Sony KD-55XF8505 won‘t start
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4537
    • Italy - Milan
    Re: Sony KD-55XF8505 won‘t start
    Let's try to understand something, after that its up to you your choice, this mb appears to be without any tcon integrated, this is clear for me by a series of details, the big Mstar white chip is the FRC processor, not Tcon one, so the 2 eproms in photo are 1 for FRC operations, the other i don't know but by exclusion it can hold standby sw, it is not surely a bootloader cause no activity on the status led means bad stby sw.. if you want to trust me you can start my tests, otherwise i don't know why since you came here because with no ideas.. or you can wait the second board to read the flash by it, since freezing only works sometimes..
    • TobiasG
      • Sep 2022
      • 16
      • Deutschland
      The working board for my TV (with the same part number) should arrive tomorrow. Then I'll also try the the dumping of the eeproms and reflashing the dumps to my old board, since it might lead to me saving money because I can then send the new board back.
      Anything else would be stupid, or
      I also considered checking all the electronic parts again with the values i will messure at the new board and maybe I'll still find the error on my old board.
      But if it still doesn't work, what else could it be?
      • lotas
        • Jan 2016
        • 4855
        • Russia
        I figuratively said that this MStar chip belongs to T-Con, since the output, signal lines go to the panel (t-con) and it cannot be responsible for the standby mode, and these two SPI Flash just relate to this MStar chip, as their position numbers start with IC4xxx.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4537
          • Italy - Milan
          yes this is a good point for you, in meantime i noticed there was also a picture of the stand alone tcon, the MStar chip is the FRC not the tcon, it sounded strange to me it required till 2 eproms to work but it is probably right.. at this point it seems this is an "always on" Android tv and the bad software is the main/only sw in the emmc, so this worths a typical test of the android devices and is trying to access recovery mode with keys combinations, if not done i suggest research of service manual cause entering could include both RC keys and local keys pressed, i think the main key possible on RC is the power key, then togheter another key on the local keyboard, try different combinations and see if starts.
          other possible tries are PC connection through ADB utility and usb, or uart connection and log viewiing , but this is for high end techs..
          another mention for the ic605 near the emmc, this is probably the reset ic, it must be probed if a good reset signal is send to the Cpu during the plugging of the tv to mains..
          • TobiasG
            • Sep 2022
            • 16
            • Deutschland
            And what does that mean for me now?
            Is it probably the eMMC?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4537
              • Italy - Milan
              #26
              yes it is..
              • TobiasG
                • Sep 2022
                • 16
                • Deutschland
                #27
                Do you think that the chip is defective or the data it contains, or could reflowing help?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4537
                  • Italy - Milan
                  #28
                  i think only data is corrupted, it can be revived by a deep clean and rewrite..
                  • TobiasG
                    • Sep 2022
                    • 16
                    • Deutschland
                    #29
                    With the new mainboard everything works fine.
                    Maybe I will try later, if it is possilbe to read the emmc from the new one and write it to the old. Maybe it works with less deep engagement
                    • lotas
                      • Jan 2016
                      • 4855
                      • Russia
                      #30
                      Be careful, when reading the dump, some programmers change the contents of the "EXT_CSD" file, and after that the TV will no longer turn on.
                        • 12330
                        • U.S.
                        #31
                        ok, with that being a possibility, I would just be happy with the new board and the tv working, would save the old board, not really worth the risk of messing up the new board. If you have or can find a good dump, maybe just buy a new emmc and try that for the old board, I think they're around 15 bucks or so, at least that's the price that I saw.
                        • TobiasG
                          • Sep 2022
                          • 16
                          • Deutschland
                          #32
                          Unfortunately, the firmware for the board cannot be found on the internet. I've searched on Russian sites myself. but they seem to have installed other mainboards
                            • 12330
                            • U.S.
                            #33
                            can get them preprogrammed, about 50+ U.S. dollars. seems a little high but haven't seen them for less.
                            • mmartell
                              Sony KDL-65W850C is this a Mainboard issue ??
                              by mmartell
                              This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
                              Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
                              It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
                              11-19-2023, 10:27 AM
                            • TerraPhantm
                              Sony A8H to A80J mainboard upgrade possible?
                              by TerraPhantm
                              I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                              So I decided I'd experiment a little bit.
                              I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                              When...
                              08-15-2023, 08:10 AM
                            • noinimod
                              Sony 55X900E no standby light, no power. Replaced mainboard already
                              by noinimod
                              No standby red light, nothing
                              This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                              Disconnected JK3 power board from main board, checked voltages on all the pin outs
                              At a few pins I can see the power supply providing 19.5V to the main board
                              Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                              LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                              12-22-2021, 12:58 AM
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • dkneyle
                              Sony KDL-46HX850 Can't upgrade/update firmware
                              by dkneyle
                              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                              09-25-2024, 10:44 PM
