and from the 25q80 is this one
SAMSUNG UE55MU6405 - no standby
I copy the dump of the original 25Q80 to the new main... but nothing is seen, only the LEDs light up... I put the original dump back to the new main and I see the screen the same as before... I mean the programmer works well for meComment
Now it seems that copying dump from 25Q80 (original main) to the new main does not work for me, but if I could find the original dump or you could modify the dump from 25q40 (non-standby) of the original board I could possibly recover itComment
But this dump corresponds to 25Q40, but it is damaged, I restored it, try it, do not forget to install and write status registers (0x88, 0x42) after recording the dump!Attached FilesComment
MAN....YOU ARE THE GOD.....its works perfectly.....the original main tx very much...y will recomend youComment
Hello ! I had the same issue that the original totof post with my UE55MU6405, I had written the 25Q40 with the fix given on the 2nd post.
Now my TV power on and all its ok, heuuhh almost ok...
I have a 1cm vertical strong black line at the left ( in front of 2nd cof )
Is a bad version of eeprom dump can cause this problem ??
Do I need to search elsewhere ?
I also checked and cleaned the tow ribbon connectors between Main and panel.
Model on TV : UE55MU6405UXXC
Model on main board : UE55MU6409UXZG
MAIN : BN41-02568B (BN94-12401R P45F)
Panel : CY-KM055HGEV1H
I have a backup dump of my original corrupted 25Q40.
Thanks you everybody !Comment
It's strange that that dump suited you (it has a different software version compared to yours), as for the strip on the panel, this dump has nothing to do with it, it is responsible for the standby mode...
Well, try your own, corrected one.Attached FilesComment
Ok, thank you a lot, I will try it today !
Could you please explain to me what are in each memory IC1604/25Q40 , IC1603/25Q80 and 24512 Flash ?
Do you know what's going on with the 25Q40 ? Why is it corrupted ?
How do you make this magic ?
Do you have a kind of section memory decoder ? What is this program ? Homemade or Manufacturer tool ?
I keep you informed as soon as possible.
EDIT : I program 25Q40 with the fix. The TV are OK but I already have the vertical strip...
An idea for the strip problem ??Comment
Hello, W25Q40CL dump is bricked I guess. No red light then connected to 220V. All fuses and components seems ok.Attached FilesComment
TryAttached FilesComment
Hy there ..y will send you the dump 25q80(display)from my tv samsung and try to replace yours(dont forget save your original dump yo restore it if you dont have succes)because is the same tvComment
Hi IOTAS, i have a Samsung HG32EE460SK that doesn't turn on, no backlight, no red standby light. 19v at the power supply output. Heating up the NAND did nothing for me.
Could you look at the dump from the 25Q40 (IC805) and see if you can fix it? It looks like large parts are missing.
Mainboard model is BN41-02468 (BN94-10894P)
Thanks in advance
I also attached dump of the 24C256 incase someone has this model with corrupted IC801.Attached FilesComment
Thanks in advance
Unfortunately, I don't have anything for this TV model, I can't check it.Comment
by PNI E.Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos -
by mrautom8Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
While relay is on, all voltage rails are present and steady (scoped) on main board.
I love a good logic puzzle but getting lost without any schematics.
No shorts on ANY capacitor main board.
Thermal camera shows 3.3V inductor getting warm instantly but...-
Channel: Schematics and Boardviews
10-19-2025, 06:32 PM -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... - Loading...
