Vizio V555-H1 - Horizontal lines then double image bursts
  • jason123
    • Oct 2015
    • 1083
    Hi there,
    I think it might be a bad panel but I thought I'd ask before I chuck it..
    thin colored horizontal lines bottom and thin section on top. As it runs warmer, you can see some ghosting or double image. Right hand side of the screen darker then brighter (backlight is always on, so it's the actual LCD that gets darker and brighter)
    Replaced the Main board, because I had one handy, no change.
    Is it worth replacing TCON? disconnecting ribbon on one side of the panel, the lines appear still on the other side (unplugged side.)
    No side tabs, so cutting tabs not an option
    • 12216
    • U.S.
    Re: Vizio V555-H1 - Horizontal lines then double image bursts
    try the tape cut-off method, maybe check the mlcc caps on panel driver boards for shorts or low ohms, can check for the usual tcon voltages.
    • jason123
      • Oct 2015
      • 1083
      No side-tabs on this panel. No shorts but i will check for low resistance
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • rapid911
        Vizio M58Q7 colored horizontal lines
        by rapid911
        Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
        05-28-2023, 04:17 PM
      • JRyan
        Vizio 39" horizontal lines
        by JRyan
        Found yet another TV by the road that has lines across the whole screen. What is causing this?
        12-22-2023, 10:02 PM
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • brad2157
        Vizio E70-E3 Two white vertical lines
        by brad2157
        I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
        Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
        Replacement main board - Boots up fine, but starting...
        12-13-2021, 05:11 PM
