RT8205C)
    - Fixed 3.3V and 5V LDO Output : 70mA
    - 2V Reference Voltage ±1% : 50μA
    - Constant ON-Time Control with 100ns Load Step Response
    - Frequency Selectable via TONSEL Setting
    - RDS(ON) Current Sensing and Programmable Current Limit combined with Enable Control
    - Selectable PWM, DEM, or Ultrasonic Mode
    - Internal Soft-Start and Soft-Discharge
    - High Efficiency up to 97%
    - 5mW Quiescent Power Dissipation
    - Thermal Shutdown
    - RoHS Compliant and Halogen Free
    Ordering Codes:
    RT8205AGQW RT8205BGQW RT8205CGQW
    RT8205AQW RT8205BQW RT8205CQW
    ZD-915 vacuum pump motor mount service alert
    If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
    One note this unit has been repaired already once because of switching power supply regulator ic chip failure
    Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
    The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
    09-19-2021, 02:15 AM
  • Dannyx
    Remote pump control ideas.
    by Dannyx
    Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
    09-11-2020, 04:10 AM
  • betmen
    water pump Scala2 - electrical diagram
    by betmen
    Does anyone have a wiring diagram for the pump mentioned?
    The markings on the board are 98800964 r07, two or three capacitors are burnt.
    I don't have the board with me yet, but I don't know if the printed lines on the board are visible due to the short circuit that occurred and how the capacitors were connected.​
    05-22-2025, 02:56 AM
  • Dannyx
    Another water pump automation project (suggestions ?)
    by Dannyx
    Good day folks. Some of you may recall that a while ago I was struggling to put together what I considered to be a very basic automation for a water supply system. It didn't work out the way I intended and I learned my lesson to do it properly from the start, rather than try to reinvent the wheel and patch something together myself from scratch, so I'll stick to commercial alternatives for future projects and such a project just came in today !
    This one is easier simply because this time the pump and level sensors are in the same place, so they don't require a remote connection....
    07-26-2022, 11:39 AM
  • bajdik
    Richtek LED Backlight Identify IC chip 'CZ=EL 12M' - LCD monitor Samsung LTN173KT01 from Asus K70
    by bajdik
    Could anyone identify Richtek backlight driver from Samsung LTN173KT01?
    There is only "CZ=EL 12M" mark on it. Thank you very much!
    04-04-2025, 03:12 AM
