SAMSUNG UE55MU6405 - no standby
  • crystaldabuu
    • Jan 2017
    • 3
    • France
    #81
    No problem, thanks for searching and thanks for helping us repair our boards !
    • Jmenuu Zavalichi
      • Jun 2024
      • 28
      • españa
      #82
      Hi, I have a PlayStation 4 that won't start... and when it started, it couldn't be updated... My question is... If I copy the 25q40 dump and send it to you, could you repair it? I don't know if it's the culprit, but I'll try.
      • Maniacks62
        • Nov 2017
        • 8
        • Czech republic
        #83
        Dobrý den,
        toto je výpis z ue50mu6172u, můžete to opravit?
        Díky.
        • lotas
          • Jan 2016
          • 4594
          • Russia
          #84
          Originally posted by Maniacks62
          Dobrý den,
          Díky.
          Hi, please write your message in English. Dump working! What is the status register set to? What is the problem with TV?
          • Maniacks62
            • Nov 2017
            • 8
            • Czech republic
            #85
            After connecting to the mains, the backlight immediately starts flashing and no TV image can be controlled. When the connectors to the display are disconnected, the backlight is on and the TV can be controlled.
            • lotas
              • Jan 2016
              • 4594
              • Russia
              #86
              Most likely the problem is in the panel, install a jumper on the motherboard between points FB_TRDY_1 and FB_TRDY_3 and disconnect the lvds cables one by one and see which half of the panel has the problem.
              • Maniacks62
                • Nov 2017
                • 8
                • Czech republic
                #87
                I made a jumper. The TV remains on and controllable by both LVDS cables separately (only backlight, no picture, but responds to the remote). If I connect both cables, it flashes again and is uncontrollable.
                I would be grateful for any advice. thanks
                • lotas
                  • Jan 2016
                  • 4594
                  • Russia
                  #88
                  Post here your IC1603 W25Q80 and what is the number of your panel, matrix?
                  • Maniacks62
                    • Nov 2017
                    • 8
                    • Czech republic
                    #89
                    I'm not sure what panel number you want.
                    • lotas
                      • Jan 2016
                      • 4594
                      • Russia
                      #90
                      Try Dump IC1603
                      • Maniacks62
                        • Nov 2017
                        • 8
                        • Czech republic
                        #91
                        Try Dump IC1603
                        Unfortunately, it's still the same.
                        • lotas
                          • Jan 2016
                          • 4594
                          • Russia
                          #92
                          You installed the jumper correctly, you can take a look at the photo.
                          • Maniacks62
                            • Nov 2017
                            • 8
                            • Czech republic
                            #93
                            In the first case, I had it soldered incorrectly.
                            pin 1 (connector CN1300), last pin (connector CN1301_UT)
                            I just tried it, the TV does not restart. It can be controlled with both LVDS connectors connected. The image does not appear even with one connector disconnected.
                            • lotas
                              • Jan 2016
                              • 4594
                              • Russia
                              #94
                              That's how it should be.
                              • Maniacks62
                                • Nov 2017
                                • 8
                                • Czech republic
                                #95
                                Tested. After connecting the CN1301_UT connector, no image is displayed on the TV. With the CN1300 connector, the right half of the TV works.
                                • lotas
                                  • Jan 2016
                                  • 4594
                                  • Russia
                                  #96
                                  Well, finally the image appeared, look for the problem on the non-working side or try to mask the contacts...
                                  • Maniacks62
                                    • Nov 2017
                                    • 8
                                    • Czech republic
                                    #97
                                    You're great, thanks for your help. I covered the contacts and figured it out. Something went wrong with the display in the lower left. You can see it in the attached photo.
                                    • lotas
                                      • Jan 2016
                                      • 4594
                                      • Russia
                                      #98
                                      Well, it looks like you were unlucky, remove the front frame and inspect the glass under a magnifying glass for burnout (on new panels, the line drivers are built into the glass itself and cannot be repaired).
                                      • PNI E.
                                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                        by PNI E.
                                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                        03-17-2025, 04:23 AM
                                        09-07-2024, 05:50 AM
                                      • JSin21
                                        Compatibility of main boards between different variations of samsung MU6100
                                        by JSin21
                                        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                        I have Samsung Smart TV UA65MU6100WXXY version DA01
                                        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                        11-27-2023, 04:54 AM
                                      • tvguy12012012120
                                        by tvguy12012012120
                                        02-07-2025, 05:13 PM
                                      • Kaar3l
                                        Samsung QLED QE65Q7FNAT only standby light
                                        by Kaar3l
                                        TV: Samsung QLED QE65Q7FNAT
                                        PSU: BN4400940A
                                        MB: BN94-12832K
                                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                        09-24-2024, 01:35 PM
