Samsung LA32M51BS
  • edharvey
    • Jul 2010
    • 17
    Samsung LA32M51BS
    Hi guys
    I have a 32" samsung LCD that when switched on, the power light will switch on and off in time with a clicking noise in the back of the set.
    I have opened the TV up and found two burn marks on the power board.
    As seen in the pictures there is a burnt out component that looks like a resistor, however I believe is actually a fuse (labelled FD802S)
    There is also a burn mark near the transformer (also pictured)
    All the capacitors on the board look fine (no bulging etc)
    Just wondering if anyone else has had a similar problem and what the best direction is to go from here, I assume that just replacing the fuse won't help as there is probably something that caused it.
    Thanks for your help
    Ed
  • edharvey
    • Jul 2010
    • 17
    Re: Samsung LA32M51BS
    I have just had a look on the internet and located the powerboard on Ebay for this TV.
    It is part number BN94-00699D interestingly enough it is from a New Zealand supplier which is where I live, however it is still $120US which I would like to avoid paying if possible!
    http://cgi.ebay.com/BRAND-NEW-SAMSUN...efaultDomain_0
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by edharvey
      Hi guys
      Ed
      It would be interesting to know the history of this set - as in has anyone been inside it before you?
      Looking over the board, the power flow is fairly obvious. Power comes in, is rectified, appears to go through a PFC circuit, and then to STR1, a combination SMPS controller and power FET in a single package. You were close with your interpretation of FD802S; it's a fusible resistor - see the symbol on the bottom of the board - a combination of a resistor and a fuse.
      If you follow the traces, you see that one end of FD802S goes to the burnt pin on the power transformer.
      And that's where history comes in. There are two possible explanations for a burnt pin like that. Scenario one is a bad solder joint caused overheating, degradation of the solder, and eventually an arc. At some point the main power FET shorted, blowing FD802S. Assuming availability of parts, that is certainly repairable. The flaw in this conjecture is the solder joints on the other transformer pins appear to be perfect.
      This leads us to the other possibility. Someone was troubleshooting and got careless, shorting that pin to ground. The arc burnt the pin, blew the fusible resistor, and possibly did additional damage. While this repair would be possible, that leave open the question of what was the original fault?
      PlainBill
      • edharvey
        • Jul 2010
        • 17
        Thanks for your reply Bill, very detailed!
        I am not sure of the history of the set, I bought it cheap from an auction company which is responsible for selling goods from insurance claims etc. A couple of screw pads on the plastic back cover have broken through, however this would suggest that someone has hit the side of the set rather than opened it.
        Would you recommend, as a first step that I find a replacement for this resistive fuse and see what happens? I am in my second year of an Electrical engineering degree, so I know a bit about this stuff but my knowledge is still quite limited in some areas.
        Ed
        • PlainBill
          • Feb 2009
          • 7034
          Ed
          Just replacing parts to see what happens is usually an expensive way to damage a piece of electronics beyond repair. I'd suggest the following steps.
          1. Examine the burnt pin carefully. Is the end of the pin pitted like an arc was occurring there, or is the damage at the point where it passes through the board? If the damage was at the end of the pin it would indicate TWO problems with the TV.
          2. Check the power FET (STR1) for shorts. If it is shorted, replace that also.
          3. Check the diodes on the secondary side of the transformer for shorts (unlikely, but it's a sensible precaution.
          4. Look for any other problems - shorted semiconductors, bad solder joints on transformers, etc.
          5. Replace the fusible resistor. I don't have more than a vague guess as to it's value.
          PlainBill
          • edharvey
            • Jul 2010
            • 17
            Ok, will do. Does anyone know where I might be able to source a schematic for this circuit in order to find the value of the fusible resistor?
            • PlainBill
              • Feb 2009
              • 7034
              You could try Googling the part number of the power supply and schematic.
              PlainBill
              • edharvey
                • Jul 2010
                • 17
                Yes, this was obviously my first attempt however I was not able to find anything. Are there any websites that specialise in schematics or should I contact Samsung and ask for it?
                • hoadle
                  • Jul 2010
                  • 174
                  Here the parts for samsung around $85
                  https://www.encompassparts.com/webwi...number=6461772
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    I think the fusible resistor is your least problem. Better focus on what may have blown it. When you find out, you may use a temporary fusible resistor like 1ohm for testing purposes. When the psu appears to be good, you'll have to use the correct type of fusible resistor of course.
                      09-07-2024, 05:50 AM
                    • magneh
                      Is this some kind of fuse resistor ?
                      by magneh
                      Hello guys
                      Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                      Seem to me like some kind of fuse resistor?
                      After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                      They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                      The red band is larger than the 4 others, but I dont have much experience with these components.
                      Also one of the orange...
                      02-10-2025, 07:54 AM
                    • ttmi100x
                      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                      by ttmi100x
                      Greetings everyone,
                      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                      Upon closer inspection...
                      07-31-2024, 06:36 PM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
                    • Pwtzz
                      Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
                      by Pwtzz
                      Hi All,
                      Before replacing what I know to be bad even with my novice experience. What I have checked at the moment is the fuse and the obvious burnt capacitor. I haven't bought any replacement parts yet.
                      I still have no idea how this happened but could just be plain old turned bad. What other stuff should I consider buying as replacement? thanks in advance.
                      Edit: I saw that a replacement board can be had for about $50. I would rather attempt to fix before just replacement the board.
                      07-19-2022, 06:45 PM
