old Bravia double fail?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8696
    Re: old Bravia double fail?
    Only thing is that the symptoms I have do not match the reflow guy - the reflow guy said that he at least got the logo to show up, which is a LOT farther than what I'm getting - all I get is the solid green power LED that never blinks until power off, and the red error LED stays blacked out.
    My USB1 1GB sticks don't seem to do anything with it nor the 1GB SD card in USB2 adapter.
    No sound whatsoever coming from the speakers so this seems to imply a bigger problem over the tcon or panel...
      • 12104
      • U.S.
      #82
      did you try another tcon? when I updated my old kdl I used a sony 4 gb thumb drive.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8696
        no, because a bad tcon would be a double failure, since having a bad tcon/panel would not stop the backlight from lighting? Still have to focus on bad mainboard or perhaps power is not good.
        I need to find a better place to put the TV - closer to my test equipment, still haven't probed it with a scope for signs of life.
          • 12104
          • U.S.
          #84
          ok, my best guess and the easy thing to try is post #79.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8696
            Anyone know... if I did use a "wrong" board and despite it "fits" (i.e., all connectors are compatible, etc.) what would the symptoms be due to the anti-repair policy Sony did for some or perhaps all of their TVs?
            Would I get a blinking power or status LED? Should the backlight come on and print on the screen "ERROR: UNAUTHORIZED REPAIR DETECTED SYSTEM HALTED" or something like that?
              • 12104
              • U.S.
              #86
              LOL, I don't think you'll get a readout like that, if the boards not compatible it usually just won't work. Can you show both boards and the stickers on each.
                • 12104
                • U.S.
                #87
                Also whenever you change out mainboards in sonys, you need to do a firmware update/pair, you prolly already know, just in case others looking on need it.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8696
                  Actually that will be a problem, the assumption is if you get the board for another model, it will assume the personality of that other model.
                  As pictured, the current board:
                  1-879-020-11
                  "almost" doppelgangers
                  1-879-020-12
                  1-879-020-13
                  1-879-239-11
                  1-879-239-13
                  Not doppelgangers but also appears to have very similar port placement
                  1-879-224-14
                  There are probably more. Main thing I'm going to look for closely before purchasing is ensuring the LVDS connector matches. And of course this is a experiment, I'm not going to pay full price to see if it works or not, better be a fairly substantial discount for it! (Unless someone says it will work!)
                  Note: these all have different features like USB or maybe even "smart" circuitry but the boards power and tcon connectors seem very much alike as well as port placement like HDMI, VGA, LVDS, TOSLINK, component, S-video, tuner, etc., etc., are all in the same place... My board even has pads for some of these ports but not soldered on.
                    • 12104
                    • U.S.
                    #89
                    1-879-020-12
                    1-879-020-13
                    1-879-239-11
                    1-879-239-13 Can't go by these alone, they are just what they start with then they populate to their needs, look at the long white stickers.
                      • 12104
                      • U.S.
                      #90
                      Did you post the panel number? should be on the metal chassis someplace.
                        • 12104
                        • U.S.
                        #91
                        The main and tcon have to be compatible with the panel, I don't think there's as much of a problem matching tcon to mainboard, but they do need to match, at least not as problematic as trying to match the newer ones, so doing away with the stand alone tcon is both a blessing and a curse in that way.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8696
                          Speaking of tvpartstoday.com since someone badmouthed it recently... are their part numbers typically accurate? Searching around there are some parts there that have multiple part numbers like the A1xxxxxxA ... and they're from different TV models and sizes!
                          Ugh. need to repair something else today however. stupid coolant leak ...
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8696
                            Oh the irony!
                            Yesterday someone was CL'ing a *free* Bravia that had a potential identical donor board. I passed on it because my car was in need of repair. And that TV was 100% working too... Figure I leave it for someone else to take, alas, still need a board.
                            Needless to say it's gone now like most free working TVs.
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              #94
                              No worries, there will be more / another one, I'm sure.
                              No one bats an eyelash to throw away an old LCD TV anymore, it seems.
                              I'm still cleaning the "aftermath" of scrap/junk TVs from just 2 Fall/Winter seasons worth of collecting. Parts everywhere, and I still have quite a few non-working whole TVs. I did at least button-up the ones that needed simple fixes, though. One is in use as a monitor right now and another I'm leaving behind as a "gift" for my to-be tenants (I had an extra TV wall mount and extra 40" 720p TV without a stand that's a slight upgrade from the 32" 720p TV they have for their bedroom.) Just gotta fetch a remote for some of these now. Speaking of which - grr... why can't people throw away / give away the remotes with the broken TVs? Or rather, why can't people not loose their original remotes all the time? I see this so often now, where I go to someone's house and they ask me how to change a setting on the TV, then proceed to shove their Amazon Firestick remote in my way and tell me that this is the one and only remote they have for the TV, and claim it's also the remote that came with the TV.
                              - Oh, but are you sure this is not our TV's remote?
                              - Yes. :annoyedface:
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8696
                                BTW, Sony's "firmware" image is in bits and pieces, anyone happen to know how to assemble them into one image? Or perhaps it seems that there are pieces of the image that are not in the distributed image, some needs to remain on the chip on the board (boot block?)
                                • Sus256
                                  HISENSE 65E7KQ PRO - no boot
                                  by Sus256
                                  Hi all!
                                  HISENSE 65E7KQ PRO
                                  RSAG7.820.13512 - chassis
                                  MT9618BAATAB - cpu
                                  RSAG7.820.12059 - power
                                  HD650Y3U77 - panel
                                  KLM8G1GETF - emmc
                                  The TV does not turn on, the standby indicator is on. All voltages are present.
                                  Emms is dead. Not readable, not detected.
                                  Replaced emmc.
                                  But with another dump there is no launch
                                  Terminal log
                                  UART
                                  AC_ON
                                  RPMB key is not yet programmed
                                  HASH1_VERSION=0x00000000 64bit
                                  E-B
                                  FDE enabled
                                  layout pattern onebin by SAR7,0...
                                  06-01-2025, 02:11 AM
                                • Michael Long
                                  No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                  by Michael Long
                                  I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                  Dead / No Power / No Standby Light results after power company had three
                                  consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                  After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                  09-13-2022, 06:55 AM
                                • noinimod
                                  Sony 55X900E no standby light, no power. Replaced mainboard already
                                  by noinimod
                                  No standby red light, nothing
                                  This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                  Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                  At a few pins I can see the power supply providing 19.5V to the main board
                                  Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                  LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                  12-22-2021, 12:58 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
