Very ugly capacitors... or fake? (Panasonic FR)
  • TheLaw
    • Jan 2011
    • 477
    Re: Very ugly capacitors... or fake? (Panasonic FR)
    Twas nice, though I prefer the shade of FCs better...
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      everybody will always miss mbz. lets hope rubycon comes out with a good replacement
      but then again, maybe in the future everything will be polymer on motherboards, things are slowly going that way for motherboards. But i'm not sure polymers can be properly integrated into power supplys. I mean, 400v polymer? not sure if thats even possible. and if it is, it won't be cost effective
      • mockingbird
        • Dec 2008
        • 5484
        Rubycon won't be replacing it. They're saying to use ZLG instead, but the ESR is not low enough. I can't say I blame them. There's much less demand for low-esr electrolytic capacitors since motherboard makers are now switching to polymers.
        Ultra-Low ESR caps will become a rarity in the future, and all you'll be able to buy is new old stock.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          But Polymers will be OK to use instead won't they?
          -David VanHorn
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            not in all circuts. VRM's where theres parallel caps sure. but supposedly not startup caps or non-filter caps, at least thats the impression i've gotten so far
            • mockingbird
              • Dec 2008
              • 5484
              #26
              Tracing back caps to see which are VRM is a nightmare for me, that's why I don't use polymers.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Often not. - Especially if it's not in a motherboard VRM.
                Try finding a 2200uF 16v in Polymer.
                .. or even a 1500uF or a 1200uF 16v Polymer.
                You -might- even find some but then,,,
                I saw some 1000uF 16v a while back. They were over $7 each...
                Mann-Made Global Warming.
                - Dr Seuss
                • mockingbird
                  • Dec 2008
                  • 5484
                  #28
                  Don't you halve it though? So a 16V 2200uF would become 8V 1100uF or more likly a 6.3V 1000uF which are inexpensive and widely available.
                  EDIT: I missed the part where you said if it's NOT in the VRM.
                  Thankfully, the motherboards are being designed these days to use lower valued caps but more of them rather than large valued ones. So only those pre-polymer designs might have no replacement parts in the future.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    #29
                    creating circuits is pretty mathematical. polys and lytics are not only different as far as the forumla they use inside, but the mathematical formula used to make circuits. this is why you must half the values
                    one thing I do notice is polys don't blow. I even put 10 of them in reverse accidentally on a dell gx270 and they withstood several attempted diagnostic attempts at starting that thing
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #30
                      That explanation was a little ambiguous, but appreciated nonetheless.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4953
                        • New Zealand
                        #31
                        So if Low-ESR electrolytics get dropped there is no replacement at all for them?
                        -David VanHorn
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Bunk.
                          Wrong all the way around.
                          Halving the uF is only safe in a VRM and even then only if you significantly reduce ESR.
                          - THAT comes from an application guide for a VRM controller chip.
                          It wasn't dreamed up out of the mist like some mods are.
                          Outside of a VRM the value of uF could be critical to the circuits operation and you'd best not jerk with it short of drawing out the entire circuit and doing ALL the math for it.
                          So far as polys not blowing,,
                          I just had one blow in a Dual CPU server board,, oh,, 45 minutes ago.
                          It blew load enough to startle me into stepping back.
                          It went out with a large puff of nasty nasty smelling black smoke.
                          The top of the can is now sitting a bit less than 1/4" higher from where it was before.
                          The 'legs' are that same amount longer than they were before.
                          It was an OSCON SEPC and in parallel with 9 others.
                          The clincher is it is VRM-out for the socket that did NOT even have a CPU installed.
                          It wasn't even loaded in that configuration.
                          - WTF! - This is NOT my day!
                          Anyone have any new 4 letter words? - I'm running out today..
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Only ones that speak Chinese.
                            - Dr Seuss
                            • mockingbird
                              • Dec 2008
                              • 5484
                              #34
                              PCBONEZ, this accident is unfortunate. Hope it wasn't a recent board but an old one in case it blew something other than just the cap.
                              When you say halve the uF, do you also halve the voltage?
                              • TheLaw
                                • Jan 2011
                                • 477
                                #35
                                No halving the voltage could be dangerous. If 12V is going through the capacitors on the VRM, and they are rated for 16V, halving it would give you 8V, which wouldn't work.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  #36
                                  I am confused...
                                  -David VanHorn
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    You know better than that...
                                    The rated voltage still has to be more than the actual circuit voltage.
                                    On the Vcore side of VRM in any thing I've seen in the last few years 2.5v caps are enough because CPU Vcore are under 2.0v.
                                    On the PSU side obviously you still need 16v caps.
                                    Was a dual skt 771. - Just sold it's 'brother' for $125.
                                    All I was doing was setting up to memtest some FB-DIMMs.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      I am confused...
                                      CH and TW brands will still be around.
                                      I don't see Suncon dropping out soon. [Formerly aka Sanyo.]
                                      Panny and Nichicon aren't droppong out afaik.
                                      - Dr Seuss
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4953
                                        • New Zealand
                                        #39
                                        Oh right, that makes sense now. In fact now that I know the answer I don't see how I failed to understand in the first place
                                        -David VanHorn
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #40
                                          Was curious because of exactly that... I thought I saw really low voltage polymers around some sockets so I was a little confused.
                                          Initially I thought that the reason for lowering the spec with polymer caps was because the higer ripple ratings compensated for the drop in voltage.
                                          Sounds like old Core2 Xeons...
                                          Thanks for the clarification.
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • Olkus
                                            Elna capacitors - fake?
                                            by Olkus
                                            I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                                            09-01-2023, 02:45 AM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • slybunda
                                            AA and AAA battery charger capacitors?
                                            by slybunda
                                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                            it has inside:
                                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                            2 x 470uf 16v LZ105c branded as G.Luxon
                                            not heard of these brands are they any good?
                                            iv attached photos of the charger and the board inside for an idea on the type of...
                                            12-24-2023, 04:41 AM
