A customer just messaged me and after moving from one location to another and plugging in their hisense tv all it does is cycles thru the different colors like its in some kind of test mode.Standby light is red and remote is unresponsive.Have tried unplugging it but no change .Tv was fine before they moved and this happened right after they moved into their new home.Any ideas.
Hisense 65H8608 screen cycling thru colours
Re: Hisense 65H8608 screen cycling thru colours
I was told once that if your main board stops sending a LVDS signal but the 12V supply to the TCON is present then the IC on the TCON goes into self test mode. I have never tested this so i don't know for sure but the only advice i can give you is to remove the LVDS cable for both sides clean it with isopropyl alcohol and reseat it. Maybe it is a bad contact causing this issue since the tv was moved maybe the tv had a bump.
Others in the forum can maybe better advise you. -
You were spot on angelos. Removing cleaning and reseating the LVDS cable brought the tv back to normal.Thanks so much for helping to solve this problem and I would say it confirms exactly what you stated about the tcon getting 12v but no signal gives the screen test mode.Comment
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by RunlincHi all, I need to change the backlights in a Hisense 55E76GQTUK. The screen is glued to the chassis, what is the easiest way of delaminating the screen from the chassis please?
also what double sided tape would you recommend to glue it back in? ….. or is that a question to ask once the screen is out in one piece?
Many thanks for any ideas you have. - Loading...
