Samsung Plasma TV PN50B450B1D No Pic, No TV Sound
  • nomoresonys
    • 12276
    • U.S.
    Re: Samsung Plasma TV PN50B450B1D No Pic, No TV Sound
    Originally posted by dskall
    You shouldn't have to remove anything till you find a problem.
    +10, no soldering needed til you find a problem, otherwise you can remove a board to get at the underside for easier testing of the transistors.
      09-07-2024, 05:50 AM
    • willis6732
      Samsung Plasma PN43E450A1F - No Picture / Pop Sound
      by willis6732
      The customer of this TV Heard a pop sound before it went dead.
      The VS and VA voltages turn on imediatly and then slowly die off.
      I got a replacement Y-Board (Large board on the left) from aliexpress and still no luck
      If tested all the IC chipson the board all the way on the left by running meter along the connectors and couldnt find any shorts there...
      I think ive checked most the capacitors for shorts as well as most of the diodes and mosfet/transistors on the big boards.
      https://photos.app.goo.gl/KDyLcgB38Bh699Zr6
      09-26-2023, 06:02 PM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
