Philips 55PUS7909
  • Narex
    • Dec 2022
    • Slovensko
    Philips 55PUS7909
    Hello.
    I have a broken Philips 55PUS7909 TV. The board number is 715rlpcb0000000401.
    After connecting to power supply, the backlight turns on for 15 seconds and then turns off. No other signs of life. I tried wipedatatool but without success. I also searched the forum, but I did not specifically encounter this problem. TV is not stuck in bootloop.
    Can anyone tell if the error is in the eMMC or in some processor?
    Similar topic
    https://www.badcaps.net/forum/showth...t=72767&page=2
    Code:
    Here is the service log:
    ^@/��S����[   0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state=0x0
    08:16:20.128 ^M^M^^^^M  248] image verified, start at 0x^M0920000...
    08:16:20.375 ^M^^^^^Mz kernel starting... MV88DE3114(BG2Q)‑A1 total 4 cpu^^^^^^^^^M, v2.0.0.21, Aug 5 2014 14:39:52
    08:16:20.419 0213[  303] start_bootloader
    08:16:20.428 ^MU�URx_message 5b 5b 20
    08:16:20.505 ^MLAUNCH_ITM is set to zero
    08:16:20.507 ^Mboard_number = 9
    08:16:20.509 ^MuiBoot = 0
    08:16:20.510
    08:16:20.510 ^MI2C switch set as 0
    08:16:20.512
    08:16:20.662 ^MI2C switch set as 1
    08:16:20.664 ^M‑‑‑‑‑‑‑‑‑ I2C Initialization^^^^^^^^M‑‑‑‑‑‑‑‑‑‑
    08:16:20.668 ^MI2C_INIT: I2C‑2 bus
    08:16:20.669 I2C_INIT: I2C‑1 bus
    08:16:20.675 I2C_INIT: I2C‑0 bus
    08:16:20.683 ^MDD^^^^^^^^^^^^^^^M reg 0xF7CB0BAC value : 0x00021421
    08:16:20.687 ^MDDR reg 0xF7CB0C00 value : 0x00004031
    08:16:20.690 ^Mleakage info 608.
    08:16:20.692 cpu from 1200 to 1275
    08:16:20.695 ^Mset vcpu to 1225mv
    08:16:20.697 set vcpu to 1250mv
    08:16:20.700 set vcpu to 1275mv
    08:16:20.704 set Vcpu to 1275 mv.
    08:16:20.708 core from ^^^^^^^M200 to 1125
    08:16:20.711 ^Mset Vcore to 1175mv
    08:16:20.713 ^Mset Vcore to 1150mv
    08:16:20.715 set Vcore to 1125mv
    08:16:20.718 set Vcore to 1125 mv.
    08:16:20.721 ^M^^^Mlash_ts_init() success.
    08:16:20.839
    08:16:20.839 ^MRDKDMP BG2Q [Oct^^^M27 2017 18:04:12]
    08:16:20.842 ^MPinmux configuration:
    08:16:20.844
    08:16:20.844 GSM 0xf7fcd040 0x009c0261;
    08:16:20.847 ^M0xf7ea0014: 00000072 00240611 00000253 1249008a
    08:16:20.851 ^M0xf7ea0028: 01249492 00000048 1ca54009 0430e44d
    08:16:20.856 ^M0xf7ea003c: 00000000 00000000 0000001f 63c06a52
    08:16:20.860 ^MClock configuration:
    08:16:20.862 ^M VCO_B^I^Ifrequency 1620
    08:16:20.865 ^M AVPLLB[4]^Ifrequency 300
    08:16:20.867 ^M AVPLLB[5]^Ifrequency 800
    08:16:20.869 ^M AVPLLB[6]^Ifrequency 1680
    08:16:20.872 ^M AVPLLB[7]^Ifrequency 610
    08:16:20.874 ^M cpuP^^^^^^Ml^I^Ifrequency 1200
    08:16:20.876 ^M memPll^I^Ifrequency 1500
    08:16:20.878 ^M sysPll^I^Ifrequency 800
    08:16:20.881 ^M dClk^I^Ifrequency 375
    08:16:20.882  cpuClk^I^Ifrequency 1200
    08:16:20.885 ^M sysClk^I^Ifrequency 400
    08:16:20.887 ^M drmClk^I^Ifrequency 400
    08:16:20.889 ^M cfgClk^I^Ifrequency 100
    08:16:20.891 ^M gfxClk^I^Ifrequency 400
    08:16:20.893 ^M zspClk^I^Ifrequency 400
    08:16:20.895  perifClk^Ifrequency 200
    08:16:20.898 ^M pCubeClk^Ifrequency 610
    08:16:20.900 ^M vScopeClk^Ifrequency 610
    08:16:20.902 ^M nfcEccClk^Ifrequency 100
    08:16:20.905 ^M vppSysClk^Ifrequency 400
    08:16:20.907 ^M appClk^I^Ifrequency 800
    08:16:20.909 ^M gfx3DCoreClk^Ifrequency 420
    08:16:20.912 ^M gfx3DSysClk^Ifrequency 400
    08:16:20.914 ^M arcRefClk^Ifrequency 400
    08:16:20.917 ^M vipClk^I^Ifrequency 400
    08:16:20.919 ^M sdioXinClk^Ifrequency 200
    08:16:20.921 ^M sdio1XinClk^Ifrequency 200
    08:16:20.924 ^M gfx3DShClk^Ifrequency 420
    08:16:20.926 ^M avif0Clk^Ifrequency 300
    08:16:20.928 ^M avif1Clk^Ifrequency 300
    08:16:20.931 ^M[00,sd00] bootloader: part1(start=0, blks=1, version=201710271804), part2(start=0, blks=1, version=000000000000)
    08:16:20.941 ^M[01,sd01] fts: part1(start=32, blks=32, version=201710271804), part2(start=32, blks=32, version=000000000000)
    08:16:20.951 ^M[02,sd02] recovery: part1(start=64, blks=120, version=201710271804), part2(start=64, blks=120, version=000000000000)
    08:16:20.961 ^M[03,sd03] tzk_recovery: part1(start=184, blks=8, version=201710271804), part2(start=184, blks=8, version=000000000000)
    08:16:20.972 ^M[04,sd04] factory_setting: part1(start=192, blks=128, version=201710271804), part2(start=192, blks=128, version=000000000000)
    08:16:20.983 ^M[05,sd05] itm: part1(start=320, blks=128, version=201710271804), part2(start=320, blks=128, version=000000000000)
    08:16:20.994 ^M[06,sd06] boot: part1(start=448, blks=24, version=201710271804), part2(start=448, blks=24, version=000000000000)
    08:16:21.004 ^M[07,sd07] tzk_normal: part1(start=472, blks=8, ver^^^^^^^^^Mion=201710271804), part2(start=472, blks=8, version=000000000000)
    08:16:21.014 [08,sd08] system: part1(start=480, blks=1600, version=201710271804), part2(start=480, blks=1600, ve^^Msion=000000000000)
    08:16:21.025 ^M[09,sd09] user_setting: part1(start=2080, blks=960, version=201710271804), part2(start=2080, blks=960, version=000000000000)
    08:16:21.037 ^M[10,sd10] cache: part1(start=3040, blks=896, version=201710271804), part2(start=3040, blks=896, version=000000000000)
    08:16:21.047 ^M[11,sd11] firmware: part1(start=3936, blks=64, version=201710271804), part2(start=3936, blks=64, version=000000000000)
    08:16:21.058 ^M[12,sd12] factory_data: part1(start=4000, blks=32, version=201710271804), part2(start=4000, blks=32, version=000000000000)
    08:16:21.069 ^M[13,sd13] userdata: part1(start=4032, blks=3328, version=201710271804), part2(start=4032, blks=3328, version=000000000000)
    08:16:21.080 ^Mget macaddr from fts: 1c:5a:6b:7d:10:ef
    08:16:21.084 ^Mmacaddr=1c:5a:6b:7d:10:ef
    08:16:21.086 ^Mtzk boot with normal mode by default
    08:16:21.090 ^Mstart to kick off SM CPU: start 0x3ff0449c, size 63216
    08:16:21.095 ^^MSM ^^^MPU is kicked [o f f.
    08:16:21.127 ^M L 1as]Itp(oSwMe)r:m oendtee irs maniont
    08:16:21.131 S^Mt[ a n db y f t s6:]W (cSraMs)h:c oEuntnetreri.nag naddroci_di:n i3t.
    08:16:21.137
    08:16:21.137 f^Mt[s :  bo o t1l2]oaWd(eSrM).c:o mLemaavndi:n g
    08:16:21.142 ^Madc_init.
    08:16:21.143 ^M[   18]W(SM): PWM Initialized
    08:16:21.146 ^M[   21]I(SM): begin to run tasks
    08:16:21.149 ^^^^^M[   514]W(SM): Joystick connected
    08:16:21.642 ^M^^^Merify boot image passed.
    08:16:22.053 ^M^^^MTP Temperature: 0 celsius ^Megree
    08:16:22.078 ^MChip Version: 0xa1d
    08:16:22.080 ^MSend bootmode=0 to SM.
    08:16:22.082 ^Mget macaddr from fts: 1c:5a:6b:7d:10:ef
    08:16:22.086 ^Mmacaddr=1c:5a:6b:7d:10:ef
    08:16:22.088 ^MGenerated bootargs: androidboot.hardware=AND1E quiet lpj=11935744 root=/dev/ram0 androidboot.console=ttyS0 console=ttyS0,115200 init=/init vmalloc=448M quiet macaddr=1c:5a:6b:7d:10:ef emmc_ts.dev_id=1 emmc_ts.size=16777216 emmc_ts.erasesize=524288 emmc_ts.wr^^^^^^^^^^Mtesize=512
    08:16:22.113 update system memory region: (0x01000000, 0x3f800000)‑>(0x40000000, 0x00800000)
    08:16:22.121 update system^^^^^^^^^^^^^^^^^^^^^^^^^Mmemory region(TZ): (0x40000000, 0x00800000)‑>(0x40000000, 0x40000000)
    08:16:22.131 ion_pool_num : 0x00000004, ion‑attributes‑num‑per‑pool : 0x00000002
    08:16:22.138 pool[0]: name: SW_noncache, base =0x02800000 , size = 0x00800000 ion_attr[0]: 0x00000002 ion_attr[1]: 0x00000939
    08:16:22.149 ^Mpool[1]: name: SW_other, base =0x03000000 , size = 0x16c00000 ion_attr[0]: 0x00000002 ion_attr[1]: 0x00000f3d
    08:16:22.159 ^Mpool[2]: name: NW_all, base =0x19c00000 , size = 0x22300000 ion_attr[0]: 0x00000002 ion_attr[1]: 0x00000f36
    08:16:22.169 ^Mpool[3]: name: NW_noncache, base =0x3bf00000 , size = 0x02000000 ion_attr[0]: 0x00000002 ion_attr[1]: 0x00000f3a
    08:16:22.179 ^MRespo^^^^Mding to SM...
    08:16:22.181 ^Mdon't do dts customization for A1D
    08:16:22.184 ^M[ 2062] Boot normal GTV image
    08:16:22.187 Start kernel at 0x40008000
    08:16:22.193 ^^^MUncompressing Linux..^M^^Mdone, booting the kernel.
    08:16:33.302 ^@
    08:16:39.117 Connection lost
  • Narex
    • Dec 2022
    • Slovensko
    Re: Philips 55PUS7909 no picture
    does anyone know what the problem is?
    • Maalobs
      • Jun 2016
      • 120
      • Sweden
      Where did you catch the bootlog from, did you record serial output from SOC-TXD-SERVICE?
      You seem to have some setting incorrect in your serial adapter, use 8N1 (8-bit, no parity, 1 stop bit) and try different speeds, start with 115200 and 57600.
      Control characters have been inserted and some characters have been replaced, maybe entire lines are missing.
      From the output that you do have, it looks like the system has successfully reached the transition away from the semi-standby state, and there it halts, so maybe it entered protection mode.
      If you can record a bootlog without artefacts, perhaps there is additional information there?
      You can download the service manual for your model from this page.
      Chapter 5 is the interesting part for you, and read through section 5.5.1 first.
      If you attach mains power and leave it for several minutes, does the TV eventually begin blinking the power LED according to signals in table 5-1?
      Study the fault finding flowcharts in sections 5.3.1 to 5.3.6.
      If you identify all of the various power rails and measure resistance to ground from each of them, maybe you'll find a short circuit?
      The service manual covers several models, so refer to table 2-1 to find the circuit diagrams and PCB layouts that are specific to your model.
      See what happens if you unplug backlight, Ambilight, and even the TCON board, can you produce a different error condition?
      There seems to be a hardware SDM in this model, at least according to the flowcharts.
      If you follow those comments and start the TV in SDM mode, then it will override the protection mode and you will be able to measure voltages on all power rails.
      Do that in short bursts, one rail at a time, so you don't leave it on for too long and maybe fry something that is drawing too much power.
      • lanada
        philips 55pus7909/12
        by lanada
        i have a philips for repair 55pus7909/12
        fault is no display but the white logo philips lit below of the screen
        No display
        No backlight
        no sound
        power supply the standby voltages are ok
        Any Help regarding this problem?
        11-07-2023, 02:31 AM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • double_DD
        Philips curling iron - is this a common AC cable?
        by double_DD
        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
        08-18-2025, 10:04 AM
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
