CRT Panasonic TV model TX-25T2L Service Mode (?)
  • LittleMega
    • Nov 2022
    • 8
    • Ireland
    Hi guys,
    I have opened the same Thread on AV Forum and they suggested asking here as I didn't sort the following issue:
    I am trying to enter in the Service Mode of a CRT Panasonic Colour TV model TX-25T2L, serial no. LE-331011 (Alpha 2 Chassis) manufactured in UK.
    I tried the most common procedures for CRT Panasonic which match with the operations available on the remote control:
    set the Bass to maximum position,
    set the Treble to minimum position,
    press Vol – on the customer controls at the front of the TV, and at the same time press REVEAL (or RESET or INDEX) on the remote control
    I didn't have any luck ☹
    The remote control is a replacement of the original one but is in full order working.
    I hope a magician among you guys has an answer for that. Thanks!
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: CRT Panasonic TV model TX-25T2L Service Mode (?)
    Item 3 - press "F" on the TV and simultaneously " -Vol" and simultaneously "Reveal".
    Item 4 - first release the "F"
    • LittleMega
      • Nov 2022
      • 8
      • Ireland
      Hi, Thanks for your reply!
      I don't have the button "F" but just the button "N" (Normalise) which I have already tried to press with no luck.
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        What buttons are there on the TV itself?
        • LittleMega
          • Nov 2022
          • 8
          • Ireland
          Please find attached a screenshot of the front panel. "Picture" is a trimmer
          • R_J
            • 9625
            Are you sure it has a service menu? Likely all adjustments are done by controls on the board. The TX-C84DRS uses the Alpha 2 Chassis.
            What are you trying to adjust?
            • LittleMega
              • Nov 2022
              • 8
              • Ireland
              Hi, if I was sure I wouldn't ask for help. Perhaps it is an old model with the trimmers inside to tweak the geometry, but I will not open it. The tv works well but I would like to be able to enter in the service mode as well.
              The model which you have mentioned is one of the latest ones. I think my one is from the 1999s.
                • 12330
                • U.S.
                some info there, not sure if it pertains to your model: https://www.youtube.com/watch?v=PUEe0mkJ6TM
                • LittleMega
                  • Nov 2022
                  • 8
                  • Ireland
                  Thank you for that, but it is not that model, it is much older
                  • LittleMega
                    • Nov 2022
                    • 8
                    • Ireland
                    I have got the info that the tv has been released in October 1991 (model TX-25T2).
                    Could be a key thing to know if the Panasonic TVs released in that period had the access to the Service from screen or not. For instance I had a Sony Crt of the same year which didn’t have the access to the Service Menu from screen so you needed to do the adjustments from the trimmers inside…
                      • 12330
                      • U.S.
                      can you post a good picture of the remote control or a link to an image of it?
                      • LittleMega
                        • Nov 2022
                        • 8
                        • Ireland
                        Hi, please find attached the original remote control (as per manual) and the replacement on which I am using. Thanks
                        • davph
                          • Apr 2014
                          • 23
                          From what I remember Alpha 2 Chassis didn't have a service menu. There is a service switch but all adjustments were still done manually with test points and adjustment points on the board
                          • lotas
                            • Jan 2016
                            • 4859
                            • Russia
                            PANASONIC chassis ALPHA-2
                              LCD LED TV Service Menu Codes
                              ALL LCD LED TV SERVICE MENU CODES
                              Service Menu Code with Board Name
                              China Universal Board / Jumper Board Service Menu Code
                              Changhong Ruba Service Menu Code
                              Ecostar LED TV Service Menu Code
                              Orient LED TV Service Menu Code
                              Haier LED TV Service Menu Code
                              TCL LED TV Service Menu Code
                              Samsung LED TV Service Menu Code
                              LG LED TV Service Menu Code
                              Videocon LED TV Service Menu Code
                              Supra LED TV Service Menu Code
                              Toshiba LED TV Service Menu Code
                              Symphony LED TV Service Menu Code
                              Veste/ LED TV Service Menu Code...
                              10-31-2024, 03:58 AM
                            • piipo
                              Old Privileg 5.1 speakers remote control question
                              by piipo
                              Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                              09-18-2024, 01:55 AM
                            • Chrissygizmo
                              Panasonic tx-40cx400b not responding to remote control
                              by Chrissygizmo
                              Hi all
                              I've just repaired the backlights on this tv. I didn't get a remote with it so I'm using a universal one. The tv works properly via the buttons on the back but the only remote command it registers is the power off. It will power on if I try immediately after switching off, if I leave it until the standby light stops blinking then it won't turn on again from the remote.
                              I don't think the remote is at fault as I've got other remotes that do exactly the same thing.
                              Any help would be really appreciated....
                              Thank you...
                              08-29-2021, 09:48 PM
                            • hemant_2222
                              Schematic for Denon Remote Control RC1156
                              by hemant_2222
                              Hello Everyone,
                              Hope everyone is enjoying their repairs at hand!.
                              I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                              I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                              Please refer to the attached picture, i think the voltage divider is missing...
                              10-06-2023, 02:05 AM
                            • dfear
                              hitachi 75hl16t64u - not responding to remote control
                              by dfear
                              I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                              It came in for a power issue which I have finally resolved by replacing the power supply.
                              The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                              Anyone have a clue how to fix TV?
                              FYI: I have checked the remote work s by pointing it at my camera on my phone....
                              09-02-2024, 12:15 PM
