Vizio E65-E1 strange image issue
+ More Options
Posts
  • remmurdmd
    • Oct 2022
    • 8
    • United States of America
    Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life and don't really have the garage space to safely open up a 65” TV and follow all the electrical inputs and outputs at the moment. Can anyone tell me what this issue is technically called and confirm this is a bad t-con board or some other issue? If I can get a replacement board for this TV then I'd probably do it if the price was reasonable. Thank you in advance, I appreciate the help.
    Note: sorry somehow the picture is upside down.
    Last edited by remmurdmd; 10-02-2022, 09:14 PM. Reason: Note about the picture being upside down
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E65-E1 strange image issue
    Looks like it is in split screen mode. Check user manual.
    • remmurdmd
      • Oct 2022
      • 8
      Thank you for your prompt reply. I searched the user manual but could find no split screen mode. The symptom I'm having persists at all times - the boot screen, inputs, and menu screens show in double next to each other at all times. As far as I can tell, it is taking the full input, removing every other vertical display line (making everything look skinny), and duplicating the remaining display data on the other side of the display. There is no noticeable flickering or other display issues at this time. I just performed a factory reset and setup the display (throughout which it did the same display issue). It is currently downloading and installing some updates. I will report back if anything changes but so far the display issue persists.
      • remmurdmd
        • Oct 2022
        • 8
        After further probing around in all the menus, I noticed a system information page that was unable to tell me the resolution or audio type info. Also, the picture is grainy, as if it were a 480p image being forced onto a 1080p or 4K screen. I assume a main board would be responsible for processing the input data and processing it as output data to the t-con to be split up and sent to the respective display sides. Am I in the ballpark here?
        • alfatv
          • Sep 2020
          • 353
          I could see this with some combinations of main boards and t-con's like RCA.
          Since your setup is original, my first guess would be a corrupted setting, but can't rule out hardware problem as well.
          I checked ebay, the boards for this TV are pretty cheap actually.
            • 12097
            • U.S.
            try turning down the backlights not brightness, see if it changes any, probably a gate driver issue, try the "tape cut-off method"
            • lotas
              • Jan 2016
              • 4540
              • Russia
              https://www.youtube.com/watch?v=QYnKJdddgns
                • 12097
                • U.S.
                Ok, my bad, wasn't signed in to look at pictures, assumed it was the usual double text situation, disregard post.
                • remmurdmd
                  • Oct 2022
                  • 8
                  So you think there's a hidden setting somewhere that may have what I'm looking for? Would I need the original remote or could I get by with another Vizio that I have? Or maybe I could see that option from my phone? Obviously if there's a setting I can correct I'd prefer to do that instead of buying boards to swap out… thank you for your reply
                  • remmurdmd
                    • Oct 2022
                    • 8
                    Thank you. This is exactly the issue I'm having. I can't understand what they're saying though and my TV doesn't have this mode as far as I know. Any additional info you can provide me? Thanks in advance
                    • remmurdmd
                      • Oct 2022
                      • 8
                      No worries. That's the only solutions I've been able to find online. Something for that ghosted image look.
                      • alfatv
                        • Sep 2020
                        • 353
                        Vizio remotes are usually compatible.
                        You need to get into service menu.
                        Search for codes, there are few combinations. If it works, you will see.
                        But I can't guarantee split screen setting is there.
                        • Diah
                          • Feb 2013
                          • 6355
                          i think if you feed the tv with signal... and try to record the video output on VCR for example or any , when you replay the record you will see its clear image or double to narrow the issue. so as solo method its hard to make judgment.. also the history of this issue you don't know.. could some one missed with service menu and lost the correct setting.
                          • remmurdmd
                            • Oct 2022
                            • 8
                            I’d like to revisit this again if you all would provide your input. I found the service menu and checked all settings in there for a split screen setting, to no avail. While I was working on this, I noticed that the two images on the left and right sides are not the same. It’s as if the vertical sets of picture data are first being sent to the left side of the panel, then the next set of data is sent to the right side of the panel, and so on until the entire image is displayed on the screen. I know this because, for example on a letter “M”, the left “pole” of the M is missing from the left side of the panel yet it appears on the right side of the panel. I’ll try to get a picture up here, but it’s like this “vI” on the left side and this “Iv” on the right side. If you can pretend that my vI and Iv are supposed to look like “M”.
                            So long story short, what’s the likely culprit here? Correct me if I’m wrong but Tcon is supposed to take the full picture data and split it up onto the two separate sides of the screen. It seems like it has forgotten to actually split up the incoming image and is just taking what it’s receiving and throwing it up on the screen while alternating left and right sides. Any thoughts on this? Thanks in advance.
                              • 12097
                              • U.S.
                              the t-cons are pretty reasonable if you want to try one, try to match up the numbers on the white sticker to insure a match: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                              • EazyBone
                                Vizio P759-G1, Tcon issue?
                                by EazyBone
                                Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                                Any help appreciated
                                https://youtu.be/tPeV2Q7TXIQ?feature=shared
                                03-22-2024, 03:25 PM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
                              • Fly_Among_Stars
                                VIZIO E70-E3 Half picture with half TCON
                                by Fly_Among_Stars
                                I have a VIZIO E70-E3.
                                Symptoms: Black screen, no picture, but LED backlights are working.
                                I probed the power board and voltages are as listed on the board.
                                Main board appears fine, too.
                                I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                There are two separate ribbon cables feeding the LCD.
                                If both are connected, the screen is black.
                                If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                04-24-2023, 08:20 PM
                              • tbsmith
                                Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
                                by tbsmith
                                I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
                                07-12-2025, 11:40 AM
                              • Ancient1
                                Strange LG TV issue : Image vertical lines in black screen
                                by Ancient1
                                Hi
                                Asking for a friend.
                                I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                but here its the opposite !
                                TV has new T-con = same issue
                                A missing panel voltage would have global effect
                                So , what should one do ? how can I find where the fault is ?
                                Thanks !...
                                02-05-2025, 03:37 PM
