Philips 50pft4509/12 - stuck on logo
  • marker_123
    • Jan 2021
    • 5
    • Norway
    Hi.
    Got my TV stuck on logo - looks like eeprom.
    Anyone can help with eeprom dump?
    Board: 715g6165-m02-000-005n
    Model: 50pft4509/12
    Thanks in advance
    Marcin
  • Diah
    • Feb 2013
    • 6434
    Re: Philips 50pft4509/12 - stuck on logo
    yours Tv chassis are TPN141E
    go here and
    download only TPN141E_010.003.086.128 (Date published: 2018-01-09) – (Upgrade Loader)
    so your TV back to life hope so if there no HW defect.
    • marker_123
      • Jan 2021
      • 5
      • Norway
      Hi.
      Thank You for fast reply. Downloading and will try soon.
      • marker_123
        • Jan 2021
        • 5
        • Norway
        Hi again.
        Copied .pkg to usb stick, software update process started after that reboot and show Philips logo. Done it one more time with same result.
        I suspect that I need to change eeprom memory - 24128C to a new one.
        However when I replace it - shall I dump current one and program new one or get a dump from somewhere?
        Best regards
        Marcin
        • lotas
          • Jan 2016
          • 4730
          • Russia
          The problem is rather in eMMC.
          • marker_123
            • Jan 2021
            • 5
            • Norway
            Thanks for pointing there ;-)
            Will search for that part and order - P95L-4KA1-JW963 should fit. Got some pinouts for programming so that will be something new to learn.
            Edit:
            Ordered - MTFC4GMCDM-1M
            Can I kindly ask for a file to flash it?
            • Diah
              • Feb 2013
              • 6434
              the way you are going to flash the new chip . do dump for the old one.
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • x_orange90_x
                Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                by x_orange90_x
                I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                12-28-2023, 06:26 AM
              • justice171
                JVC LT-50N795 Stuck on Wisdom Share Logo
                by justice171
                I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                Thanks in advance!
                11-04-2024, 02:55 AM
              • mr.Data
                Macbook A1990 stuck on logo
                by mr.Data
                This Macbook Pro 2018 boots up and then gets stuck on the logo.
                All the normal methods of resetting this Macbook have been tried but do not work.
                I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                Any help would be greatly appriciated....
                04-18-2024, 11:51 PM
              • platinumsteel
                Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                by platinumsteel
                Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                03-18-2024, 05:16 PM
