Nevir 39" LCD acting up. Broken panel?
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi! I got this TV that was supposed to "not work well".
    I turned it on and the BL got lit but nothing was showing on screen
    Opened it and found that the only PS voltages present (12v and backlight) were 100% perfect
    Plugged it back in and the screen kind of started up showing a NEVIR logo but it was split into several chunks with also missing lines in between. Nothing else
    Next time the screen showed an amorphous large color cloud in the screen swinging from side to side (maybe a screensaver picture) with all broken lines everywhere.
    I unplugged the LVDS cable from MAIN to panel and the image slowly faded away to black. I tried unplugging the flex that links both sides of the LCD panel boards and the image only happened on the right side, with only dim shades of the same in the left side.
    At this time I want to be able to tell if this is a bad panel (the panel is 100% intact, at least physically), or the main board. Well, this is a single board TV set...
    Also I tried gently pushing the edges of the screen, the flex cables from the LCD board to the LCD, and pushing also all the components on the LCD board and nothing changed at all
    Any direction will be appreciated
    Thanks!
    PD: Videos too large to attach, can be found here: https://file.io/OhgBhoAUATsP
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: Nevir 39" LCD acting up. Broken panel?
    Just to add to this, the TV set responds to all either panel buttons (on-off, volume, channel) as well as remote commands. I mean I can't see anythng chnaging on screen as this sliding cloud is all I see, but the stb_by led flashes everytime I touch any button and I can turn it off/on with both panel and remote, so everything inside seems to be "alive"
    • lotas
      • Jan 2016
      • 4880
      • Russia
      There should be a fuse in this area (check it) DC 12V should be suitable for it.
      • edugimeno
        • May 2017
        • 581
        • Spain
        Ok I will check that, and will that fuse cause such an effect on the screen?
        • lotas
          • Jan 2016
          • 4880
          • Russia
          If the fuse is blown or there is no 12v power to the T-con, then the matrix will not work and there will be no image.
          I misunderstood, you had something on the screen, so the problem is either on the bars (T-con) or in the panel itself.
          • edugimeno
            • May 2017
            • 581
            • Spain
            Understood, I will check that fuse anyway.
            Is there any easy way to determine if the issue is on the bars or panel?
            • lotas
              • Jan 2016
              • 4880
              • Russia
              Well, if you disconnected the left side (loop) and the right side showed the image well, then the defect is on the left side, well then disconnect the loop and check all ceramic, blocking capacitors for low resistance or short circuit.
              • edugimeno
                • May 2017
                • 581
                • Spain
                No no, I disconnected the left side (the one that's bridged to the right side) and left side went blank with just some remainig shades, and right side was still showing the weird cloud moving side to side, check the videos I uploaded, one is with bridge to second bar and other is without bridge
                • lotas
                  • Jan 2016
                  • 4880
                  • Russia
                  The video has been removed from your link.
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    I see, thanks for letting me know. I uploaded them again to this other site:
                    https://filetransfer.io/data-package/XpcUq2ZO#link
                    Tjanks
                    • lotas
                      • Jan 2016
                      • 4880
                      • Russia
                      Yes, the defect is more like a problem in the panel itself, you can also check the voltages at the test points on the panel bar (T-con).
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        Hi again, I couldn't find time for this yet, but I was thinking, either if the fault is in the TCon boards (are those panel bars called T-con on these TV's too?) or if its the panel, its not easily fixable right? This is just a basic 32" set.
                        Thanks!
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • ravi_1617
                          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                          by ravi_1617
                          Hello to all ,
                          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                          on external VGA port image is perfect /normal , Attached image...
                          07-25-2025, 12:07 AM
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • Glaval
                          Sony OLED XBR-65A8G 4 flashes
                          by Glaval
                          Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                          01-23-2025, 04:04 PM
