Toshiba 58L1350UC Backlight.
  • tantogata
    • Dec 2022
    • 14
    Symptoms: turn the TV on - short white flash screen and black. Flashlight test showing an image on the black screen. Power light is on (green light). I've red a "A guide on how to troubleshoot 2 seconds to black" but before to start to follow this guide may be someone got the same experience with that model of the TV and give me some additional advice. Thanks.
    P.S.
    After moving (shaking) and didn't operate the TV for several days it starts to work properly for 10-15 minutes and go black screen again.
  • neilc6
    • Nov 2015
    • 1550
    Re: Toshiba 58L1350UC Backlight.
    On Toshibas, bad backlights can damage the power supply and vice versa. So if you install new strips, they can be instantly be damaged again. Do not recommend repairing these models for this reason since you will spend more money trying to repair than the tv is worth.
      • 12272
      • U.S.
      check over your solder joints, just in case its something simple like that, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
        • 12272
        • U.S.
        check the big capacitor C601, carefully VERY HIGH VOLTAGE THERE, meter set to dcv probe on each leg, see what voltage you get with tv powered on. If its around 400 or so, then maybe take it down to the backlights and check them and their connections, refresh rate for this one is 120, a lot of gamers like that.
          • 12272
          • U.S.
          maybe check the electrolytic capacitors around the P802 connector.
          • tantogata
            • Dec 2022
            • 14
            Everything looks perfect
            https://imgur.com/a/VFDR5l6
            355V. on C601 capacitor. The electrolytic capacitors around the P802 connector look like new.
            Looks like the issue is in backlight strip. Right?
            • tantogata
              • Dec 2022
              • 14
              I've checked LED strips - work fine (125-130V. for 23 LED in one line, there are 5 lines, no one died, around 5,5V for one LED, is it OK?).
              Measurements on LED connector (P803 on power board, from 0-1,5V. between LB1-/LB2-/LB3-/LB4-/LB5- and LB1+/LB2+/LB3+/LB4+/LB5+ with/without connection LED strips, power TV on). BUT if I put negative lead on ground and positive one on LB1+/LB2+/LB3+/LB4+/LB5+ I get 120V.
              What I did: checked all diodes, LED strips, voltages on P803 connector. The diode (D201) is strange. When I'm checking on the board it passing test in both side. When I took it out and check again the diode passing test only one way (as normal). The fuse is OK.
              • tantogata
                • Dec 2022
                • 14
                I'm confused, all symptoms tell that I have dead led strips but I've checked them with a backlight tester, no one was dead. Is it possible if even all led strips pass test they still have an issue?
                  • 12272
                  • U.S.
                  could be, most backlight testers do not supply the current that the powerboard does, so they could be failing at the higher current, but backlight testers are still a great tool imo, they have saved me many hours of troubleshooting by just showing me the screen had a slight crack, that could only be detected by lighting up the screen.
                  • tech9pc
                    • Sep 2021
                    • 49
                    You can also try testing each LED individually ... if you see any that are working but are dimmer than the rest .. replace them.
                    • tantogata
                      • Dec 2022
                      • 14
                      I'm not sure, please clarify a question: I have 0 volts between LB1- and LB1+, LB2- and LB2+, and etc. (TV is on, disconnected LED wires). Is it normal? I think it must be around 120 volts like to between ground and LB1+, and etc.
                      • tantogata
                        • Dec 2022
                        • 14
                        Some guys recommend to measure voltage for LED strips between LB1- and LB1+ on the connector, the others between "ground" and LB1+. Who is right? I'm confused.
                        • tantogata
                          • Dec 2022
                          • 14
                          If I unplug the TV for a long time (several days), the TV is working untill next turn on/off. I've changed a powerboard but the problem is still there.
                          • lotas
                            • Jan 2016
                            • 4745
                            • Russia
                            The problem may be not only in the LEDs, but also in the connectors on the strips themselves (no contact, burning, poor soldering, cracks).
                            • lotas
                              • Jan 2016
                              • 4745
                              • Russia
                              You should always measure between LB1- and LB1+, because on LB1+ it is always present relative to gnd, and LB1- is controlled by driver led and mosfets.
                              • tantogata
                                • Dec 2022
                                • 14
                                I've changed a main and power boards but the problem is still there. I've checked LED connectors, they are ok. All LEDs light well, I've checked them with my LED tester. Now I'm thinking to change T-CON board - the last board on the TV which I didn't change yet. If this not help to fix the TV it will be interesting.
                                  • 12272
                                  • U.S.
                                  First post, you state flashlight shows an image, MOST times this means a backlight issue, could also be powerboard issue, usually I like to prove the backlights and powerboard before moving on to mainboard or tcon or panel.
                                    • 12272
                                    • U.S.
                                    "I've checked LED strips - work fine (125-130V. for 23 LED in one line, there are 5 lines, no one died, around 5,5V for one LED, is it OK?)." what does that mean? if it is different than the rest it's a backlight issue, when you are able to turn the tv on, set the backlights or brightness way down, then see if tv stays on longer.
                                    • tantogata
                                      • Dec 2022
                                      • 14
                                      All 5 led lines light shine with led tester. No one single led died. When the TV is turning on LEDs is short flashing and that's it. After long period of time (a week and more) not operating the TV, it is turn on and works for long time (I dodn't know how long cause I've tried to turn off and on the TV but on second time turning the TV was failed).
                                        • 12272
                                        • U.S.
                                        Are you saying that you tore it down and looked at/tested every single led?
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
