Samsung Plasma TV PN50B450B1D No Pic, No TV Sound
  • paulxxxx
    • Oct 2022
    • 14
    When I turned it on, it has the internal generated sound, but no audio signal from the TV programming.
    The logic board in the center of the TV blinks at about 1 Hz.
    I checked the voltages to each boards and they seem to be OK
    Visually, there are no bulging capacitors, no burnt transistors, at least when viewed from the top side of the boards.
    The X board buzzes.
    There is no picture at all.
    I play with electronics from time to time but I don't know anything about TV. Does the audio signal go through the X-Y boards as well?
    Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung Plasma TV PN50B450B1D No Pic, No TV Sound
    Disconnect main to control board and connect jumper to autogen on control board. See if you get a test pattern.
    • paulxxxx
      • Oct 2022
      • 14
      Help me out here, what is a "main" (and X-main, y-main)?
      Is there any markings for "autogen" on the control board?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Help me out with some good pictures and good close up of small control board.
        • paulxxxx
          • Oct 2022
          • 14
          Here we go.
          • lotas
            • Jan 2016
            • 4591
            • Russia
            Originally posted by paulxxxx
            Here we go.
            Disconnect the main cable from the logic,
            put a jumper on the Logic 3-4 next to the fuse and turn it on from the remote control.
            • paulxxxx
              • Oct 2022
              • 14
              Thanks.
              But it did seem to do anything.
              I don't have a remote, I just turned it on using the button in front.
                • 12173
                • U.S.
                I would suspect lots of things, first I would remove x board and test the transistors, the ones on the heatsink seem to go bad a lot but check them all, good policy to check everything on heatsinks and the the usual resistors and diodes, plasmas are notorious for one bad board taking out another, you want to make sure your buffer boards have no shorts or problems, theres some good videos on youtube for checking them, tampatec and norcal715 have covered the procedure.
                • paulxxxx
                  • Oct 2022
                  • 14
                  The x-board is buzzing. Is it a good sign or a bad sign?
                    • 12173
                    • U.S.
                    its all about the testing, I dont usually mess around with plasmas, too bulky and heavy, see if this helps, a pro there, notice the heartbeat about 2 times per second on a healthy tv, try the tests: https://www.youtube.com/watch?v=-7zWKY2Hwnc
                      • 12173
                      • U.S.
                      heres Bobby doing your model, its what I suspect is wrong with yours, test those mosfets/transistors, last one I messed with had all bad mosfets on x-board on heatsinks and a bad diode, then I found the y-buffers to be shorted and called it off, was too much trouble for not much reward, it only does 720p: https://www.youtube.com/watch?v=fqs1Ig2UM0M
                      • paulxxxx
                        • Oct 2022
                        • 14
                        Thanks. I suppose I will have to pull these transistors and test them one by one.
                        Somehow, I find my soldering iron isn't powerful enough, especially for melting the solder pins on the heat sink. Do they use a higher temperature solder here?
                        What would be a good soldering iron for general electronics repair that doesn't damage the PCB?
                          • 12173
                          • U.S.
                          testing igbt transistor for shorts in circuit, plenty more videos on youtube if you want to go thru them: https://www.youtube.com/watch?v=T1y3gYL-KmY
                            • 12173
                            • U.S.
                            testing y-buffer board for shorts: https://www.youtube.com/watch?v=3Oq2MsU0XOQ
                              • 12173
                              • U.S.
                              here's ABOVE "average joe" testing for shorts: https://www.youtube.com/watch?v=aZF57Bok7Ws
                                • 12173
                                • U.S.
                                for soldering like this its nice to have a good adjustable iron but they cost more of course, if you dont intend on doing much soldering you can get by with a 40 to 60 watt iron from one of the big box stores or wherever, I wouldnt go lower than 40 watts tho.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  The heatsink is absorbing the heat, you need a decent iron to remove them.
                                  What's your budget ?
                                    • 12173
                                    • U.S.
                                    This is your best bet if it is a match, read the fine red print there about matching, 33 bucks is nothing compared to the trouble of replacing components, imo, be sure and test those transistors and other components with your multimeter and test the y and y-buffer boards, look at those videos I linked: https://www.ebay.com/itm/36216634083...Bk9SR76p74_8YA
                                    • paulxxxx
                                      • Oct 2022
                                      • 14
                                      As cheap as possible. LOL.
                                      I have a few already, one for for modern low power electronics with thin tip, one with large tip for older PCBs that are easily damaged by high heat. This one, the biggest, is a 30W cheapo from sometime ago. It seems to have a gap between the heater and the tip rod that gets bigger as oxidation increases with time. If there is a way to get better heat conduction, I bet this might be good enough.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        You shouldn't have to remove anything till you find a problem.
                                          09-07-2024, 05:50 AM
                                        • willis6732
                                          Samsung Plasma PN43E450A1F - No Picture / Pop Sound
                                          by willis6732
                                          The customer of this TV Heard a pop sound before it went dead.
                                          The VS and VA voltages turn on imediatly and then slowly die off.
                                          I got a replacement Y-Board (Large board on the left) from aliexpress and still no luck
                                          If tested all the IC chipson the board all the way on the left by running meter along the connectors and couldnt find any shorts there...
                                          I think ive checked most the capacitors for shorts as well as most of the diodes and mosfet/transistors on the big boards.
                                          https://photos.app.goo.gl/KDyLcgB38Bh699Zr6
                                          09-26-2023, 06:02 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
