Samsung LN52B550K1F no backlight has picture has sound
  • henry21347
    • Dec 2022
    • 5
    Hi I have a samsung LN52B550K1F LCD TV. There is no backlight but I can see a picture under a flash light. The sound is playing as normal. I have attached the pictures of the boards.
    With my laptop connected to HDMI4 port, I tested the voltages of the connectors:
    Power board (BN44-00267B) to main board (BN97-03035M) connector (CN801):
    5V_DET 0.1V
    E-PWM 2.77
    I-PWM 0
    INV-ON 0.05
    13V 12.81
    5.1V 5.15
    SB 5.2V
    PS 1.22
    SYNC 1.74
    Power board to LED driver board (SSB520H18V01):
    VCC 12.81
    FB1 0
    FB20
    GND0
    LD9.3
    Power board main capacitor: 60-64V~
    Unwelded caps:
    2H684k: 650n
    470nk: 450n
    Voltage of T-con fuse: 12.8V
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Re: Samsung LN52B550K1F no backlight has picture has sound
    Can you us a little history of the TV?
    Did you aquire it in this state or have you been using it normally until these symptoms developed?
    Here is the service manual for your TV.
    [Mods pardon me if this is not allowed]
    https://www.manualslib.com/manual/24...1f.html#manual
    Once you download it you can jump straight to pg 169 to follow the troubleshooting section.
    Let us know how it goes!
      • 12306
      • U.S.
      looks like you are not getting the proper inverter on signal from mainboard, my guess is mainboard fault.
        • 12306
        • U.S.
        try unhook cabe from power board to mainboard, plug power cord in, see if backlights come on and stay on, if they do, that usually means that backlights and powerboard are ok, I always make all unhooks and rehooks with tv unplugged from power to avoid any errant surges etc.
        • henry21347
          • Dec 2022
          • 5
          @KYBOSH
          I picked it up from others in this state. It's free.
          Following the troubleshooting part, I started with "No power" section:
          backlight off, power LED flash 5 times after down.
          BD102:5.1V
          BD104:12V
          BD108:13V
          BD106:5.1V
          R102:3.3V
          R171,R173,C122,R527: all good
          LVDS pin1-5:12V
          T-con fuse:12V
          power is supplied.
          Then it tells me to go to No video-HDMI part but I have no wavevision to debug this part. I do have an image on screen under flash light.
          @nomoresonys
          The inverter_on signal is nagative because DET_5V is negative. DET_5V is negative because FB1 FB2 feedback is negative. I tried connecting INV_ON to 5V but still no backlight.
          @nomoresonys
          With CN801 disconnected, the backlight is still off. But I have another good TV (Samsung LN40A500T1F) which backlight is also down with main board disconnected to power board.
          @all
          The HDMI1, HDMI2 and HDMI3 are not working. I think it's because of plugging cables too hard. After I had it only HMDI4 worked and it's located on the edge of the main board.
            • 12306
            • U.S.
            It helps when I read the whole post, lol, so the main caps have 64 volts and you can see an image with a flashlight? what voltage do you get on main caps with inverter unhooked from powerboard?
              • 12306
              • U.S.
                • 12306
                • U.S.
                guess its possible it's going into protection? maybe ohm out the little transformers on the inverter, they should be very close to each other in ohms, can also check the resistors and diodes of inverter.
                  • 12306
                  • U.S.
                  I would check the voltage at ps-on and inv-on, check it just like this, tv off but plugged in[standby] put neg. probe on metal chassis ground, pos. probe on the top of connector contacting the metal part of wire terminal, make note of voltage, leave it in place power up tv, make note of voltage, do the same to both ps-on and inv-on, both should change from 0 to 5 volts or 5 volts to 0, and hold steady in properly working tv.
                    • 12306
                    • U.S.
                    can also test the powerboard, UNHOOK cable from powerboard to mainboard, could need up to four approx. 1k resistors, with resistors jumper ps-on to sb-5.2, inv-on to sb-5.2, then plug in power cord, see if backlights come on and stay on, if not may need to add the other resistors from e-pwm to sb-5.2 and or 1-pwm to sb-5.2, and retry see if backlights come on and voltages are as expected. Of course make all the jumps with tv unplugged from power, then plug it in after jumps are made, so you don't get any unwanted accidental contacts.
                      • 12306
                      • U.S.
                      also check cable from powerboard to mainboard, they may get faulty with age, had one a while ago had a burned wire that wasn't real obvious, look it over, see if there's any brown marks on either end, can also check each wire for continuity.
                      • henry21347
                        • Dec 2022
                        • 5
                        Both main caps read 60-64V~ with inverter unhooked from power board. But there is a surge of volts at the begining exceeding the multimeter (>750~).
                        I can see an image like this with a flashlight put in the holes from the back.
                        All little transformers on the inverter board read about the same ohm (output 17 ohm between pin2 and pin1/3, input 0 ohm between pin1 and pin4, 0ohm between pin2 and pin3, open between pin 1/4 and pin 2/3). The little transformers model is 488R B8CU1.
                        I don't know which one is power_on actually, but I suppose 'PS' is power_on. In stand_by mode (power connected but shutdown), all pins of CN801 is 0V. After I turned it on and heard the start up music, I measured CN801 on the POWER BOARD:
                        PS 1.02V
                        SYNC 1.6V
                        SB 5.1V
                        INV_on 0.02V
                        Can anyone tells me what the pins mean? I uploaded an image of the CN801 connector.
                          • 12306
                          • U.S.
                          is that capacitor right next to the connector domed/bulged on top at all? looks like it.
                            • 12306
                            • U.S.
                            PS 1.02V
                            SYNC 1.6V
                            SB 5.1V
                            INV_on 0.02V
                            read Budms' most excellent guide here, explains it all, read the basic tv and monitor troubleshooting guides pdf: https://www.badcaps.net/forum/showthread.php?t=25810
                              • 12306
                              • U.S.
                              quote "Both main caps read 60-64V~ with inverter unhooked from power board. But there is a surge of volts at the begining exceeding the multimeter (>750~)" what type of multimeter are you using, it was set to dcv, 400 or 600? if it isn't auto-ranging.
                                • 12306
                                • U.S.
                                maybe test the main cap/s on the good tv if you have easy access like this one, should be around 400 volts dc when powered on, something seems quite off with the readings.
                                • henry21347
                                  • Dec 2022
                                  • 5
                                  Both main caps read 64-64V AC and 319/-55 V DC against ground and 0V AC and 390 V DC from themselves. This is about the same as the good TV.
                                    • 12306
                                    • U.S.
                                    ok, I kinda thought you were measuring in ac instead of dc, the 390 is all we needed, so thats good, means the powerboard is working ok, at least up to that point.
                                      • 12306
                                      • U.S.
                                      test fuse on inverter board, make sure it shows continuity/is not blown.
                                        • 12306
                                        • U.S.
                                        test voltage at cnl801, meter set to dc 20, neg. probe on chassis metal back.
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • gl4709
                                          Samsung un55cu7000d with backlight and sound No Video / Picture
                                          by gl4709
                                          I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                          01-23-2025, 06:21 PM
                                        • LaPCon_IT
                                          Samsung UE50TU7099U no picture no sound, backlight present
                                          by LaPCon_IT
                                          TV has one combo board (VTT55UH160). Symptoms are like this.
                                          When part of the screen is disconnected (white part), it looks like this
                                          Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
                                          I haven't noticed any shorts on rails listed below:
                                          VGH - 30V
                                          VGL- -9V
                                          VAA - 14V
                                          VCOM - 5.6V
                                          STV - 11.95V
                                          LC1, LC2 - +30/-12V
                                          All CKV lines (no shorts between them) looks the same:
                                          I've tried to cover some lines with...
                                          12-15-2023, 03:55 AM
