"universal mainboards" for TVs?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    I've heard about "universal main boards" for TVs, is there such a thing and perhaps I can adapt one of these to a TV with a bad main board?
    I suspect most of these "universal main boards" are for LED TVs so I'd have to convert it for CCFL which probably means I'm keeping the old PSU. But will the existing tcon take the signal from one of these "universal" boards if they exist?
    Searching ali points to such thing but I don't know if these really work or not...
    Incidentally I have a RCA TV's mainboard, wonder what the chances are of getting it to work with a Sony TV, and no I don't care if I have to cut more holes in the back panel, as long as I can use the TV once more
  • mmartell
    • Oct 2013
    • 3189
    Re: "universal mainboards" for TVs?
    I don't know anything about them but I have seen them for sale on Aliexpress so they do exist.
    • petehall347
      • Jan 2015
      • 4450
      i might search the panel number and see which tv.s it was used in . it might not be exclusive to sony .. i know sony dont hand out training manuals unless you repair under licence . unless things have changed these days .. i do actually have lots of old paper manuals for sony that i acquired years ago all from before flat screen tv.s .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        Yeah... just wonder what is expected to be able to use these so-called "universal" boards, and who knows, it may add "smart" tv functionality to the old TV too...
        The sony's panel is made by Samsung, so I suspect it's also a Samsung TCon that works with the Sony mainboard... so there's definitely some mixing matching going on here.
        • petehall347
          • Jan 2015
          • 4450
          first have to understand how it works then it becomes easier . same with anything i suppose . televisions or idiots lanterns as i call them are white man's magic .. most of them must basically work in a similar fashion .
          • alfatv
            • Sep 2020
            • 353
            Pretty much every cheap TV brand is using "universal" boards.
            How to program them or what adapters to use you have to figure out by yourself.
            Backlights are limited to specific configuration.
            You can dig it here:
            https://www.kazmielecom.com/category/universal-brands/
            • advant
              by advant
              02-03-2020, 12:25 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • cheeky2
              Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
              by cheeky2
              For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
              See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
              01-08-2024, 05:56 AM
            • joby91
              SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
              by joby91
              I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
              I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
              I found one chat about firmware on ************** forum but i cannot read the comments.
              https://**************/forum/108-114100-1#880537
              09-04-2024, 01:34 PM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
